Question about Samsung RS2630SH Side by Side Refrigerator
No chilled water
There is water passing through the valve low down at the back of the fridge when water dispenser is activated but it dosen't reach the spout at the front, like wise the ice maker has stopped working.
  • jozekzebrack Dec 20, 2008
    no chilled water
    as per service technician fridge was switched off for 36 hours and chiled water delivery restored but unfurtunately only for another day and then "got frozen" again. somebody experienced same ??
    Genius:
  • 1,122 Answers
REPLACE THE DUEL WATER INLET VALVE ON THE BOTTOM BACK OF FRIG.-,SEARS .COM- PARTS,MIKE
Posted on Dec 06, 2008
Ice maker works but no water out of water dispenser?
Hi
You have not supplied the make or model of your fridge and so I can only offer a generic response.
Most ice-makers, chilled water dispensers are reliant upon a water stop valve that make a distinctive click when operated.
Does it click when you dispense water?
If not, then assuming the ice dispenser works (indicating the activate button is working), then the water valve has possibly failed (or less likely the wiring somewhere in between).
Dec 15, 2013 | Refrigerators
My Amana french door/bottom freezer is leaking water. Did the procedure with hot water the drain in back of the freezer, although it seemed clear of ice. That didn't help. The leaking stops when I...
Two possibilities:
1. A cracked plastic tube. These will leak whenever there's a call for water - either the chilled water dispenser, or re-filling the icemaker tray (two seperate tubes). Pay particular attention to anywhere the tubes are clamped to the chassis; anywhere they're routed near or under the refrigeration unit; and near the solenoid valve - especially if there's a tight loop in the tube there.
2. A bad (leaking) connection where one of the tubes exits the water valve. Again, these will leak whenever the valve is activated.
Those plastic tubes don't last forever. I've replaced many of them for the same symptoms. They're known to simply deteriorate with age.
Manuf's make good money selling replacement tubing kits.
Aug 15, 2011 | Amana AFB2534DE Bottom Freezer French Door...
Water is leaking from our water dispenser. A large amount. An 8 oz cup fills up within an hour. It is coming from the water dispenser on the outside of the fridge. The ice maker is working fine but the...
Your water valve on the back of the refrigerator is plugged up, there are two sides to it, one side is for ice maker the other is for chilled water dispenser.You may be able to clean it out, if not then you will have to buy a new valve.Hope this helped.
May 29, 2011 | Kenmore Refrigerators
Water dispenser does not dispence water
need to replace the water inlet valve. the part number for this model is 4389178
Jun 18, 2010 | KitchenAid Superba KSRG25FK Side by Side...
Ice maker is on but is not producing ice
The ice maker is probably not getting water. Have you heard the water valve click on and off to allow water to flow to the ice maker? If you get chilled water from the fridge, the ice maker's water valve will probably sound very similar to when you dispense chilled water. Try the water to listen for it. Then, listen for it over the course of an hour or so to determine if the ice maker is doing the same thing. If you hear it - then there may be a blockage in the line or filter.
If you don't have provisions to get chilled water from your fridge (ice only) or notice that you can't get water from your fridge any more: Make sure the water supply is on and.. that supply line isn't kinked or got crushed when the fridge was pushed back into position. This is a pretty common occurrence. If you don't hear any water valve clicking, the valve itself may have failed or there may be a problem with the electrical circuit. Hopefully, you won't have to got beyond this, but if so - let us know.
May 24, 2010 | GE GSS25LGM Side by Side Refrigerator
No cold water
  1. Make sure filter is installed right.
  2. Disconnect water line see if water is flowing from line. May have a water valve in line not working.
  3. reconnect line but leave lose open inline valve just a little see if water flows out. No water PSI may be to low to reach up to fridge or valve stuck closed.
  4. Got water to connection tighten check dispenser for water.
  5. No Water If your system has a reservoir to store & chill water Your float may be stuck locate & check unstick if needed.
  6. Still no water May have faulty dispense value. Check value replace if needed.
Please rate hope this helped. If I can help further I'll standby.
Mar 09, 2009 | Samsung RS2534 Side by Side Refrigerator
No water from dispenser
Frig is set too low of temp Water is freezing in tubing chill coil
Jun 07, 2008 | Electrolux 25.9 Cu. Ft. Side-by-Side...
Whirlpool water dispenser not working model ED25RFW00
It is possible that you have an airlock in the chilled water section but not very likely. I would be more inclined to suspect that the water storage section in the fridge compartment (below salad section) has become frozen as I have experienced this before. I would suggest defrosting the cabinet completely and trying again, ensuring that you push the water valve for a long enough duration. Hope this is of some help.
Mar 13, 2008 | Whirlpool ED2FHEXN Side by Side...
Water dispenser not working but making ice
GW, the valve on your refrigerator is actually a "2-in-one" kinda setup. One water line comes in, but splits at the valve to perform the separate functions, chilled water and ice. It's called a dual coil valve... one coil for each function.
Generally speaking these are the Achilles heels of the plumbing system. The easy way to check it is this... pull the fridge away from the wall, have someone get behind it down where the water line goes behind the cardboard cover to listen. Now have someone try to get water from the dispenser. If you hear the valve energize and get no water, you have a bad valve assy. (You'll hear a low "hummmm" at the valve when it's energized)
Replacement is easy. The part number is 2315533 and lists for about $45.00. Turn the water off, remove the cover from the lower rear, remove the valve. Remove the tubing and electrical connectors and install on the new valve, then reassemble. All you'll need is a 7/16" wrench and a 1/4" socket or nut driver.
If you don't hear the low hum I mentioned, remove the cover, reach in there and touch the valve's mounting bracket and have your helper try to get water again. You should feel the bracket vibrate slightly. If so, see above.
If the valve makes no noise and doesn't vibrate, we'll have to look deeper. Let us know what you find.
Oct 23, 2007 | KitchenAid Superba Architect KSCS25INSS...
Samsung RS2630SH Side by Side Refrigerator Logo
139 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Richard Roth
Richard Roth
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
