Question about RCA RC5215P DVD Player
Wrong Format I recently purchased the Simpson Season 1 DVD. Disk 1 kept giving me the message about the disk not formatted to my player. I took it back to the store where I purchased it and exchanged for a new one. Now disk 2 says it not formatted for my player. Is there anything that can be down to fix this?
  • 3 Answers
I have a feeling this might be a region issue. If your DVD is the correct region for your country (check it against this list)
1: United States, United States Territories, Caribbean, and Canada
Europe (including British and French territories), Japan, South Africa, and the Middle East
Southeast Asia
Latin America, Australia, and New Zealand
Russia/Eastern Europe, Central and South Asia, and Africa (except Egypt, South Africa, Swaziland, and Lesotho)
6: China
(7: unused)
8: airlines/cruise ships
then your DVD-player might not be set up properly or may be faulty. Have a look at the settings and make sure the correct region code is set up in your player. If you find a "0" as the region code it means your player can play all regions.
Posted on Jan 21, 2018
SOURCE: Can't view DVD's burned from the tv on a DRC8335 RCA DVD recorder
If you do not finalize the disc then you can not play it back. Go back to your instruction manual and look under 'setting options'. There should be a choice to 'finalize disc before ejecting'. The recorder will not finalize a disc until it knows when you are done recording, so you have to tell it somehow.
Posted on Jan 06, 2008
SOURCE: I have a dvd recorder/player Rca DRC8052N
What I did that worked flawlessly was press setup on the remote, go to general and go down to restore. Hit Yes to restore factory settings and all is well. :) You should now be able to play all of your region 1 discs with no issue. This is using the RCR192DA1 Remote with The RCA DRC8052 DVD Recorder.
Hope This Help!
Posted on Apr 19, 2008
  • 463 Answers
SOURCE: problem with DVD/VCR RCA DRC8335
More than likely the DVD drive in your unit is bad.
Posted on Feb 27, 2009
  • 2002 Answers
SOURCE: It says "Disk error" on any disk. It won't read disk
turn off and, unplug your DVD recorder remove the six screws holding on the top tilt the back of the top up disengage the front of the top and set it aside look for a small laser tag this will point to a 1/4 inch glass lense this is the laser taking rubbing alcohol on a q-tip gently clean the lense with a twirling circular motion
Posted on Apr 28, 2009
  • 4 Answers
SOURCE: Can't Record, wont read blank DVD
This Recorder won't work with High speed DVD Media.You need 4x or slower Media
Posted on Sep 03, 2009
Why is my dvd player always saying wrong disc
When it says wrong disk there must be a reason why. To test the system, you should put in a bought DVD, not one you burned yourself on the computer. If that DVD does not give a message, you know the player is 100%.
What could be wrong with self made disks?
First a normal DVD has a silver or gold layer to reflect the light coming from the laser. A disk you can burn yourself, has a dye, which changes colour when the laser burns its info. It ls less and less reflective, compared with the silver or gold plated ones.
Then when you have burned the DVD's from your computer, with a video format, other then the DVD format, most DVD players can't play that. There is only one DVD format and there are hundreds or different (not with DVD compatible) video formats, you can play on computer and MP4 players.
I hope this is enough info for now.
Apr 19, 2015 | Spectroniq PDV-70X
Dvd player unlock codes
This can indicate a bad disk or a disk not recorded in DVD format, you can check the disk status and format in your computer with DVD drive and a player software as VLC.
Aug 16, 2014 | JVC Televison & Video
My 2004 tahoe z71 overhead drop-down dvd player message dish format error is that means my dvd player is bad need new one or something i can do to fix i?
Hello there and welcome to Fixya :
No there is nothing wrong with your player the message you are receiving is telling you that the format of the disk is of the wrong format and the player can not play that type of format.
Normally when a disk is coppied it is done in a certain type of format whether it be wmp or mda or somthing like this there are several different types out there. so if you have a player that takes only a certain type of formattted disk you will need to format the disk to that type of format before it can play. ok
Hope this helps i can help you more if needed ok
Best regards Mike
Oct 30, 2011 | Car Audio & Video
When i insert a blank disk i get cannot format disk message
sorry that you getting this message......... but the ch-dvd 300 is not a recording only plays recorded DVDs
May 08, 2011 | Cyberhome CH-DVD 300 DVD Player
Wrong disk
try cleaning your disk player with cleaning disk see what format your dvd player is set for chage to region 1 N America or whatever region you are in
Mar 20, 2010 | Coby TFDVD5000 Portable DVD Player
Formatting disk
You should not format a dvd-r disc as it is a record once disc and formating is a recording function. The message "use a +r/rw" is telling you that the system will only recognise a + disc and not a - disc.
May 29, 2009 | Televison & Video
Some DVDs will play and some won't.
I learned that the first few season of West Wing were recorded in a different format. I bought another DVD player ($30) and they work fine.
Apr 05, 2009 | Sony SLV-D370P DVD Player/VCR
Cant transfer footage from Canon DC201 onto computer (and eventually internet) Do I need specialist software to take video from DVD to computer?
You don't need specialist software to take video from DVD to computer.
One of two things has gone wrong
1. Your PC cannot read the -R DVD format, or, more likely
2. You have not finalised the disk.
You must finalise the disk in the camcorder before putting it in the PC. To finalise the disk you must have the power adapter connected to the camera, plugged into a wall socket and turned on. Then go to the main menu, select 'disk operations' and you'll see an option to finalise disk. Don't move or shake the camera whilst the finalising step is underway.
Once finalising is complete, put the disk into the PC.
Mar 09, 2008 | Canon DC210 DVD Camcorder
Disk problem
There is a website out there dedicated to just Cyberhome equipment. if you do not see anything pertaining to your system, register as its free, and leave a post.. I hear they get alot of assistance there. Good Luck Please do not forget to rate this thread.
Dec 10, 2006 | Cyberhome DVR 1600 DVD Recorder
RCA RC5215P DVD Player Logo
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
