Use esata hard drive through my N Belkin router
I want to connect my esata external hard drive to my N Belkin router, so it's esata to ethernet any ideas?
    Problem Solver:
  • 8 Answers
Synology Inc has products that will do this
Something like http://www.synology.com/enu/products/DS207+/index.php
Posted on Dec 06, 2008
How can I get my Belkin router to read my Seagate storage device so that all computers in the house can access said Seagate storage device?
1) Turn off your wireless router and unplug the external hard drive you want to make wireless.
2) Plug an Ethernet cable to the "Network-attached storage" device, and the other end of the cable to an available Ethernet port on your wireless router.
3) Connect one end of the USB cable to the wireless router's available USB port and the other end of the USB cable to your "External" hard drive.
4) Turn on the both the Wireless router and the External hard drive. Make sure that your Internet connection is still working.
5) Insert the installation CD and run it on your computer. Follow the installation instructions and install any utilities related to your external hard drive. There may be special utilities provided for flash drives that are not needed for hard drives.
6) Create a login name and security password for the "NAS" device during the setup process. When the installation process is completed, you will now be able to use your external hard drive.
Apr 10, 2011 | Computers & Internet
Hi i have got seagate Go 500gb when i connected to my computer it say that insert a disk into your Usb .i would like to know how can i fix it
Can you give any more information? What kind of PC? Age of PC? How old is the external drive? is the drive new? Esata is different then USB. Make sure you are connecting to an eSATA port on the computer. Newer laptops usually have a shared eSATA and USB port.
Feb 10, 2011 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
My router works when connected as wireless, but when I connect an ethernet cable to this, it does not work. This is required as I am trying to connect a network hard drive via the ethernet connection.
Hi. I suggest you double check first if the ethernet cable you're using is a known good cable if yes then that should be on your router configuration that enables you to use the ethernet cable, so I think you need to contact your Internet Service Provider regarding this matter because by default you should have the access using the ethernet cable, and they'll be the one to configure your router. Hope this helps
Jun 04, 2010 | Belkin (F5D7230-4) Router (587009)
I have a Huawei EC 168 usb modem from alltel and would like to know if it can be used with my belkin N+ router
inorder to connect to the belkin router you should have an ethernet outlet from the modem...even if it is an usb modem, go ahead and check whether there is an ethernet port...if there is an ethernet port, then connect it to the MODEM port of BELKIN router using an ethernet cable...if no ethernet port is found then it willnot be possible to connect to the belkin router...
because belkin router has got only ethernet port for getting connected to the ISP...
pls rate me if its useful...
Apr 03, 2010 | Belkin Computers & Internet
Need documentation on how to attach WD PassPort HDD to Belkin N+ router using usb port on router ... to be accessed by Windows 7
Gather and connect all necessary connecting cables. You need an Ethernet cable to go from the box linking the hard drive to your wireless router in one of the open ports on the back of your wireless router, and a USB cord connecting your external drive to the storage link box (unless you are using a flash memory device or stick drive).Power up the devices. Make sure your Internet connection Is working and that the storage device is working properly.Insert the Setup CD into your computer. Follow the instructions and install any necessary utilities for the specific type of external drive you are using. Configure the storage link. During setup you should have been given the option to secure the device with a login name and password. Open the device and log in. Make any changes you want to on the storage device, but if you aren't sure what specific changes you want to make to the default settings, leave the default settings alone to avoid creating problems.
Mar 13, 2010 | Computers & Internet
How do I get my other computer connected with a Belkin N router(F5D8236-4)?
try to know the w/l setting of the belkin router and using the wireless utility u can connect the second computer
Feb 25, 2010 | Computers & Internet
Connecting a esata port to a sate external hard drive
I don't think there is a converter from USB to ESATA, but you could buy a new Hard Drive enclosure that has those options, but I am not sure if you are willing to take out the HD from the existing one.
Sep 09, 2009 | Iomega HDD External Desktop (32660) 80 GB...
My apartment receives its internet connection via ethernet from an external router. I had been using the Belkin F5D7231-4 as a wireless router (not configured as an access point) but recently it dropped...
You don't want to set a static IP address in your wireless router. You'll be connected to the network alright, but the IP address won't be recognized by the primary router. Thus, you'll see you're connected with only local access.
First and foremost, ensure that your Internet connection is valid. Plug the ethernet cable from the wall directly into your computer and test the connection. If you can't get it to work, then the problem is not on your end. Contact the agency in charge of the external router (e.g. apartment maintenance).
If your connection is fine hard wired, you may have bad data or a faulty configuration in your wireless router. I suggest doing a complete hard reset (there should be some instructions with your router on how to do it--some have a small flush mounted button that you have to press for a few seconds). Set up your wireless router as if for the first time. This should take care of your problems.
May 23, 2009 | Computers & Internet
ESATA Connection problem with My Book & my laptop w/ Vista
Had the same problem with a WD esata 1TB drive and an HP DV6 laptop. Using Vista home premium. Lots of experimentation BIOS settings and driver update, and finally fixed it by trimming back a couple of mm of the plastic shoulders on each connector of the esata cable. A few depth measurements and it became clear that the connectors weren't going in deep enough otherwise. The cable was a Belkin of reasonable quality.
No problems now, but the drive is only recognized if it's connected at boot-up.
The core of the problem is the external casing of both the laptop and the WD drive enclosure. They're thick and keep the cable connector from going in far enough. Perhaps manufacturers of the cables or the esata devices are sloppy, or the standard isn't specified well enough. I've seen pictures of esata cables that have significantly different dept.
May 14, 2009 | Western Digital My Book Essential Edition...
Computers & Internet Logo
2,704 people viewed this question
David Payne
David Payne
