Question about Epson Stylus CX5400 All-In-One InkJet Printer
Epson CX5300 Scanner error------>see your documentation
Tried re-installing the program and using the unlock tab, and nothing changed. The red light for error is still on. Any suggestions?
  • Epson Master
  • 541 Answers
Download this to reset your printer http://www.ssclg.com/epsone.shtml
plz rate me
Posted on Dec 06, 2008
Scanner error occurred please see documentation
turn the printer off, lift the scanner, make sure the transportation lock is in the unlock position, if it is in the lock position, toggle it to the unlock
Feb 11, 2010 | Epson Stylus Photo RX620 All-In-One InkJet...
My scanner
scanner error see ur documentation and callservice if necessery
Oct 21, 2008 | Epson Stylus CX3200 All-In-One InkJet...
Scanner error see your docmentation and call service if necessary
Please follow the steps below to resolve your issue.
1) Turn off the printer.
2) Lift the scanner cover.
3) Toggle the transportation lock five times, ensuring that it is in the unlocked position, towards the back of the scanner.
4) Turn on the printer, and the error should be cleared.
Jul 28, 2008 | Epson Stylus CX3200 All-In-One InkJet...
Help Epson CX3200
I just like to ask to where specifically you can see the red light. It will help us determine what cause the red light. To give you heads up as well, the Printer's LCD screen can help us determine what exactly the offline condition of the CX3200 is:
Error message: No color or black ink cartridge-->Press the Color Copy button to install a new ink cartridge.
Solution: The indicated ink cartridge is not installed. Please install the necessary cartridge(s).
Error message: Color or black ink out -- >Press the Color Copy button to begin replacing the ink cartridge.
Solution: The indicated ink cartridge is out of ink. You will need to replace the necessary ink cartridge(s).
Error Message: Ink cartridge error -- > Press the Color Copy button to begin replacing the ink cartridge.
Solution: There is something wrong with the ink cartridge. Make sure the cartridge is genuine Epson ink. Also, try reseating the cartridge (remove it, and then reinstall it).
Error Message: Paper jam or misfeed -- > Press the Color Copy button and clear the paper jam by hand if necessary.
Solution: Paper is jammed. Check for any obstructions under the unit's cover, and in the paper tray.
Error Message: Paper out -- > Load paper in the sheet feeder and press the Color Copy button.
Solution: Load paper in the sheet feeder, and then press the Color Copy button to continue printing.
Error Message: Scanner unit open -- > close the scanner unit
Solution: Carefully close the scanner and press it down until it clicks securely into place.
Error Message: Scanner error -- > See your documentation and call service if necessary.
Solution: Press the ON button to turn off the Epson Stylus CX3200. Unlock the transportation lock, if necessary. If it is already unlocked, toggle the lock back and forth, 5-10 times. Turn on your Stylus CX3200 again.
Error Message: Printer error -- > See your documentation and call service if necessary.
Solution: Press the ON button to turn off the Epson Stylus CX3200. Disconnect it from power, and then reconnect it to power. Press the ON button to turn on the Stylus CX3200.
May 23, 2008 | Epson Stylus CX3200 All-In-One InkJet...
Solid Red Light "Scanner Error-----See your docoumentaion and call service if necessary.
After working with Epson to unistall, re-install, and reset everything the red light still comes on. Epson, and confirmed by a repair dealer, said the light bulb on the scanner is bad. The dealer said it is cheaper to buy a new scanner. My unit still prints in b&w and color.
Nov 01, 2007 | Epson Stylus CX5400 All-In-One InkJet...
The red light is on and the message scanner error. tried turning it off and then on again after a few seconds the red light comes on again. Also check to see if the system was locked released that. Tried...
Try flicking the transportation lock (on the left side under the scan lid) on and off. It has a picture of a pad lock shown locked and unlocked. Flip it back and forth and leave it in the unlocked position.
This worked for me. Good luck!
Oct 15, 2007 | Epson Stylus CX3200 All-In-One InkJet...
Scanner error
Oct 07, 2007 | Epson Stylus CX3200 All-In-One InkJet...
Scanner not responding to preview scan
Try this as a last ditch effort. Remove the software. Reboot the computer and come off line. Disable the Anti Virus program. Now install the soft ware. Then try. If the red light still flashes then assume it is new scanner time.
Jul 26, 2007 | Epson Expression 1640XL Flatbed Scanner
Film option is ghosted
try to reseat (unplug and replug the TPU cable at the back of scanner, and open epson scan go to professional mode and click on configuration button, go to OTHER tab and press reset all then restart computer and try if film is an option to select.
Jan 15, 2007 | Epson Perfection 4990 Flatbed Scanner
Epson Stylus CX5400 All-In-One InkJet Printer Logo
1,230 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
