Question about Lexmark X73 All-In-One InkJet Printer
Paper jam for some reason everytime i print the paper gets jammed.what do i do?
    Sergeant:
  • 310 Answers
Can you tell me if the paper goes through squint?. if you turn the printer upside down and give it a gentle shake and see if anything comes out, i have removed pens, toast, and loads of other things that sometimes gets stuck inside. also have a look and see if you can find any jammed paper even if its only a tiny bit, this fixes 80% of the printers that comes into us. hope it works John
Posted on Mar 01, 2007
SOURCE:
Get Paper Jam everytime I print
its general problem with commen soln. just put the all pages properly & neatly in ur printer & turn on ur printer whenever u required & after finishing ur printing process turn off it everytime.Also dont give the fake printing commands it also affect ur printing process.
Dont turn off ur printer while process is running. its main reason of paper jam.
Aug 04, 2009 | HP Officejet Pro L7680 All-In-One Printer
False paper jam
Try cleaning the feed rollers with some alcohol on a lint free cloth. You may have some debris on the rollers.
Jan 31, 2009 | Lexmark P4350 All-In-One InkJet Printer
The paper jams up when the printer pulls it into print
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed throught the printer. The reason for this, in some cases I have been able to clear the paper track of debris that was deposited there over time. Worth a try. I have fixed a number of printers this way saving costly repairs. Bud
Jan 21, 2009 | Lexmark X4530 InkJet Printer
Epson RX500, Paper Jam - printing couldn't start
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button, applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this, is in some cases I have been able to clear the paper track of debris that was deposited there over time. Worth a try. I have fixed a number of printers this way saving costly repairs. Bud
Jan 06, 2009 | Epson Stylus RX500 All-In-One InkJet...
Re: Paper Jam
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Jan 02, 2009 | Lexmark X3650 Printer
Paper Jam Photosmart C3180
Jan 02, 2009 | HP Photosmart C3180 All-In-One InkJet...
Paper jams every time
does the same doc jam or all docs jam ?
on the first page or there after ?
Sounds like your printer may need a normal clean and service...
any decent printer repair company does this for a very reasonable fee...
Dec 08, 2008 | HP PSC 2210 All-In-One InkJet Printer
Paper Jam
Seems you have a dusty roller in the feed mechanism. try cleaning off the roller with some windex (or equivalent) on a towel.
Nov 18, 2008 | Brother MFC-9420CN All-In-One Laser...
Paper Jams and Margin Incorrect
Check the humidity of your paper, type and weight. Nothing more than 32# will run through the tray, any heavier should go through the bypass to prevent jamming. Margin follow the internal tutorial for moving your margins. Xerox machines do skew 3 degrees left for some reason or the rollars that feed from tray 2 need to be changed.
Peter
Apr 01, 2008 | Xerox Phaser 7750DN Laser Printer
Lexmark X73 All-In-One InkJet Printer Logo
88 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Clive
Clive
Thomas F. Schneider
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
