Question about Samsung HT-Q70 Home Theater System System
Swa3000 I can not get my rear speakers to work with the swa3000. I have a samsung ht-q70 home theatre system. The blue light is on the swa3000 but no sound is coming out of the rear speakers. I have tried to reset it as the manual said to do but that did not help.
  • 7 more comments
  • Anonymous Feb 18, 2008
    reversed wires turned off both the tuner and the wireless unit
  • dwads82 Feb 24, 2008
    I have the same problem with the swa-3000! It worked the first time I used it, but now the red light comes on and no sound from the rear speakers! I have reset it several times like the manuel says and nothing changes!
  • Anonymous Aug 01, 2008
    Same here, red light stays on, din't even work once, dunno what to do?
  • Anonymous Sep 30, 2008
    same problems. I just moved my swa 3000 to another room and it now doesn't work wirelessly. Samsung support is useless. They've just suggested over and over to do what the manual says. Doing it 10x will not make it work!
  • Anonymous Oct 16, 2008
    Same thing Keep trying even unplugged it for a week and nothing
  • Anonymous Oct 30, 2008
    same here, the wireless wont sync and i cant get the rear speakers to work, no response so far from samsung on it
  • Anonymous Nov 02, 2008
    Did work - now red light stays on and won't connect to tuner. I've tried mulitple times to reset but nothing
  • Anonymous Dec 23, 2008
    My girlfriend swapped power points and now the redlight is on and no sound.
    What's the reset procedure? I can't see it in the manual..
    The manual did say it has a fuse in the power plug, but there's only a fuse in the sub plug.
    Judging by the problems everyone is having I'm not expecting alot of results, but if someone can post the reset procedure it'd be much appreciated.
  • Anonymous Jan 24, 2009
    Same problems. Nothing solves it. I've hit reset, tried to sync it, unplug, switch plugs, etc. It only stays on for a few minutes at a time. The blue light goes out and the red light comes on.
  1. With the home theater system off, press and hold the REMAIN button on the home theater's remote control for 5 seconds.
    Note: You can release the REMAIN button when the POWER LED blinks blue/Red depending on model.
  2. With the SWA-3000 turned on, use a ball point pen to press the RESET button on the back of the SWA-3000. The POWER LED in the front of the home theater blinks two times.
Posted on Dec 19, 2009
SOURCE:
Why wont my ht-e3550 play tv sounds
I have the exact same problem - I have connected the RCA cables but it's just not working....this is very frustrating. Anyone who has a solution - pls contribute! Regards, Justin
Mar 16, 2013 | Samsung Ht-E355 330W 5.1 Channel Home...
Everytime I turn my on samsung ht-q70 the display screen says protection and the system shuts off. what can i do to get the protection off
The amplifier has a bad channel, or is bad itself. It is trying to either output too much current or is not putting out enough. If you have multiple speakers wired to one channel, you will either have to change the wiring to series(unit positive to first speaker red, first red to second BLACK, second red to unit negative) or remove on speaker. (If this is the case, then you might want to look at this. It is a tip/rick to place and properly/successfully run three subwoofers, but the main concept can be used on all channels.) If all channels are wired to he correct speaker, then the amp is in fact at fault.
Jun 21, 2010 | Samsung HT-Q70 Home Theater System System
Samsung home theatre system HT-TZ422 - rear speakers don't work
I bought the system samsung HT-TZ 422 but wireless receiver module is not connected spikers or not riding tx card.Sound test system is show all spikers but from wireless module is not hiring.When can i get any hepl.
Thanks.
Marek.
Mar 01, 2010 | Samsung Audio Players & Recorders
I just want to know if I can connect my laptop to my Samsung HT-Q70 Home Theater System for audio so I can hear the sound from the laptop on my Home Theater speakers?
Yes you can and it is very simple. All you need is a special wire. One end fits to the earphone jack on the laptop, and the other end looks like rca cable. At the back of your home theater choose aux in, and connect the rca end of the cable to that. Then the other end looks like a headphone jack, and you connect that to the laptop headphone jack. Now on you home theater select aux. You will everything that comeout of that laptop including the windows vista melody when you first boot it up. Now you are ready to enjoy music.
Nov 23, 2009 | Samsung HT-Q70 Home Theater System System
How do i connect/play my turntable?
Hi sorry to say cant go direct.
What you can do if really want it running is get a RIAA pre amp with power supply (search google local shops). The turn table plugs into that, then that plugs into one of the analogue inputs of the Q70. That will work great if prepared for the effort!
Best of luck
Jul 22, 2009 | Samsung HT-Q70 Home Theater System System
Rear check message on HT-TXQ120 samsung home theatre
Looks like it is to do with the rear wireless speaker. Now, my problem is over. Its gone. I first turned the reciever on and then turned on the rear speaker wirel less on. No rear chk in problem now. Hope this helps. R.
Nov 19, 2008 | Samsung HT-TXQ120 Home Theater System...
The rear speakers and the center channel speaker do not work
Hi, maybe,like my HT-THX25, my book states that sound will only be heard from the rear speakers when in DVD 5.1 or Dolby Pro Logic 11 mode, peronally I would love to hear sound from any of my speakers when TV is on lol. Geoff
Mar 23, 2008 | Samsung HT-X40 System
1,481 people viewed this question
Top Samsung Audio Players & Recorders Experts
Mike Duncan
Mike Duncan
Marvin
Marvin
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
