Question about Sony Handycam DCR-TR7000 Digital Camcorder
Camera goes into alarm yellow flashing arrow,can't reset
The camera went from cold to hot. I read that this could be a moisture problem. I left it open to dry out. I hit the play button and it stills goes into alarm with a yellow flashing arrow and C:31:22 in the right hand corner. My son is wrestling in a tournament and would like to use it today.
  • 62 Answers
Well once the water damage has been done it cant be resolved. you have to buy another camera
Posted on Apr 01, 2009
I went out after very cold winter, wont turn over multi flashing lights in dash, including right and left arrows, I bought new battery because it was fur years old and still not fixing problem
Hi Shawn, gazing into my crystall ball the Harley Gods are telling me that if you have a security alarm with FOB you need to do a reset or alarm overide. So I will post those websites first. If you don't have a security alarm I will give you a checklist and it's corresponding website:
https://answers.yahoo.com/question/index?qid=20100903124902AAsvdFY
Harley Davidson Security Alarm Setting PIN Override The Garage Harley...
And the usual suspects are:
1.Ignition/Light Key Switch not in IGNITION position.
2.Engine Stop switch in the OFF position.
3.Discharged battery, loose or corroded connections (solenoid chatters).
4. Bank Angle Sensor tripped and Ignition/Light Key Switch not cycled to Off and then back to Ignition
5. Starter control circuit, relay or solenoid faulty.
6. Electric starter shaft pinion gear not engaging or over-running clutch slipping.
09 Streetglide wont Start Harley Davidson Forums
Good luck and enjoy the video:
May 05, 2015 | 2011 Harley Davidson FLHX Street Glide
TPM is alarming every 30 seconds since the weather went cold. How do I silence the alarm..... I know how to reset the TPM but that doesn't work.
Cold weather causes air to condense and air pressure to be reduced, causing your tires to read low pressure to the TPM. Check and fill all your tires to your recommended vehicle inflation pressure, to stop the TPM from alarming you every 30 seconds.
Feb 04, 2011 | Lincoln Aviator Cars & Trucks
2006 sebring 4 cyl - in cold weather security alarm goes off whether i have it left unlocked - use key to unlock or fob - every morning it goes off - yesterday - when i was leaving work - went to unlock...
I know a quick fix to get it started but you might think i'm crazy to do this:
My 2003 Dodge ram van 1500 does the same thing. I put a small heater on the driver's side floor blowing the hot air toward the door.
I plug in the heater when I get home from workand let it run all night.
The computer for the alarm is under a kick plate near the driver's door next to the driver's seat on the left side. Once it warms up the alarm; it will shut off the alarm and you can start the motor.
Jan 06, 2010 | 2006 Chrysler Sebring
What does the yello camera with the yello
I have an S1000fd and to get rid of the yellow camera icon with the exclamation mark next to it I pushed the button on the side of the flash to pop the flash up. Its a low light level indicator basically.
Aug 10, 2009 | Fuji FinePix S1000FD Digital Camera
Fisher price kid tough camera shows red-yellow-green light icon with an arrow on the red. Also the flash icon (lightning bolt) is showing in the bottom left of the screen. Emptied memory and changed...
We had the exact same problem. We transferred the photos off of the camera and then it went away. So possibly it is a memory full error or a card read error. I am not sure but the transfer solved the issue.
Jun 23, 2009 | Fisher-Price Kid Tough Digital Camera
Olympus 1030 sw -Flash doesn´t work anymore
Have you tried to reset the camera to the factory defaults? To do this: have the camera in shooting mode - go to Menu - left arrow to reset - press ok - Highlight Yes and press ok. This will reset the camera to factory settings. See if flash works now.
Feb 11, 2009 | Olympus Mju 725 SW Digital Camera
Keep getting 10.00.03 supplies error, have tried turning the machine off and on several times.
10.00.03 - The printer cannot read or write to the yellow print cartridge memory tag.
Solution:
Turn the printer off and then back on again.
If error returns, remove all print cartridges and turn off the printer.
Cold reset the printer:
Turn on the printer.
Watch the control panel.
When the memory starts counting, press and hold the green (Select) button.
Continue holding the green check button until the Ready, Data, and Attention lights flash once, and then stay on steady.
Release the check button when the Ready, Data, and Attention light are on steady.
The control panel will display SELECT LANGUAGE.
Press (Down Arrow) button once. The control panel will display COLD RESET.
Press (Select). The printer will perform a cold reset and then continue its power-on sequence.
Wait for the printer prompt to install each print cartridge.
This should return the machine to operating condition. If you still get the error, replace the yellow print cartridge.
Jan 15, 2009 | HP LaserJet 4600dn Color Printer
Olympus Stylus 710- no flash mode
I;ve been on the internet all morning researching the same problem. It appears it's a curcuit related problem with the flash. As of know, haven't got a solution other then buying another camera or taking paictures in manuel mode without flash.
Nov 25, 2007 | Olympus Stylus 710 Digital Camera
Alarm went off
I just had the same problem (second time in about two months this has happened). I went to the manual, as recommended, and they had this helpful bit of information:
Q. What do the numbers mean on the digital display when
I press the “Test/Reset” button?
A. The numbers you see when you press the Test/Reset button
are NOT a CO reading or a Gas alarm. This is a simulated reading
the alarm displays as it tests its electronics. The numbers displayed
when the Test/Reset button is pushed should be between
100 to 400 (usually around 200). These numbers are shown after
the “Gas” test is complete.
Then later, they give another helpful tip...if the system does not work as described, replace it immediately. Good advice. I wonder what manufacturer I'll try this time. Repeated false alarms render these things utterly useless.
Oct 17, 2007 | Kidde Nighthawk Combo Gas/co Detector
Sony Handycam DCR-TR7000 Digital Camcorder Logo
242 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
