Question about HP PSC 1610 All-In-One InkJet Printer
Hp printeer not recoginizing paper
Our printer keeps telling us it is out of paper.
It worked and then did not. We made sure that there was nothing foreign in there......
    Sergeant:
  • 399 Answers
The printer needs servicing.as the sensor which detects the paper is moved from its orignal position or getting blocked due to some dust.
Posted on Dec 06, 2008
Message in the screen add paper
The best thing you can do is read the manual first, it explains all these things. Just in case: That is telling you to put more paper in or it will quit printing. Try these links:
Canon printer says its out of paper when there is paper
The printer keeps saying its out of paper and its not not sure if paper is... My printer says paper is jammed when it isnt HP Printer keeps saying to add paper but it in
May 30, 2016 | Office Equipment & Supplies
How to fix CM2320 MFP PAPER JAM
if you don't find nothing inside printer and you are SURE there is no paper inside machine try to clean or replace pickup roller, if you wanna be sure about that try to print from Try1, if it work the problem is in try 2
Aug 28, 2014 | HP Laserjet CM2320nf All-In-One Color...
I'm getting an error code Illegal attribute value on my hp 4050 printer
Nothing to worry about. It just means that you have printed a page or pages that all the trays do not have the correct paper size. Say your trays all have A4 papers and you printed a PDF document (US letter size) downloaded from America. Printer prints the page, then print another page with your error message just to tell you your pages do not match the papers. This is HP PCL6 code. A Postscript printer driver will just refuse to print if page size mismatches and keep the user wondering why.
To avoid the message, just make sure that your documents have the same page settings as papers in your printer trays.
Nov 26, 2013 | Computers & Internet
Mt HP Photosmart C6380 keeps wadding up the paper and gets jammed. It then says out of paper and when I clear it and press OK, it crinkles the paper to death. Please tell me how to fix this. There is...
Hp printer paper jam error message is displayed by the printer when paper is jammed in one or more locations. In such a case, users are recommended to remove the jammed paper from the specified location. The entire paper path must be checked for any pieces of paper. To stop the message, open and close the top most cover of the printer. Lastly, verify the flags and the sensors. If the problem persists, the cause of the error message could be a broken sensor or sensor lever.
Nov 09, 2010 | HP Photosmart C6380 All-In-One InkJet...
Printer keeps telling me I have a paper jam but theres nothing inside
Hello there No harm in tring this could do the trick.
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Also clean The purge unit, called a spittoon assembly in an HP, Lexmark, Caonon and other inkjet printers, is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing.
That is where you'll find the print head assembly parked on top of it.
It also has an electrical pump to milk the print heads and test for ink flow.
So clean all under where the heads are parked and on IP6600D models you can take out the heads just by clipping them out, and then clean well.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
May 10, 2010 | Canon PIXMA iP3500 Printer
I have an HP DESKJET 3930, its install and everything is ready, but it wont print. the light keeps blinking and i put paper in. I had it stored for a while until i got a new computer but know that I...
unplug printer & power cables, replug in
take cartridges out, put back in making sure sure nothing is obstructing the ink dispensary on the cartridges and that they're clean
look in the printer where the cartridges go, making sure nothing is blocking the ink getting into the printer
check the rollers to make sure no paper is caught inside the printer
turn on printer and try this
hope this works and good luck
www.hp.com
Apr 30, 2010 | HP DeskJet 3930 InkJet Printer
Photosmart C309a series Printer (brand new) will not print
check the Tray. there are markings on the tray that tell the printer what paper is loaded, if the tray isn't in the percise location of type of paper, you'll get that error message. If that isn't it, then check the sides of the tray and see if there is any damage. sometimes the tabs on the trays that tell the printer what paper is in it, get broken. If that isn't it, then look inside the printer where the Tray goes in, and look for damage, or bent metal feelers that rub against the tray,
Oct 01, 2009 | HP Photosmart Premium C309A All-In-One...
HP Photosmart c5280
Make sure to check all the way to the right and left inside. I ussually find paper loose in either of those ends. Then check your encoder strip which is the plastic strip that the carriage slides on. This may be dirty causing this issue. Use a soft paper towel and alcohol. Windex is okay to but may leave streaks on it and give same issue.
Dec 09, 2008 | HP Photosmart C5280 InkJet Printer
Samsung CLX-3160FN printeer
Sure. You can download it here.
Please don't forget to rate this as fixya. Thanks.
Jul 06, 2008 | Office Equipment & Supplies
Paper keeps feeding
Just started happening yesterday to my HP printer as well....a virus maybe?
Jan 25, 2008 | HP Photosmart 2610 All-In-One InkJet...
HP PSC 1610 All-In-One InkJet Printer Logo
26 people viewed this question
Ben Johnson
