Gaggia Classic Espresso Machine
Problem for Gaggia Classic Espresso Machine
Gaggia Classic Espresso Machine - will not pump water
By vincentSF on Feb 14, 2007
Hi!
I have a Gaggia Classic Espresso Machine that will pump espresso through the filter only very weakly, drop by drop. one cup takes about 3-4 minutes to fill. I bought it used and it worked when i got it. A month later this problem arose. it's worked fine once or twice in between for no obvious reason. What I've tried:
- cleaning all the filters in between. as well as removing all the filters entirely, where it still only pumps drip by drip.
- repriming the pump as suggested in the manual...ie. running H2O through the steamer for a while. No noticeable effect here.
I can hear the pump working and sometimes, water will start dripping back into the H2O tank through some kind of overflow tube in there.
any help will be really appreciated as this thing makes unbelievably good coffee....
thanks! -v
Same Problem
Oct 31, 2008
-   water will pumps thru very slowly creating alot of back pressure. I have unscrewed and cleaned the screen - it seems plugged beyond that - what else can I do? Is there tech.support in N.S.-   draci
Best Solution
posted on Sep 08, 2007
Helpful)
DiscoDave
Rank: Apprentice
Rating: 92%, 5 votes
I had exactly the same problem with my Gaggia Classic. Worked fantastic every day for two years then one day developed the symptoms you describe. I rang some Gaggia service agents and they all said it needs a service ($100-$150). The last one I called told me to descale it before bringing it in for a service as it was probably scale buildup. I told them it wasn't a gradual thing - it just suddenly stopped and they said what happens is the scale builds up to a point where a piece breaks off and clogs the pipeworks leading to the brewing head. So, I used the instructions outlined here: http://www.coffeemachine.com.au/descalin...
At then end of the second flush through the steam head, I closed the steam vale to try and push the descaling solution back through the brew head (just dripped through again) then left it for 10 minutes again. Did the same the third time and it went to drip again for about five seconds then bingo - burst back to full flow. Hope this helps.
Was this helpful?
Yes
No
Solution #2
posted on Feb 22, 2007
Somewhat Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Have you changed coffee beans? Some beans need a coarser grind than others. If this is the case, try a coarser grind and/or less hard tampering of the coffee in the portafilter. This should solve the problem, at least it did for me. Otherwise you probably have a pump problem
Magnus
Solution #3
posted on Nov 01, 2009
Very Helpful)
neiltonks
Rank: Apprentice
Rating: 100%, 2 votes
Hi, this is so easy to fix. Firtsly unplug the machine. Then remove the two screws in the top plate so that you can have access to the internals of the machine. You will see the red pump to the left hand side at the back. Remove the two screws that hold the pump in place (use a magnetic screwdriver so that you can pull the screws out). Pull the pump up towards you and then unscrew the thin plastic pipe at the top of the pump . It is the pump that has the scale build up problem. If you the put the water tubes into the water tank and hold a cup to the top of the pump to catch the water you then have to switch the pump on. You will then start to see lots of scale come out of it and the pump will pump more water than you are expecting so be careful. Be sure to cover the internals of the machine whilst you are doing this as you don't want to get water on the electrics and electricute yourself!!! Then rebuild it! Just svaed yourself £100 in having it serviced :-)
Was this helpful?
Yes
No
2 people thought this was helpful
Solution #4
posted on Nov 09, 2009
Not Rated)
janesymanski
Rank: Apprentice
Rating: 0%, 0 votes
For those in soft water regions it's probably not the pump, but rather in the heater.
  1. Switch on the machine and run the pump for a moment to prime the water path through the heater (where the coffee comes out!).
  2. Once water is through and dripping out stop the pump.
  3. Switch on the steam button. Leave for a minute or so.
  4. Switch off the steam and switch on the pump. A lot of steam and a bit of water will come out, stop when there's no more steam.
  5. Repeat from 3 several more times until water freely flow.
  6. Enjoy your coffee once more!
Was this helpful?
Yes
No
Popular Solutions for Gaggia Classic Espresso
Questions and Unsolved Problems for Gaggia Classic Espresso
Do you recommend Gaggia Classic Espresso Machine?
Answer
Answer
I have a Gaggia Classic coffee machine which I haven't used for some time. I filled the resevoir... (More)
Answer
HI. my problem stems from not enough water coming through the brewing head. there is a small amount... (More)
Answer
started up gaggia classic for the 1st time today. followed the instructions in the manual but when... (More)
Answer
I need to purchase a new Turbo-Frother for my Gaggia Classic coffee machine but don't know where to... (More)
Answer
Its brew very slow even without coffee, i clean it everything whats next? I think the pressure its... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Gaggia Classic Espresso...:
Top Coffee and Esp... Experts
Rank: Guru Guru
Solutions: 1582
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Coffee and Esp... Experts
Top Small Appliance Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
