Question about Sony Xplod 1100 Watt Max 10" Subwoofer, XS-L100P5W Car Speaker
Amp i have a 1100 watt sub what watt amplifier would i need?
  • 27 Answers
You could use a 2000 what amp
Posted on Dec 11, 2008
Are sony xplod 1100 watt 10'' subs 2 ohm stable
No keep on trying end blow everry thing up, Buy some real subs.
Nov 29, 2012 | Sony Xplod 1100 Watt Max 10" Subwoofer,...
Which amplifier i should use with JBL CS-1205T
this sub woofer tube has a rms rating of 275 watts... try using a kicker or orion 600 watt mono amp to run this. the brand name is what tell you about how good an amp is for instance the names i just mentioned rate their amp by standard play frenquencies where as other lower brand names rate their amps by the max out put on certain subs at certain frequencies which may lower their impedance and create more power although you will never play your sub at those frequencies. as for the max power of your sub of 1100 watts that is more than like only at a certain frequency so always only double your rms rating of your sub to find max power handling.
Jan 29, 2011 | Sony Xplod Amplifier XM-SD51X - Class D...
I got 2 1100 watt sony xplod subs powered off a 1000 watt sony xplod amp, everything works fine i just wanna make sure this will be ok and the amp or subs wont blow or fry.
you can blow a sub out when they are overpowered as well as underpowered. Distortion is the main reason thing go out. distortion occurs when you have the volume n the head unit up all the way and the gains on the amp are up all the way. always make sure the bass plays clear and you should be okay
Jun 14, 2010 | Car Audio & Video
I have a dub2502 amp with the red protection light on and will not go off. The amp is a 1100 watt peak amp @ 4 ohms and my sub is an Audiobahn 1100 watt peak, 4 ohm. wired perfectly. so how do I fix the...
The unit will need to be repaired by a technician. Most likely you have a bad transistor that is causing the protect mode to turn on. The only way to get the protect mode to turn off is to remove the bad part.
May 04, 2010 | AudioBahn DUB Mag Audio DUB2502 Car Audio...
I would like know whether a sony xplod subwoofer can be connected to my alpine car audio system! xplod sub woofer is 1100 watts.
Deffinitely but wired directly would be pointless, the Alpine's internal amp is way to weak to get the best out of the sub. You need an amp, minimum 300w and bridge the outputs to give all the power to sub preferably switched to low-pass (most amps will have a high / low pass switch)
Dec 07, 2009 | Alpine CDA-7892 CD Player
Amp big enough for speakers
No amp is too big, you can turn the gain down. Anyway in my experience people tend to blow up their subs with underpowered stuff anyway (power spikes from clipping). Your amp is rated at 11000watts max and will probably only put out 500 or 600 watts RMS - RMS by the way is the number you should go by. It indicates the usable output w/ out lots of distortion. On the flipside you can power high wattage subs with an underpowered amp and be just fine. However if you wish to extract the most you will need to match amps and subs. A good example of under powered sub applications is in some of my work- I built a wall of nine 12" subs in a bronco, we competed in a 50 watt class and cleaned house taking first in class. Another would be a 150x2 watt amp driving two 15" CV Strokers (1200 watts each). I was going to compete in that class but they made me move up becuase I was an installer at the time. I was upset at first but after my first try I was able to get about 146db and went on to take first anyway. So if the enclosures are built right you can still use that kind of setup. I hope this was helpfull. If you are concerned with exact wattage ratings the manufactures websites should list them. Good luck.
-Dynami
Mar 28, 2009 | Sony Xplod 1100 Watt Max 10" Subwoofer,...
Is amp big enough for speakers
To run 2 subs, the amp would be a little small. The subs will run OK, they just won't be very loud.
It's usually better to compare and match up the RMS power rather than the peak power. The Sony XS-L10P5B sub has a peak power handling figure of 1200 watts, but the RMS is 300 watts. The Sony XM-ZZR3301 monoblock amp puts out 1100 watts peak, but only 330 watts RMS. They would work great together, 1 sub, 1 amp. But if you add another sub, each one would only be getting about 165 watts. They'd work OK, just not as loud as they could be.
Hope this helps!
I have 3500 watts of subs total of 1100 rms what size amp should
Make shure your running thick guage wire like 2-0 guage wire to get correct power to it also and check on amp the ohm's it can handle to make shure your not running to makny ohms.
Jan 12, 2009 | Car Audio & Video
Sony Xplod 1100 Watt Max 10" Subwoofer, XS-L100P5W Car Speaker Logo
136 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
