Question about Nokia N-Gage QD Console
Insert sim card message
When i turn on my n-gage phone i get a message to insert my sim card but my sim card is already inserted. I have tried several different cards and batteries and i still get the same message. What could be the problem?
  • Anonymous Feb 13, 2008
    my N gage nokia always complain insert sim even when there is sim in it
  • Anonymous Mar 04, 2008
    my n-gage qd is not turn on (startin problem)
I got problem with my phone n-gage,after i turned my n-gage on..itssays "insert sim car"..i already put my sim card inside of it
Posted on Sep 12, 2009
Where the sim card slots into there are 6 gold points get a small amount of wd - 40 and clean the points with it. this worked for me
Posted on Feb 17, 2009
    Scholar:
  • 113 Answers
It seems like the phone is not reading the sim. It has nothing to do with your sim or battery. But you may try this: 1. After inserting the sim card into the slot, fold a piece of paper (thick enough so that when you close the cover some pressure is applied on the sim) so that its approx the size of the sim (dont make it too thick or the cover won't close). 2. Put the folded paper right on top of the sim and load the battery. 3. This is just a trick which works. 4. If this doesn't work, please get the phone checked from a Nokia service center. Please revert back with the results.
Posted on Mar 02, 2007
Insert sim card
Do you want to insert other network sim or if your Blackberry Curve 8350I displaying insert sim card,if already sim card inserted.Don't worry i will help you.You can insert other network sim card in the phone by unlocking the phone from current network lock.To unlock Blackberry Curve 8350I use unlock code.Visit the site Wickedunlock.com get unlock code and unlock it easily.Then insert any GSM network sim card.If the phone displays insert sim card even though sim card is already in the phone.Please remove the sim card and replace it correctly.It is because the phone didn't detect the sim correctly.After inserting if it is display invalid sim or sim not valid message on the screen.It is locked to some network,you need to unlock it.To unlock use unlock code.Get code from online site and unlock it.
Jul 30, 2013 | Blackberry Curve 8350i
My phone shows "please insert
You could try to remove your sim card.
Install battery and turn on phone without sim card.
Use phone without sim card and do some operations.
This will check if you phone is working correctly.
Turn phone off and install sim card.
Made sure sim card is install correctly.
If this does not work, it could be the sim card is bad.
Jan 15, 2011 | Cell Phones
When I turn on my phone I get message: insert SIM card, but my SIM is already in the phone?!
Try inserting another SIM, your current SIM might have a problem. You can try a friend SIM. Hope this will help you. Thanks for using Fixya.
Jul 18, 2010 | Sony Ericsson K700
Insert sim card
Is the sim card new? Sounds like its damaged or non-compatible with your service provider/phone.
Sep 12, 2009 | Nokia N-Gage QD Console
My lg phone
There are several reasons for this message. Has your sim been activated by your servide provider? If not, you must call them.
Has your sim expired or been damaged in some way? If so, it must be replaced.
Have you inserted the sim correctly? The gold contacts of the card must be facing down, and the cut corner must be facing out of the card slot, pointing to the right hand side.
Do you have the right sim for your phone's cellular service provider? If your phone is locked to one provider you can't use a sim card from another provider, unless the phone is unlocked.
Hope one of these helps!
Aug 04, 2009 | LG Vu CU920 Cellular Phone
Says insert sim card when there is one in it
"Insert SIM" message is normally displayed on phones when a SIM card is not inserted on power-on or it does not detect the SIM card inserted.
Likely Causes:
  1. No SIM card inserted or inserted SIM card is damaged
  2. Inserted SIM card not positioned well in such a way as to make contact with the corresponding contact bridges on phone.
  3. Phone locked to a specific network and can only work on other networks when the firmware version is "flashed", that is completely changed to an unlocked version.
  4. The phone might be faulty (try with another good SIM, if you still get thesame message and its not one of the above reasons... it might be a transciever problem or the phone's SIM card slot's pins might be defective).
cheers.
Apr 30, 2009 | Sony Ericsson Walkman® W880i Cellular...
Sim card
Sounds like phone is locked or firmware is bad
Mar 15, 2009 | Motorola Mobility RAZR V3
Insert SIM Card message in nokia 6080 though SIM is inserted
May be its detecting your sim card properly. Check your sim card in another handset. Verify if its the propbelm with sim card not your handset.
Nov 26, 2008 | Nokia 6080 Cellular Phone
Insert Sim Card
WWATER GO INSIDE TE PHONE REMOVE BATTERY BLOW IT
Sep 16, 2008 | LG KG800 Cellular Phone
Motorola Razr says insert SIM card when it's already in there
You May Have Fryd Ur Sim Card Did U Try Puttin It In Any Other Phones Besides The Other Model?
Jun 14, 2008 | Motorola Mobility RAZR V3
Nokia N-Gage QD Console Logo
723 people viewed this question
Top Nokia Video Game Consoles & Games Experts
matt
matt
Arizona Information...
Are you a Nokia Video Game Console and Game Expert? Answer questions, earn points and help others
