My thomson DTI6300-16 red light keeps flashing
On Dec 3 whilst looking at the program guide I chose a chanel to watch and pressed OK. Then the unit shutdown ans the power light started to flash. I have lelt the unit powered down for 3 days also left the unit on for a day but with no sucess. On searching the internet I have found a number of people have suffered the same fault arround the same date.
Can you help or do I bin the unit.
Cheers
Bill C
  • 15 more comments
  • Anonymous Dec 13, 2008
    Found mine with the red light flashing on 11/12/08
    1yr and 1month old
  • George L Dec 15, 2008
    My Thomson DTI6300-16 has the same problem, On Tues 2nd Dec whilst checking the recordings, the screen went black and a FLASHING RED LIGHT on front of box.It doesn't respond to the controls so I rang Top-up TV who said they were aware of this problem but have no fix for it at present!! they told me to continue calling them to see if they find a cure to fix it !!!!
    I've had this approx 10 mths and bought it new from a trader called 'dti store' on ebay
    Has any body else had this and fixed it?
  • Anonymous Dec 27, 2008
    this is exactly the same as ours, same date and age. was this built in to ensure we buy a new one?
  • Anonymous Dec 29, 2008
    My DTI 6300-16 developed the same fault. I have turned power off overnight but still it does the same. Does it mean the end for my unit or can it be rectified. My unit is 1 year and one month old. My in laws have the same unit but no problems yet, but will that one go the same way?
  • Anonymous Jan 04, 2009
    Bought my thomsons digital recorder in april 2008. On december 30 the red light began flashing. Switched it off for a while, plugged it out and then plugged it in again but the red light continues to flash.
  • eccoboy Jan 08, 2009
    Just experienced the same problem with my Thomson DTI6300-16 too, tried turning it off, unplugging it for 10 mins still to no avail, if this is a common fault then Thomson need to do something about offering a replacement or a solution. Has anyone got any advice at all about how this can be rectified before I go down this route?
    Cheers BB
  • Anonymous Jan 12, 2009
    Yeah, same here only mine happened the day after the warranty expired, which leaves me thinking it is a dowloaded fault or pre programmed, as many people have the same problem but thomson just say they do not yet have an answer.
  • Anonymous Jan 31, 2009
    mines done it too, bought second hand, cant stop it flashing!
  • julie Chambers Feb 06, 2009
    My DTI 6300-16 has developed the same fault and it is exactly 1 year and one month old. This happened tonight. DONT BUY THIS HEAP OF ....... so fed up because i record a lot of tv and im to skint to buy another one.................Wont by thomson again....
  • lisacutler Mar 05, 2009
    I have the same problem as everyone else on here with the flashing light. Had for one year and one month when it went wrong. They gave me several options to try by switching off, holding buttons etc to no avial. The lady said if that did not work it was the hard drive that had gone. Ive got a friend on the case at the mo as good with computers etc, any luck i will let people know, but have a feeling it will be going in the bin.
  • caister79 Mar 11, 2009
    Identical! One year and one month to the day! Have tried the usual rebooting over various lengths of time from one minute to 30 minutes with the dtr switched off with no success. Am now trying with it off overnight. Bought mine off fleabay and have pinged off an email to the seller. Hopefully will get some kind of response.
    Why does Thomson not have a website/contact details? The instruction manual doesn't offer any help of this kind either - that seems strange.
    Will post with more info.
  • caister79 Mar 13, 2009
    Update:
    http://www.topuptv.com/help+centre/setup...
    "If after powering on the box from the mains socket a front
    panel lamp constantly flashes red and remains in this condition after
    some 5 minutes or so then try powering off and on again at the mains.
    If this condition persist (sic) then the box may have encountered a fatal problem.
    In this case, please call 08444 159 159 and a member of the Technical Team will be happy to help."
    NB Calls cost about 5p/min apparently - I've yet to ring them (haven't got hours spare just yet) but have sent an email requesting a step by step guide for this specific problem. Doesn't look promising though does it?
    Update:
    Got the chance to ring...
    You need to use options 1 then 4 then 1 again when you ring (saves listening to all the automated messages)
    If and when you speak to someone they'll ask if you are a subscriber (to TUTV) (I'm not and never have been - I haven't had the chance to catch up on my own recordings let alone something 'extra' like TUTV or TUTV+Movies).
    They gave me two options
    1. Buy a refurbished unit for £49.99 (Not one that has previously suffered FRLOD I suggested)
    2. Have a 'free' unit but subscribe to one of the two extras above - £9.99pm and £14.99pm respectively.
    Apparently there is no known cause for the FRLOD and it can, and does, happen at anytime - which they are implying that the number of 13 month occurrences on these forums is coincedence.
    I don't think this is a definitive answer but hope you can use this info - however you like.
    Good luck
    ps For fifty quid I might get another...
  • IanMConnor Apr 04, 2009
    The Amber light is supposed to come on for about a minute before it changes to red. At this point it can be switched on. Now , after about a year, the amber light just flashes constantly. Is this the same problem you are talking about ? I've opened the box and looked inside. I've removed the hard drive and plugged into my pc. The drive is ok. I am wondering if the unit has overheated. I removed the fan and tested. The fan is working. I need a miracle to get this thing working, HELP !
  • miss_wheeler Apr 19, 2009
    I have the same problem. I have read that it can be restored to factory settings. How can I do this?
  • MalcLong Apr 20, 2009
    Yep DTI6300-16 did the flashing red light last night. I've extracted the hard drive & it appears fine. Write-ups on the 'net talk of forcing it to re-format its hard drive. These had the file system as NTFS/FAT32, but mine is all LINUX ext2 partitions (there are 3 of them). The only thing that looks strange is one of them is 100% full - could that be the issue? I've copied the files using a windows utility to read the LINUX files just in case I can play the AV files (file extension .TRP which is a type of MPEG2 for TV recording apparently). Am going to try to force the unit to re-format itself.
    TopUpTV wash their hands of it although there appears to be a lot of people getting the same only a short time after a recent software upgrade - connected?
  • Anonymous May 01, 2009
    I too have the Thomson DTi6300-16 box with the flashing red light. It happened on Tuesday 28/04/2009 at about 22:30 just after I managed to delete a recording from the library and then the light started flashing. Nothing I do seems to work. Tried the TOPUPTV help desk and was told that the software was corrupt then I was cut off without getting a solution to the problem. Anybody out there got any (polite) suggestions
  • 4 Answers
There is a known power supply fault on Thomson boxes. If you go to www.satcure.co.uk you`ll be able to order the parts needed. Be aware, you`ll have to be able to use soldering irons etc. as this requires you to remove components and refit new ones.
Posted on Aug 20, 2009
Liebert gxt2-10000t230 low batt,bypass light flashing,no output,shutdown after a minute
Test outlet power by switching the unit to manual bypass and breakers off.
If power is supplied OK and the filter board repaired OK then restart the unit starting with the breakers supply to unit,battery confirm the display is on and static bypass led also on then switch back the bypass knob to normal and press the on button to switch the unit to normal.
Give the batteries time to charge 12hours then you can test the unit on backup mode.
Nov 25, 2014 | Liebert (GXT2-10000T230) (GXT2-10000T230)...
I have a Panasonic PT-52LCX66 television that I bought just over 4 years ago. I have replaced the bulb for the second time just 3 months ago and now the set will just shut off after about 3 minutes of...
Tv making and have clicking sounds as tv shutdown as lights flashes?Yes.The board that call the Ballast board might be dying and dead soon.This Ballast board job responsible only are to ingnite the tv projection lamp only.
Jun 30, 2011 | Panasonic PT-52LCX66 Projection Television
How do i change the time on my polar f6 watch
5.1.3 TIME SETTING
If you start from the Time of Day display, repeat steps 1-3, page 38.
4. Press the / buttons to select TIME. Press OK.
5. Press the / buttons to select 12 H or 24 H time mode. Press OK.
If you chose 12 h mode, select AM or PM with the / buttons. Press OK.
6. Set the hours with the / buttons. Press OK.
7. Set the minutes with the / buttons. Press OK.
Nov 25, 2009 | Polar F6 Wrist Watch
I need the code for the philmore pm-rc1a so i cant watch my tv!
Try this as most remote controls work the same when manual setting.
Here you go. This will work with most all universal remote controls. If you don't have the code do the following:
Automatic Programming
With automatic programming, the remote control tests all the codes available on the Code List and assigns the correct code for the selected device. Although this method can be more time-consuming, it eliminates the need to look up codes and enter them manually.
1. Turn off the device with which you want to use the remote control.
2. Press and hold the corresponding button on the remote control
(TV, VCR, SAT, DVD, CAB or AUD) until POWER INDICATOR illuminates. It should take a couple of seconds for the light to remain solid. The remote control is in programming mode.
3. Press and release power button. The POWER INDICATOR flashes once and stays on indicating the unit is in Power Scan mode.
4. Press CHANNEL up or CHANNEL down repeatedly until the device turns on.
5. When the device turns on, press OK to store the code.
Note:
• To exit without storing the code, press BACK.
• T he unit will search for the next code or the previous code if you press
CHANNEL up or CHANNEL down after the device turns on. (go slow you need to press OK when the TV turns on) if you mess up turn TV off and start over.
6. Press any other button. If the device responds, the remote control has been programmed. If the device does not respond, repeat steps 2-5.
Fill free to ask me questions about anything..........................
Sep 28, 2009 | Televison & Video
Lost remote to portable dvd player
Any universal remote will work. Just look on the back of it to make sure it supports your brand. That's the key. Just follow the directions for manual input. It will work something like this.
Note:
Sep 24, 2009 | RCA DIRECTV Satellite Remote Control
Unable to find a code for an admiral tv NO.GOJ
Most universal remotes work the same. Try this.
Note:
Sep 23, 2009 | RCA 3-Device Universal Remote
Cannot find manual. need to program menu
Hi and welcome to FixYa,
The user manual for a Brookstone 538744 is available here. It is in pdf form and would need Adobe Acrobat Reader to view the file.
Good luck and thank you for using FixYa.
Jun 25, 2009 | Brookstone 538744 Remote Control
I want to find the Sky remote code for this Tv.
Just got an LG 42LH2000 and code 0206 works
May 16, 2009 | LG Televison & Video
Not turn on i do not have 24v. Was watching TV for three hours when I was finished the set would not turn off from either remote or front panel. Unplugged unit and left overnight. When I plugged the unit...
Good Day,
The most common problem with this Model is the Caps on the Main Board, but to make sure pull the codes. Follow this procedure:
This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the input/device and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source) 1. MAY BE INTERMITTENT, SELF-DIAGNOSIS ERROR 23 OR 24. CHECK SOLDER CONNECTIONS AT CONNECTOR "DY" ON THE YOKES. 2. SHUTDOWN AT POWER WITH SELF-DIAGNOSIS ERROR 23 OR 24. CHECK C411 2200 UFD 35 V AND C412 10 UFD 50 V, BOTH LOCATED ON THE MAIN PCB. Good Luck, big IRISH.
Aug 24, 2008 | Mitsubishi VS-50605 50" Rear Projection...
Beko wma 1715 pre wash led keeps flashing manual says contact service engineer
Turn power button off (not at wall)
Select 90 degree wash
Press Start and Cancel button down at same time for 3 seconds and turn power button on whilst still holding buttons down - Start light will flash.
Leave power on.
Select any Spin position.
Press Start and Cancel button at same time again for 3 seconds - other buttons may start to flash - if they do, press Start and Cancel button together again for 3 seconds.
Machine should be re-set ready for use.
All we need now is for the rain to stop
May 04, 2008 | Washing Machines
Televison & Video Logo
1,335 people viewed this question
Top Televison & Video Experts
