Question about JVC AV-36F802 36" TV
On timer light on
My On timer light is on and when trying to turn on the set it makes the usual on sound and a short delay then it clicks off and the on timer light is illuminated,
  • Anonymous Dec 05, 2007
    I've
  • cmperdomor Jul 20, 2008
    I have been trying to turn the tv on but the light of the on timer keeps lighting up and when turn on, it makes the sound but the screen stays black and turns off. Please help
  • 68 Answers
Do you see a horizantal line across the screen before the set goes off. if you do, you have a problem with the virtical ic. it has to be changed. let me know if you see the line across the screen and I will show you what to do
Posted on Mar 28, 2007
Hb51r manual
Plug in
make sure bulbs work
rotate dial to set choice of delay times
timer turns on at dusk,,, and delays off for amount of time you choose
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#outdoor
Gene
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Dec 13, 2013 | Intermatic Outdoor Timer/Photo Control...
Timer delay
It seems like defective control panel
Dec 08, 2013 | Indesit Washing Machines
When the occupancy switch model #IOS-DSIMF-WH is in auto-mode, and an additional light is turned off, will the switch turn on immediately or after a delay?
Try it and see what happens.
Occupancy switch turns ON immediately when receiving auditory or electrical signal depending on type of switch.
If you have the occupancy switch wired for 3-way, when more than 1 switch controls same light, then usually the wiring is set up so either switch can operate ... but if somebody just wired in occupancy switch and it was not set up for this specific application, then you have to try it and see what happens.
Mar 09, 2013 | Hardware & Accessories
Looking for instructions how to use Electric light Switch timers
Electronic timers are usually 7-day.
Usually a 24-hour timer has mechanical analog dial that rotates as time passes.
Copy following link for instructions by experimenting with features:
http://waterheatertimer.org/How-to-set-timers.html
There are many timers on the market today, including plug-in, box-type, timer modules, delay timers, indoor-outdoor timers, and knock-offs of each brand. Each has different watt load rating that usually appears on side of timer.
Some timers work with any type bulb, and others only with incandescent.
Copy following links to help identify timer.
http://waterheatertimer.org/Woods-timers-and-manuals.html
Jul 26, 2012 | Hardware & Accessories
I have a horn that sounds when my hay baler chamber is full. I am looking for a timer relay that will allow the horn to sound for 3 to 5 seconds and then disconect the circuit so it won't drive me...
DEI 528T appears to be 12Volt 'wait to start' or ON-delay timer.
528 receives electrical signal, and then delays the start-circuit by up to 60 seconds.
For example home alarm system. Door is opened and alarm sounds. Install DEI 528 and set for 60 seconds: Door is opened and alarm will not sound for 60 seconds.
You need 12-volt off-delay timer.
Off-delay timer receives electrical impulse, and then begins a countdown.
After countdown expires, then circuit turns off.
ELK-960 appears to have off-delay feature for 12V DC
http://www.homesecuritystore.com/p-423-elk-960-delay-timer-module.aspx
Use wiring diagram #7 for alarm cut-off:
http://download.homesecuritystore.com/downloadmanual.aspx?FileName=ELK-960_Install.pdf
Aug 25, 2011 | Directed Electronics Dei 528t Pulse Timer...
I am wanting to energize a relay for 3 min. then off, whether the power stay's on to coil or not! what I want to do is when a door rises and hits a switch I want to energize a coil for 3 min. whether...
You want 3 minute 'off delay' timer.
When timer is energized with push button or momentary electrical signal, circuit remains ON for set amount of time, and then turns OFF.
http://waterheatertimer.org/How-to-wire-Dayton-Off-Delay-Timer.html
Aug 15, 2011 Dayton/ Grainger website is offline
Most delay timers have 1 amp capacity rating, so circuit needs fast acting 1 amp fuse, and timer controls separate relay or contactor unless Load is equal to 100 watt light bulb.
3-minute off delay pin timer
Omron shows 120Volt 8-pin M-series-(minute) 3 minute delay timer
Part number H3CR-H8L 120volt M
http://waterheatertimer.org/pdf/Omron-timers.pdf
Example 240Volt timer showing timer and base.
http://www.sourcingmap.com/ah33-220v-030-minutes-delay-timer-relay-socket-p-119441.html
Wiring diagram shows on side of timer.
Aug 15, 2011 | Amperite Dayton Solid State Timer On Delay...
My interior lights won't go off
Fault in one of the door switches or if thre is timer delay for the lights to dim off then it is short in the control board of the delay switch.
First make sure all the four switches work before you can confirm on the delay timer.
Sep 18, 2010 | 2002 Ford Taurus
Not turning itself on and off. tigger are set clock is running. light are on 24 hours. model no T101 diana or shannon
1) The on-off tripper pins might be worn out. Buy new pins
http://www.grainger.com/Grainger/INTERMATIC-Timer-Tripper-2E054?Pid=search
Do you need new pins?
2) The manual override will click on and off with timer. Watch if manual lever is moving to OFF when timer is off ... and moving to ON when timer is on.
3) Timer might be worn out. Click manual override lever back and forth.
Is manual override loose? Or does it click crisp ON and OFF? This test would indicate general wear on timer. If manual override is loose or broken, the tripper pins may pass right over without tripping lever.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
http://waterheatertimer.org/images/WH-lever-005-500.jpg
http://waterheatertimer.org/images/Back-of-WH40-2b-500.jpg
4) If manual override clicks on and off with timer, and lights stay on, then there might be a short between timer and lights.
Test for short to ground. Turn off power. Inside timer box, disconnect ground wire going to light. Do not disconnect ground wire unless power is off. Turn power back on. If lights are off, then the wire going to light is bad, or a light fixture is bad.
Caution. If there is a short, do NOT touch light fixture when power is on.
Sep 17, 2010 | Intermatic & Indoor/Outdoor Rain Tight...
Vent axia SOLO PLUS SELV T fan has a delay timer fault
There is usually two pre sets; one for time delay before turning on and one for how long it runs for. Have a look
Sep 14, 2017 | Dryers
Indesit WIL103 flashing lights problem
because of the short time this runs then stops, there could be maybe 3 faults, 1 check water inlet valves and supply for water flow 2 check for any motor action (use another programme) 3 check heater element for open circuit number 1 or number 3 sounds most likely hope i have helped, if so rate me please
Sep 25, 2007 | Indesit W 123 Front Load Washer
JVC AV-36F802 36" TV Logo
67 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
