Question about HP DeskJet 660c InkJet Printer
Has power but doesnt do anything
My DeskJet 660Cse has power but doesnt do anything. I cant even run the self tests or diagnostic. When I try to print from my computer it says printer is not connected.
    Problem Solver:
  • 17 Answers
I would probably want to try a new/different parallel interface cable. If that doesn't work, I would strongly recommend purchasing a new printer. The DeskJet 600-series models are Jurassic Park stuff.
Posted on Mar 01, 2007
I have a 2009 Porsche cayenne S, the window washer doesnt work and there is no motor soundj. The voltage meter on the dash doesnt work and the dipper beam warning light is on
Hi before you do anything I would run a diagnostic check on it first I wouldn't go changing anything until you get it checked first hope it helps.
Sep 02, 2015 | 2009 Porsche Cayenne S
Why does my HP Deskjet F4280 Show an E in the Start/Copy screen??
Regarding your recent inquiry about the HP 60 cartridge error message ("E in display window") and inability to print with your HP Deskjet F4280 printer, this type of error is normally associated to an electrical connection issue between the printer and the cartridge, or more likely, an internal micro-electronic failure inside the cartridge itself (please note that it is very rare for both ink cartridges to electrically fail at the same time). An electronic failure of the cartridge would be unrelated to the ink cartridge refill process; these same failures can (and frequently do) occur with brand new ink cartridges.* To help identify the root cause, please run the 'Tap 41' cartridge's electrical / diagnostic tests below (refer to B. and C), this will identify which ink cartridge is causing the issue:
NOTE: Unfortunately, alignment pages and internal self test prints will usually print Ok even if the cartridge is internally electrically damaged. Do not use these test pages as a proxy for determining whether a cartridge is good or bad, only the 'Tap 41/43' diagnostic test report can yield this information.
As a temporary workaround, or if you are unable to determine which cartridge is causing the issue, remove one of the ink cartridges from the printer....this might place the printer into the 'single cartridge printer mode'....print jobs may then be executed from the computer (only):
An internal electrical failure of a cartridge can be confirmed by performing the following corrective/diagnostic steps:
A.Ensure BOTH carriage/flex cables and BOTH ink cartridge contacts are thoroughly clean before proceeding: http://inkjet411.com/?page_id=1519
B.Validate the cartridge's electrical health by running the 'Tap 41' diagnostics test. Refer to DIAGNOSTIC TAP 41 video procedure at the following link on how to activate and read the service test:
http://inkjet411.com/?page_id=440 (HP 60 - Deskjet F2400/F4400/F4500 models)
    1.While holding the Power button, press Cancel (X) button 4 times, then press the Color Copy button once.
    2.Release the Power button.
    3.The 'Tap 41' diagnostic test print should print.
    http://inkjet411.com/?page_id=444 (HP 60 - Deskjet F4200 model)
      1.While holding the Power button, press Cancel (X) button 4 times, then press the 'Resume' button once.
        --- Providing the color cartridge is partially functioning the Tap 41 diagnostic test print will be printed (this is a forced service print test which is mainly used for the evaluation of ink cartridge electrical health). A good HP 60/60XL color cartridge should display 1248 good nozzles, while a good HP 60/60XL black ink cartridge should show 336 good nozzles. If the results yield anything different then the ink cartridge is likely damaged and will need to be replaced. Refer to 2nd video on how to read the printout.
        ---- If the printer attempts to print the diagnostic test pattern (1 page) then the printer is generally considered operational and functional, if nothing is printed, but the printer attempts to print the pattern, then the tri-color ink cartridge is either empty, clogged or severely electrically damaged (black ink cartridge is not used). You can remove the tri-color cartridge, reactivate the tap 41 test and the printer will print the diagnostic test print in black ink.
For any additional questions please contact us directly: Inkjet411help@gmail.com
To purchase the lowest cost ink cartridges available in the USA (remanufactured in the USA) please visit: http://www.inkplicity.com/
-Thank you
Aug 14, 2014 | HP DeskJet F4280 All In One Printer InkJet
Hp 4480 how do you unpause it
The HP F4480 likely has a malfunctioning ink cartridge which is causing the printer hang (i.e. internal micro-electronics damage inside the HP 60 color or black ink cartridge). You can verify the electrical condition of both HP 60 ink cartridges by activating the Tap 41 diagnostic test report (see video here for complete instructions):
    For additional support please visit http://www.inkjet411.com
    -Thank you
Dec 09, 2013 | HP F4480 All-In-One Printer
HP Deskjet 5650 - Troubleshooter keeps saying paper is low or out.
How to use the solutions in this document To resolve the issue, try each solution in this document, and then use the steps in this section to print a self-test report. This step determines if the product hardware functions correctly. When you have resolved the issue, and the product successfully prints a self-test report, there is no need to continue troubleshooting. Print a self-test page Follow these steps to print a self-test report.
  1. Load plain paper in the paper tray.
  2. Press the Power button (c01602202.gif ) to turn on the product.
  3. Press and hold the Power button (c01602202.gif ).
  4. Press the Resume button (c01678098.gif ) four times. The self-test page prints.
c01733891.gif IMPORTANT : Try to print a self-test report after every solution even if the solution resolves the issue.
Mar 28, 2013 | HP DeskJet 5650 InkJet Printer
HP R732 FLASH DOESNT WORK
Try to run self-diagnostics tests - press flash button, while turning on the camera. One of the tests checks the flash functionality.
Nov 28, 2009 | HP Photosmart R707 Digital Camera
Cant i run a stand alone self test on my deskjet
o check printing capabilities, print a Self Test Report. In order to print such a test follow the next steps:
  1. Turn the printer on and place media in the tray.Set the width adjusters to fit tightly against the sides of the paper in the tray.
    1. Press Power button while opening and closing the printer access door four times.
    2. Release the Power button.Your printer will print a test report.
Oct 28, 2009 | HP DeskJet 3740 InkJet Printer
Says printer out of paper but it is not - won't feed
Try this: turn the printer off This document explains how to perform built-in internal tests on HP Deskjet 3650 printer. The internal tests can be used to verify that the printer's internal firmware is functioning properly. The tests do not verify that the computer and printer connections are working properly. Running a diagnostic test
  1. Turn the printer on.
  2. Press and hold down the POWER button.
  3. Open and close the top cover four times.
  4. Release the POWER button.
NOTE: When running the test on an HP Deskjet 3600 series printer it may be helpful to use a pen or pencil to hold down the Power button.
Oct 04, 2009 | HP DeskJet 3650 InkJet Printer
I have HP deskjet F4288 ,print is not comming.
Try printing a self-test page... to do that please follow below instructions...
Printing a self-test page Follow these steps to print a self-test page from the control panel. Make sure paper is loaded correctly in the product before beginning the procedure.
  1. Press and hold the power button (c01346625.gif ), and then press the cancel button (c01361518.jpg ).
  2. Release both buttons. The self-test page prints.
Thank you.....
Jan 29, 2009 | HP DeskJet F4280 All In One Printer InkJet
Self diagnostic test codes
anytime you do the self-diagnostic you will almost always get those 2 codes.
12 - direct power input to the PCM has been disconnected within the last 50 key-on cycles
55 - End of error messages
Dec 27, 2008 | 1997 Mitsubishi Eclipse
HP DeskJet 660c InkJet Printer Logo
100 people viewed this question
Clive
Clive
