Question about Rangemaster Classic 90 (Electric) Kitchen Range
Classic 90 (Leisure) cooker. The oven igniter does not work.
I have had this cooker for about 5 years. The igniter of the oven does not work . I feel a good service might sort the problem, but I would like to know how much will this cost? Any ideas?
SOURCE: rangemaster leisure 110
Hi
Just to say we sorted the problem. Simply the bulb was out in the one oven. We replaced this and problem solved.
Carole
Posted on Feb 10, 2008
  • 1550 Answers
SOURCE: hi my leisure alta cookers
CAN YOU BE SPECIFIC WITH YOUR MODEL NO
ITS DIFFICULT WITHOUT MODEL NO TO SUGGEST A SOLUTION TO YOUR PROBLEM .
Posted on Sep 22, 2008
SOURCE: Leisure classic 90 - oven
Replace the ignitor
Posted on Dec 04, 2008
FitzOriginal
  • 842 Answers
SOURCE: rangemaster classic 90
Regardless of the clock running, if the timer is not set to zero and off, the oven will not function. See my instructions on using the timer (http://www.fixya.com/support/t1416237-timer_instructions_rangemaster_toledo) I hope that this is your problem and it will show you how to get the oven going again.
Posted on Feb 15, 2009
SOURCE: both ovens on my leisure rangemaster 100 will not come on
I have a range master cooker, where both ovens do not work, because the clock/timer is not working, but if I switch the griddle/grill on for approx 1 hour everything works fine!! The clock starts flashing, i press reset & switch the ovens on! Once the griddle has cooled down, you have to start the entire process again the following day! This appears to be a vary common fault.
Posted on Jun 24, 2009
My gourmet classic leisure cooker has a noisy fan. What can I do?
Hello CAROL ROSA,
If it is NEW... TAKE IT BACK.
ELSE... (replace the fan).
Post the actual model number to see if
we need to look for 'parts' (USA) or "spares" (rest of the world)...
Together we can get this
'FIXED' (USA) or "sorted" (rest of the world)...
http://www.harveynorman.ie/home-appliances/cooking-appliances/range-cookers/leisure-gourmet-classic-oven-grb6cvr.html
Aug 30, 2016 | Kitchen Appliances - Others
I have a leisure range cooker. model number CMTF99R.The oven RHSis not Heating up. the fan is working and the thermostat light is coming on.
Check for voltage at the element, could be a hi-limit thermostat or a failure at the control board.... You may find you are missing one leg (half) of the 240VAC required to power the elements
Jul 31, 2016 | Leisure Range 90 CMTF95C Cream 900 mm Dual...
I have a Leisure Gourmet Classic double oven. The hobs, the grill and the upper oven all work fine, but the lower oven suddenly stopped producing any gas. I turn the knob and the austomatic ignition s
Apparently there is a bad valve for that oven , recommend calling a gas service repairman . your gas provider should be able to recommend a good one to you .
Apr 19, 2017 | Leisure Kitchen Ranges
The gas flame in the oven of my leisure classic 90 starts on tick over but than does not flare up to full flame like it should
common problem,it will most probably be the solenoid FF device fitted by the oven burner,these can be obtained from Gas On Spares on 0121-585-7799.the will need the model number and serial number.
Apr 02, 2011 | Rangemaster Classic 90 (Electric) Kitchen...
Just bought a Leisure Gourmet Classic gas cooker. Connected the gas and plugged it in but none of the burners will light. The ignition is working but no gas is getting through. Any ideas folks? TIA, Andy
I had a similar problem when my new Leisure cooker was installed last December. The burners would light when I held the knobs in but when I let go the flame would go out. The engineer took off each of the burner knobs and stuck a small wad of aluminium foil between the inside of the knob and the contact on the front of the cooker - he said it's a design fault and the gap is just a bit too large for contact to be made reliably. This fixed the problem and I've had no trouble since.
Jun 22, 2010 | Ovens
Don't know what electricity supply is required
Emmet in luton: what fuse does a rangemaster 90 duel fuel need?
Apr 10, 2009 | Rangemaster Classic 90 (Electric) Kitchen...
Rangemaster Classic 90 (Electric) Kitchen Range Logo
162 people viewed this question
Top Rangemaster Kitchen Ranges Experts
Ismael Rodriguez...
Paul Carew
Charles T Nevin
Charles T Nevin
Are you a Rangemaster Kitchen Range Expert? Answer questions, earn points and help others
