Question about Ricoh Office Equipment & Supplies
Hi I have a AP3800c with regular paper jams betwen tray 1 and the Vertical Transport cover. Its screws up the paper in this area. I have already replaced the feed rollers. Any suggestions please. Cheers Dave
  • daveiow Dec 07, 2008
    Hi I have a Ricoh AP3800C Printer. It has developed a intermittent paper jam between the output from tray 1 and the Vertical Transport cover. Its screws up the paper in this area. I have already replaced the tray 1 paper feed rollers. All the rollers on the Vertical Transport Cover run freely. The jam occurs every 3 -5 copies. The whole area is clean with no obstructions. The jamming is in this area as I have run several single print runs to see how many it takes to jam. Cheers Dave
  • 4,889 Answers
If the printer continues to Jam after replacing the rollers then the problem can be in the pickup, turning, alignment areas. I would start by checking the alignment area for worn out parts or any "junk" such as bits of paper, clips, hair etc., obstructing the alignment process. If not check the pickup and turning categories for similar characteristics. Feel free to post back if you need more help.
Regards,
Sai.
Posted on Dec 07, 2008
    Genius:
  • 1,239 Answers
After years of heavy use the rubber rollers which transport the paper through the printer can get a shine to them and tend to loose their grip. This causes misfeeds and blockages.
HI
Using a damp cloth and something like Jif (slightly abrasive kitchen/bathroom cleaner) rub the rollers whilst rotating them by hand. With a clean damp cloth remove any cleaner and you should see the rubber has lost it's sheen.
Some rollers can be hard to get at but a little patience pays off. I've reclaimed dozens of printers due to be scrapped in this way.
  • 1 more comment
  • ABHISHEK.C
    ABHISHEK.C Dec 07, 2008
    INTERMINTENT PAPER JAMS ARE GENERALY CAUSED BY
    1. DIRT RESUDUE OF PAPER SPECIALY COATED /PHOTOPAPER THAN HAS STACK ON THE HEATING ELEMET/FUSE UNIT ACCESSED THROUGH DOOR AB.
    2.POOR PAPER QUALITY THAT KEEPS ON SLIDING WITHIN THE PAPER PICK UP MECHANISIM AT THE PAPER TRAY
    3.INCORECT PAPER SIZE -LENTH- SELECTION AT THE PRINTER PROPERTIES SETTING
    4. USE OF VARYING PAPER LENGTH AT THE PAPER
    5. STATIC CHARGE THAT TEND TO BIND PAPERS TOGETHER, PERUSE THROUGH PAPER BANDLE BEFORE INSERTING TO PRINTER
    6. TORN PAPER PIECES THAT GOT CAUGHT UP WITHIN THE MECHANICALS OF THE PRINTER:::FI X - OPEN DOOR AB AND SIMPLY INSPECT:::
    7. THIS SHOULD BE YOUR LAST RESORT
    ::::THEORY :::: OFTENLY PAPER JAMS ARE CAUSED BY WARE AND TARE OF THE PICKUP MECHANISM AT THE PAPER TRAY, THE PICK UP ROLLER LOCATED AT UP THE FURTHEST END FROM THE MIDDLE OF THE PAPER TRAY IS THE CALPRIT. THIS FIX WILL SIMPLY RESTORE THE GRIP OF THE PICK UP ROLLER. :::: FIX:::: WITH A NORMAL SAND PAPER RUB THE PICK UP ROLLER (BLACK RUBBER) GENTLY ACROSS (RIGHT TO LEFT) FOR A FULL CYCLE OF ROLLER::: IF THIS FIX DOESTNT FIX YOUR PRINTER THEN BITE THE BULLET AND REPLACE YOUR PICKUP ROLLER.
    SIMPLE FIXES FOR THE NON TECHNICAL
  • ABHISHEK.C
    THANK YOU PLEASE RATE IT.............
  • ABHISHEK.C
    i hope this will help you but let me know if it doesnt i will get further into it with you
    richard from chicago
    http://h10025.www1.hp.com/ewfrf/wc/docum...
    Issue An 'Out of paper' error message displays on the computer and the product does not pick up or feed paper from the main paper tray
  • 365 Answers
The output side may have some difference in the uniformity.clear it
  • JITHIN ANTONY Dec 14, 2008
    have you checked the thing all
I have a problem with my di183 copier.
Where is a paper jam located?Please relate detailed the jam location in fuser unit?in paper tray?in vertical transport?
Mar 30, 2013 | Minolta DiALTA Di183 Copier
When i switch on my photocopier tohiba 2860, it asks for service and gives an error code 08221-918100. what could be the problem?
Hi tkasirye,
Welcome to Fixya.
You may need to check again the error code. According to the manufacturer's checklist for error codes, only the following are documented;
  1. Error Codes - Toshiba 2860
  1. "E01" Paper jam inside machine. "E02" Paper jam near the fuser. "E03" Paper jammed inside machine when power supply is switched on. "E04" Front cover open while copying. "E05" Paper jam near the aligning roller "E08" Paper jam at stacking area in the ADU "E11" Paper feeding jam at the ADU "E12" Manual feeding jam "E13" Paper jam from cassette 1 "E14" Paper jam from cassette 2 "E15" Paper jam from cassette 3 "E16" Paper jam from cassette 4 "E17" Paper jam from cassette 5 "E19" Paper jam from the LCF "E21" Paper jam in transport route 1 (LCF) "E22" Paper jam in transport route 2 (COPIER) "E23" Paper jam in transport route 3 (ALIGNING) "E25" Paper jam in transport route 4 (PFP) "E71" Original feed jam in ADF "E72" Original transporting jam in ADF "E73" Original exiting jam in ADF "E75" 2nd original feeding jam "E81" Paper jam before sorter "E82" Paper jam in sorter "E83" Sorter early arrival jam "E84" Paper in sorter when power is turned on "E85" Joint open jam while copying "E88" Paper jam outside the sorter bin "C01" Abnormal operation of the copier main motor "C04" Abnormal operation of the PFP main motor "C05" Abnormal operation of the ADU main motor "C11" Abnormal operation of the ADU side motor "C12" Abnormal operation of the ADU end motor "C13" Abnormal operation of the upper cassette tray "C14" Abnormal operation of the lower cassette tray "C15" Abnormal operation of the PFP upper cassette tray "C16" Abnormal operation of the PFP middle cassette tray "C17" Abnormal operation of the PFP lower cassette tray "C18" Abnormal operation of the LCF tray "C21" Optics carriage initialize error "C22" Lens initialize error "C23" Mirror initialize error "C26" Faulty exposure lamp "C33" Easy set-up is failed "C35" Developer material exists at the transfer separation adjustment "C41" Faulty thermistor or heater "C43" Faulty thermistor "C44" Faulty heater "C45" Sub thermistor is open
Shoulg you not find any of these mentioned error codes, I suggest you contact the tech support especially if the machine is still under warranty.
Hope this helps.
Takasashi
Jul 05, 2011 | Toshiba Office Equipment & Supplies
I have a problem. When I turn on my printer, the first symbol from top constantly blinks and it doesn't print anything. How can I solve this issue?
Welcome to FixYa!
If the first symbol on the top is constantly blinking as shown in the picture below, It means that a paper or a foreign object has jammed your printer.
Jam can occur in 3 areas. Please refer to the image below.
1. Internal Areas
2. Input Trays
3. The Output Bins
To clear the jam, turn the printer off and disconnect the power cord. Be careful not to tear the paper in case of a paper jam. If a small piece of paper remains in the printer, it could cause additional paper jam.
Let's clear out the Internal Areas first. Push the button to open the print-cartridge door, and then remove the print cartridge. To prevent damage, do not expose the print cartridge to light. Cover it with a piece of paper. Please refer to the image below.
If jammed paper is visible, grasp it with both hands and slowly pull it out of the printer. Please refer to the image below.
If no paper was jammed inside the print-cartridge door, open the Output Bin or the back door
of the printer. To avoid damaging the printer, do not attempt to clear a jam in the top output bin by pulling the paper straight out.
Again, if jammed paper is visible, grasp it with both hands and slowly pull it out of the printer.
If no paper or foreign object is visible, close the back door of the printer.
Next, let's take a look at the Input Tray. (We have already taken out the print cartridge.)
Lift the Tray 1 roller cover, grasp the jammed paper or foreign object, and slowly pull it out of the printer. Please refer to the image below.
If no jammed paper is or foreign object is visible, open Tray 2 and see if a paper is visible. Again remove it slowly with both hands. Please refer to the image below.
Close Tray 2.
If no jammed paper is visible in the second tray area, pull down the upper media guide (we have already taken out the print cartridge). With both hands, grasp the jammed paper and slowly pull it out of the printer. Please refer to the image below.
Close the upper media guide and return back the print cartridge. Please refer to the image below.
These steps should clear out any jams that you are experiencing.
Connect back the power cord again and turn on your printer. You should be able to print now.
Thanks for using FixYa. Keep me posted.
Jas247
Mar 03, 2011 | HP LaserJet Black-and-White Laser Printer
JAM E, UNNABLE TO CLEAR ERROR
Jam E normally cause by the paper path sensor came off during when you clear a paper jam.. the sensor is located at middle side , to fix it back you will need to remove the E cover..and remove the transport unit...4 screws.. but putting it back will need to have some technical know how as fitting it back wrongly will cause you unit not able to feed paper due to the plastic blocking the paper path.
Will upload some instruction later...
Apr 14, 2010 | Epson Aculaser C1100 Printer
Hp LaserJet 4100 printer says its out of paper which is not the case, could someone assist me and figure what may be causes this problem? Thanks in Advance
Paper jams can occur in the following areas
1 Top cover and toner cartridge area
2 Optional envelope feeder
3 Input tray areas
4 Optional duplexer
5 Output areas (top and rear)
6 Fuser area
Solving repeated paper jams
* Check all the paper jam locations. A piece of paper might be stuck somewhere in the printer. Even a small torn piece of paper in the printer path can cause repeated jams.
* If using a duplexer, check all areas (including under the duplexer).
* Check that paper is correctly loaded in the trays, that all three adjustments have been made, and that the trays are not overfilled. Make sure paper is under the front and back tabs.
* Check that all trays and paper handling accessories are completely inserted into the printer. (If a tray is opened during a print job, this might cause a paper jam.)
* Check that all covers and doors are closed. (If a cover or door is opened during a print job, this might cause a paper jam.)
* Try printing to a different output bin.
* The sheets might be sticking together. Try bending the stack to separate each sheet. Do not fan the stack.
* If you are printing from tray 1, try reducing the size of the stack.
* If printing from the envelope feeder, make sure it is loaded correctly, pushing the bottom envelopes in slightly farther than the top envelopes.
* If you are printing small sizes, feed paper short edge first.
* Turn over the stack of paper in the tray. Also try rotating the paper 180°.
* Check the characteristics of the media you are using. Use only paper that meets HP specifications (see the online user guide for paper specifications). Try using different paper to see if the problem goes away. Do not use curled, deformed, damaged, or
irregular paper.
* Avoid using paper that has already been used in a printer or copier.
* Do not print on both sides of envelopes or transparencies.
* Print only on full sheets of labels and do not print on both sides of label sheets.
* Check that the power supplied to the printer is steady and meets printer specifications (see the online user guide for printer specifications).
* Clean the printer (see the online user guide procedures).
Hope this helps.
Please rate my response.
Thanks
Have a good day.
Dec 09, 2009 | HP LaserJet 4100 Printer
Paper jam
Hi usually paper jam at paper input area a or transfor section(photo drum area or fuser unit area, so you may try:
1) take out paper tray and open the cover that you can change toner cartridge there (see manual) looking for any paper inside paper input area or around the cartridge, then take out jam paper.
2) open fuser unit at paper output area ckick a locker at somewhere (see maanual) looking for any paper jam
Dec 22, 2008 | Canon imageRUNNER 1310 Printer
Kyocera FS 9130DN is showing MP tray transport jam and to open front cover. No paper is jammed or in the machine.
check the bypass transport connector for a small piece of paper. or the paper sensor arm is jammed down there are 2 one in the transport unit and one in the mp tray
Nov 03, 2008 | Kyocera Office Equipment & Supplies
Kyocera Printer FS-1800 plus - paper jam Can't find the printer manual. Please provide steps to clear the paper jam and reset the printer.
Hi, first of all,pull out paper tray and check any paper,or scrap jammed.When paper tray is pulled out,open paper transport unit-You have green handle on the right side of machine,in the place of right side of paper tray.Pull out paper transport and remove paper.Just close paper transport unit and paper tray,open and close top cover.
Nov 29, 2007 | Office Equipment & Supplies
Paper transport does not work; terrible grinding noise
I took mine apart from the back and put it back together and it worked. It is probably due to moving it and the bottom paper tray alignment gets out of whack. I inspected all of the gear train and didn't find any worn or missing teeth. I suspect a paper jam started it and the user turned the printer around to open the back door. Since the handles are on the printer the tray doesn't move with it which allows it to separate and possibly jam a pickup drive gear.
Nov 08, 2007 | Dell 3000cn Color Laser Printer
Paper wont go through printer
You have a very small jam, and possibly need to reset your printer margins also. Take out all visible paper in tray. Open unit, get a torch and some tweezers. Thoroughly check all inside in rollers, near carriage for printer cartridges, left and right, and down the back where paper goes. I am wiling to bet you find a tiny scap or foreign object( i call them ujo's, unidentified jamming objects) my little boy jammed mine with a scrap off his toy typewriter!!! It was so small you clould barely see it. Tip: once fixed, regularly open unit and tidy rollers and paper area with a long thin soft bristled brush. Keep printer covered after it cools and breaths betwen usages. I do!!!
Aug 24, 2007 | Canon PIXMA iP4200 InkJet Photo Printer
26 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Bernard D'Souza
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
