Question about Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet chirping
Washer works fine with no error codes. When the machine is not running and the display is off. I will occasionally chirp once at random times. I unplugged the machine and it still chirpped about two more times, then was quiet for the night. Any Ideas?
  • 15,935 Answers
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 21, 2010
Fh error code wirpool duet washer
Display shows F20 or FH - Front-load washer ' Whirlpool ...
https://www.whirlpool.com/...fh-front-load-...
Whirlpool Home AppliancesQuestion: Display shows F20 or FH - Front-load washer. Answer. Image. or. Image. or. Image. This error code indicates a water supply problem. Are both the hot ...
whirlpool duet error code FH - Appliance Repair Forum
forum.appliancepartspros.com > Appliance Repair Help > Washer Repair
Jan 5, 2009 - 10 posts - ‎1 author
... Repair Help > Washer Repair » whirlpool duet error code FH .... FH No water detected entering machine or Pressure switch trip not detected. Whirlpool Duet diagnostic code C:03 error code FH
1 post
Dec 5, 2014
Whirlpool Duet Washer HF Error Code
Jun 10, 2013
FH Error Code on Whirlpool Duet Washer
Mar 11, 2013
FH error code
Sep 13, 2008
More results from forum.appliancepartspros.com
Stumped on error code FH for Whirlpool Duet front load washer .
Jan 08, 2016 | Washing Machines
Chirping sound on duet steam even when unplugged
There might be some cloth which is stuck inside it machine
Apr 13, 2014 | Whirlpool Washing Machines
My washer ( Whirlpool Cabrio M: WTW6500WW) will not start, cancel, rinse nothing! I can't even properly diagnose it because every button I press gives me an error chirp?
it sounds like you have a bad touch pad,try unplugging the machine for a few minutes to see if it resets the board,i would call the factory on this,they've been having problems with this and they might give you the part for free but you'll have to pay for the labor.
http://www.repairclinic.com/PartDetail/Touchpad-and-Control-Panel/W10070060/1202650
this could be the problem
Mar 29, 2013 | Whirlpool Cabrio WTW6600SBT Top Load...
Washer display code F05 what is this code?
the f5 error code is to do with the water inlet valve not working it will need replacing in the mean time try connecting the cold water to the hot select hot wash and see if the water flows into the machine
Dec 10, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My kenmore washer showes sud code
If it is similar to the Whirlpool duet,
Try using less soap (hi eff machine)
try using more fabric softner
to clear the occasional Sud warning, I run the machine on "quick wash" with no detergent/additive. gives it two more quick spin cycles in 30-35 minutes, usually clears it.
Jul 14, 2010 | Kenmore Elite 45986 Front Load Washer
F-02 error code on whirlpool front loader duet
F/02 Long Drain
If the drain time exceeds 8 minutes, the water valves are turned off and "F/02" is flashed.
NOTE: After 4 minutes the "Sud" error will be displayed, then 4 minutes later the F02 error code will be displayed.
Press PAUSE/CANCEL twice to clear the display.
  • Check the drain hose and make sure it is not plugged or kinked.
  • Check the electrical connections at the pump and make sure the pump is running.
  • Check the drain pump filter for foreign objects.
  • If the above does not correct the problem, replace the pump
Mar 27, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Mdl GHW9150PWO Washer stops
HI. this code represents a Long Drain issue.
If the drain time exceeds 8 minutes, the water valves are turned off and F02 is flashed.
NOTE: After 4 minutes the “Sud” error will be displayed, then 4 minutes later the F02 error code will be displayed.
Potential Causes
• If the above does not correct the problem replace the pump
Oct 16, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washer won't power or fill.
What no warranty might need a new board you should call a service provider
Jul 28, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Sport ~ E28 Error Code
serial communication error between central control and motor control.
Check connections at ccu (top front right corner) and mcu (bottom by motor), check belt drive for wear.
Did motor run ? Any other codes in diagnostic? (any one modifier button 4 sec on 4 secs off 5 times.) F codes are failures and C codes are portions of test cycle(automaticly run)
Apr 28, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
94 people viewed this question
Dan Webster
Dan Webster
Sal De
