Monitor wont work
When I switch the monitor on the picture only lasts for about 2 seconds.
if I switch it on and off again it does the same thing
Can you help
  • 60 Answers
Hi can you try a different monitor to check if its the same or tv if its the same you know it the Graphics card  then you need to remove it and then try to reinsert it and drivers as well from disc or website
cheers
Posted on Dec 06, 2008
How to Fix display problems ( red display, or only for about 2 seconds display)
There are two problems, screen goes black after 2 seconds, red only. The problem is in the video processing board located on the back of the picture tube, it is well shielded against outside interference.
Apr 07, 2012 | IBM J156-1702 17 in.CRT Conventional...
Monitor screen is black. If I switch it off and on again it'll light for 1 second and then go off. I rebooted and it came on for 1 second each time the powering up screen changed.
The picture board on your monitor is bad, since it goes off after a second and the power led or button is on, it means the picture board of your monitor has developed fault.
The best thing for you to do now is to take the monitor to a local repairer within your vicinity to help with the replacement of the picture board.
Regards.
May 17, 2010 | Computers & Internet
Screen going blank on system boot and on switch off/on
It is the picture picture board on your monitor that is malfunctioning, since the power led or button is on, but the display screen goes blank after a fraction of seconds, it means the picture board of your monitor has developed fault.
The best thing for you to do now is to take the monitor to a local repairer within your vicinity or any service center to help with the replacement of the picture board because the fault is not something you can fix yourself, in order not to complicate issues.
Take care.
May 08, 2010 | Sony SDM-HS75 17" LCD Monitor
I have a samsung syncmaster t240 monitor. Boots up normally but the desktop appears for a brief time (1 second) then goes black. I used the torch technique and saw the desktop icons. When I switch the...
I believe the power led button is still on while the screen goes black, if yes, it means the picture board of your monitor is bad that is why it appears for a second and goes black after that
Since the power led button is on, It means the picture board on your monitor is faulty that is why it appears for a second and goes black.
The best thing for you to do now is to take the monitor to a local repairer or any service center within your vicinity to help with the replacement of the picture board because the fault is not something you can fix yourself in other to complicate issues.
Take care.
May 01, 2010 | Smart Modular SV3170A
Syncmaster 226CW showing picture only for a second + flickering
Call and get the RMA for your monitor, the problem is in the power supply and it will only get worse. This is a common problem with LCD monitors after 2-3 years of use.
Buddy
Corporate Computer
www.ccl-la.com
Oct 17, 2009 | Samsung SyncMaster 2233BW 22" LCD Monitor
Dell tv/monitor picture goes blank after 1 second upon power-up
The synchro transistor has died. The only option is to have it repaired. Just had it happen to mine, can't tell you thye cost yet though as I have a loan monitor while dell fix it. Of course they will find more than 1 item i bet. But a tch who works for samsunhg looked at it and told me it would need to have a new sync transistor. Because its dell he wouldnt touch it.
Aug 24, 2009 | Computers & Internet
My Sceptre X7 LCD computer monitor comes on at startup and goes black after about two seconds. I turn the monitor off and on again and the picture comes on foe about 2 seconds and then goes out again. The...
SORRY MONITORS R MONITORS THEY EITHER WORK OR THEY DON'T. WARRANTIES R THE BEST THINGS FOR MONITORS.HAVE U TRIED THE COMPUTER ON ANOTHER SYSTEM TO MAKE SURE YOUR VIDEO OUTPUT ON THE COMPUTER IS WORKING CORRECTLY
Aug 11, 2008 | Computers & Internet
IC POWER CM2017 LCD MONITOR
Normally when this type of problem happens, the first suspect would be the inverter board, then the filter capacitors and lastly the mainboard.
A defect in one of the lamps and faulty inverter IC may cause the display to shutdown as well. If the lamp is defective, it will send a feedback and cause it to stop producing output signal thus the display just shut off once you switch in ON.
Jun 24, 2008 | Gateway FPD2275W LCD Monitor
Phillips 170b monitor not working
Exactly the same problem here. Phillips 170B Monitor about two years old. Lights up for no more than 2 seconds then goes blank. Switch on/off and exactly the same thing. I suspect than the screen goes really dim rather than switching off because sometimes I can see the screen image very faintly.
Dec 31, 2007 | Computers & Internet
Dell E173FP - After sometime the screen switches off
Sorry not a solution - but I have started experiencing the exact same problem over the last month although sometimes, on switching on again, it will run for 10-15 minutes before the problem re-emerges. Initially I put it down to the v. hot weather in July but it still continues. So I would also appreciate any solutions!
Aug 06, 2006 | Dell E173FP 17" LCD Flat Panel Monitor
Computers & Internet Logo
37 people viewed this question
David Payne
David Payne
