Hello. I am running vista home ultimate 64bit. Manually I am unable to create a restore point. Error message 0x8004230F unexpected error for shadow copy provider. I have check in the computer management console and the service is running. Can you help?
    Problem Solver:
  • 11 Answers
Sometimes, Windows Vista Ultimate 64bit will not allow to create a restore point as it is self scheduled to create its own restore system restore points.
To over-come this: turn the system off, press the on button and keep pressing the F8 button to get into Safe Mode. Once you are in Safe Mode, go to the System Restore and then create a Restore Point. Once you have done this, shut down and restart the system, you will then see your restore point that you have created.
Hope this helps
PC Software Solutions PLC
pcsoftwaresolutions@techie.com
Posted on Dec 06, 2008
I am unable to back up with an error message saying 0x800704230F
Make sure that System Restore is activated on your computer. Some backup programs will not run unless it is.
May 08, 2014 | Microsoft Windows? Vista Home Premium...
System restore not functioning
Save your data and reinstall windows. Check your hard drive for defects.
Nov 24, 2013 | Microsoft Windows 7 Home Premium 64BIT...
Trying to Re-install windows 7. Got the following error: "The computer restarted unexpectedly or encountered an unexpected error. Windows installation cannot proceed. To install Windows, click...
So was this the issue then? You can run the Windows Vista Upgrade Advisor to see if there are any compatibility issues that you may be having with hardware or software that would prevent an upgrade to Windows Vista.
I hope this helps.
Mar 28, 2011 | Microsoft Windows 7 Ultimate for PC
My computer is not creating Restore Points... yes it's turned on... yes I know how to do a manual... but it disappears when the next Restore Point is created... can you help?
Creating a System Restore point using a shortcut For a more elegant way to create a System Restore point using Script in Windows Vista, check out our article Create System Restore Points Quickly using Script in Windows Vista and Windows XP.
Alternately, you may use the method below:
Copy the contents below to a Notepad document, and save it to a file name with .vbs extension (Example: createrp.vbs) and close Notepad.
set SRP = getobject("winmgmts:\\.\root\default:Systemrestore")
CSRP = SRP.createrestorepoint ("Created a Restore Point now", 0, 100)
If CSRP <> 0 then
Msgbox "Error " & CSRP & ": Unable to create System Restore point"
End if
Right-click on the Desktop and select New - Shortcut
Create a shortcut with the following target:
wscript.exe c:\scripts\createrp.vbs
Note: The above assumes that the createrp.vbs script is present in the c:\scripts folder. If that's not the case, change the Path accordingly.
Name the shortcut file name as Create Restore Point
Running the script To create a System Restore point, run the script with elevated mode. To do so, right-click on the newly created shortcut (Create Restore Point.lnk) and choose Run as administrator. When you are prompted for an administrator password or confirmation, type the password or provide confirmation. A System Restore point will automatically be created.
Nov 23, 2009 | Microsoft Windows Vista Home Premium with...
Error: 0xC004D401 an unauthorized change was made to windows The security processor reported a system file mismatch error.
I suspect a program or driver for a hardware device was just installed prior to this error. Best thing to do is to use Windows Restore and use a restore point dated before the first occurance of the error. You may need to repeat this process choosing previous restore points until system is back to normal or you have run out of restore points.
Here's how:
Startup computer and go into safe mode (Press F5 key as computer is starting up but before you see the Windows logo screen).
Open your Windows Vista Start menu, select All Programs, select System Tools, and then choose System Restore.
Use the System Restore Wizard to choose a restore point/date that was created before the error started occurring on your Windows Vista computer.
Revert your system configuration to this same restore point.
If error still occurs and you had other restore points, you can repeat process with older restore points.
If you have gone back several points and still cannot, you may have not choice but to do a full Windows restore. This can result in a loss of data.
If you get to this point, re-post here for instructs on how to possibly save data before doing a full restore.
Bret
1-2-1ComputerServices
Oct 07, 2009 | Microsoft Windows Vista Home Premium with...
Unable to create system restore point
GOOGLE found:
Run services.msc and make sure Volume Shadow Copy is stopped. Then locate and delete any System Volume Information folders on the root of any volume that was previously being monitored by System Restore. You may need to alter
Folder Options/View tab/Advanced in order to see these protected system folders. Reboot the system and retry turning it back on.
Best of Luck,
Rick Rogers, aka "Nutcase" - Microsoft MVP
http://mvp.support.microsoft.com/
Windows help - www.rickrogers.org
My thoughts http://rick-mvp.blogspot.com
May 30, 2009 | Microsoft Windows Vista Ultimate Edition
I am not able to create restore point
What errors you are getting? Is system restore enabled?
Mar 15, 2009 | Microsoft Windows Vista Ultimate Edition
Yahoo Chat Voice problem
Hey, try to right click the yahoo, select run as administrator. you can try another version of the program http://www.filehippo.com/download_yahoo_messenger/3153/
Nov 01, 2008 | Microsoft Windows Vista Ultimate Edition
Vista An unexpected error (1342140992)
I dont know what the error actually means.
But have you formatted the hard drive using NTFS.
Are you selecting the upgrade option.
To perform the installation follow the steps :
http://support.microsoft.com/kb/918884
Use the vista upgrade advisor whether your compter is capable of upgrading to vista.
Then start the installation.
Good Luck.
Live, Love, Laugh.
May 03, 2008 | Microsoft Windows Vista Ultimate Edition
Computers & Internet Logo
89 people viewed this question
David Payne
David Payne
