Laptop shutting down by itself
Laptop shuts off for no reason
  • Julie Heinricy Jan 02, 2009
    Mine shuts off and somtimes it will even come up and then shut off. Sometimes the screen only shuts off. But the lights are still on.
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 87 Answers
Your CPU chip may be overheating and/or your screen backlight may cut out as well. This is common of the VAIO PCG-F series Laptops.
Disconnect the power from your laptop and remove the battery.
To repair this issue, you must feel comfortable to solder SMD components and have such solder equipment as well as watch makers screw driver tool set. You will also need some copper shimming material, about 1-2mm thick and thermal grease/paste.
Eye piece Magnifier is useful as well.
Over time, the thermal contact material SONY used shrinks. It shrinks between the CPU chip and the Heat sink, effectively impeding the cooling efficiency of the fan/heat sink.
Clear indication for that is the Fan runs at full speed all the time.
Carefully open your laptop, (be sure you are ESD safe) and carefully remove the keyboard to get access to the CPU/heatsink.
Remove the heatsink and notice the white sponge material between the CPU and Heatsink is likely no longer making physical contact.
Fabricate copper shim to desired size and install the copper shims instead of the sponge, make use of the thermal grease on both sides.
Reinstall the heatsink.
To fix the LCD backlitght, carefully remove the 4 rubber thingys in the corners of the screen, and open the screen.
On the lower side there is a slim Board wrapped in some plastics.
Carefully remove this board, remove the plastic wrap and look at the soldering spots on the Ferrite Transformer. They may be cracked and need resoldering. Resolder as needed and reinstall the board.
If you do not feel comfortable to do this, then find someone who is.
Perferly a technician with experience in such fields.
Good luck
Posted on Jan 10, 2009
My E5430 laptop will not reboot - tries to and then shuts down
Can you boot into diagnostics without it shutting down? Try it while plugged in and the battery removed.
Jun 25, 2014 | Dell Latitude E5430
Laptop keeps shutting down
There are a few reasons, bad power supply adapter, cooling fan is not working or there is dirt blocking the ports causing it to shut down, battery issues, "remove to verify" the DC jack in the laptop has become intermittent and must be dismantled down to the motherboard level and flipped over for solder touch up.
Apr 14, 2012 | Dell Inspiron 1525 Laptop
My lenovo g460 shut down while playing games
hi, happens on my msi, notebook too. if you have 2 graphics cards and one is nvdia. disable the nvdia card in device manager. there has been problems with this card causing shut downs.
Nov 03, 2017 | Computers & Internet
Tv remains on for about 20 minutes then shuts off by itself and won't come back on. please help
does the power indicator blink when the set shuts down? If so thats an error code let me know the number of blinks and I will assist with the reason why the set is shutting down.
Jan 20, 2012 | Sony BRAVIA KDL-52W4100 52 in. LCD HDTV
Toshiba Satellite a135-s4527 shuts off itself. And when I restart, I'm getting black screen right after Toshiba logo. It starts eventually.Anything I can do?
you dont say how long it was runnig when it shut off,,nor did you say if or not it shut off again after you eventually got it giong again,,,,a lappy will generally shut down for no reason if the cpu gets hot,,this is caused by the amount of dirt and dust in the cooler fins and fan,,,
Jul 17, 2010 | Toshiba Satellite A100-S8111TD Notebook
MY laptop some times shut down itself ecspeciali when i'm on the net When i swich it on again i'v got a message the windows was not shut down properly because of securyti reason probably some body was...
Usually when it shuts down for no reason it is overheating. Very common. There error happens when windows doesn't do everything the normal way when it shuts down such as save all your settings and so on. When it restarts it finds an error and you get that message. Again very common.
With your hand feel the bottom of the latop. If it feels hot not just slightly warm thats your problem. You need to have the cooling fan and passages cleaned out. You can use compressed air or a vacuum to do this. It takes very little dust on some models to make them overheat. If you have pets or use gas to heat your house or use the laptop near the kitchen you may have to do this about twice a year.
Jul 09, 2009 | Toshiba Computers & Internet
Dehumidifier keeps shutting itself off.
For some reason it is overheating and shutting itself off. There is a law that all electronics are supposed to have a point to where it automatically shuts off if it gets too hot from a malfunction or loose connection in the circuit board. It is to protect the consumer. You either need to take it to a tech or get rid of it. Get a new one.
Sep 13, 2006 | GE AHG40LA Dehumidifier
Computers & Internet Logo
1,658 people viewed this question
David Payne
David Payne
