Question about Refrigerators
Chescold caravan fridge 3 way fridge, (out on the bench not in a van) works well on 240V but not on gas. Pilot looks good, fridge is level, I have tried inverting the fridge as suggested. No luck. I can't understand why it won't work at all on gas. If it was jet size, I would expect it to at least get a little cool. Thanks, John Moore
Yep same prob as my Chescold model RC1180. I pulled the entire gas circuit apart as the fridge works well on 240v haven`t yet sussed the 12v.
I suspected the thermostat ( on the gas side ) there is a tiny jet on the side of the aluminium block at the base of the electric thermostat, also another springloaded 'valve' at the bottom of the aluminium block.The ' valve' is actuated by the thermostat Dial, as it screws a pin down onto a plate which departs from an O' Ring seal letting gas into the chamber where the tiny Jet is seated.This tiny Jet meters the gas to the Pilot burner.
Anyway ' That' wasn`t the problem! lol
The Problem was a 'Clogged Pilot flame Jet'
Fix..... I stripped as piece of fine electrical wire 12v and cleaned the jet out. It is a # 26.
The Jet itself looks like it has been 'Stamped' out rather than Drilled, this may account for some fridges working better on gas than others as there seem s to be some distortion on the Jet Orifice. I will buy a new Jet and a #26 drill and replace the original one.
I am just testing the fridge on Gas now...going like a Trojan... bonus is ive got a little 3 sausage hot plate over the Gas exhaust and am cooking dinner while the beer is getting colder !
K
Posted on Apr 12, 2009
I have acquired a finch b533g 3 way fridge but without instructions. Can anyone help with simple steps for 240v and 12v . The gas is covered by factory stickers. Thanks in advance
as this product is rather ancient, manual is difficult to obtain, i can suggest enquire in sports stores which still sell this product, manufacturer is obscure, but fridge itself is one of teh best and cheapest on the market! new one is sold for anything between $500 and $800. it was first manufactured over 25years ago... have friend which is still using it...
have short preview for it:
http://www.wholesalervequipment.com.au/chescold-portable-fridges/freezers/dometic-b533-575-12v/240v-33ltr-lpg-finch-fridge/prod_14.html
and i think this will be best manual for it:
http://www.google.com.au/url?sa=t&rct=j&q=&esrc=s&source=web&cd=8&cad=rja&uact=8&ved=0CGAQFjAH&url=http%3A%2F%2Fernie.awa.com.au%2FArticleDocuments%2F1168%2FUser%2520Manual%2520Memphis%2520TWF45L.pdf.aspx&ei=WwTaVKvxHZLd8AX5lYCgBQ&usg=AFQjCNH26A-FH7kUw55NIz3gZBzjHGezkQ&bvm=bv.85464276,d.dGc
hope this will help you - do not forget to vote...
Feb 10, 2015 | Refrigerators
Dometic rc1180 not cooling down on gas
clean all LP lines to ignitor if no clicking replace board
Oct 25, 2012 | Dometic Refrigerators
Why does my caravan fridge trip out when connected to 240v
The heater element is almost certainly to earth. Work it on gas until you can fit a new heater.
Jul 01, 2012 | Refrigerators
Hi,i have chescold rt50 fridge freezer,older model,colourbond brown colour,recently i have replaced the 240v element and the fridge work perfect again,at last camping trip i used on gas and work icy...
try disconnecting thermistor let run if cold replace thermistor if not bad board or cooling unit look for yellow stains on cooling unit or if you smell ammonia
Oct 13, 2017 | Dometic Refrigerators
Chescold rc1180 users manual
It appears that your brand branches off to many first name brand's like=> Chescold RC1180, 50 litre, 3 way, (12v,Gas,240v)
Here is the user manual=>
Combi Box 3 Way Fridge & Freezer RC1180
sea_breeze_111.jpg Caravan's Plus
RC 1180 EGP Fact is I could see so many different versions I am leaving you with a few extra divisions of Dometic. Should you need more answers please let me know, Thanks, Sea Breeze Please rate this solution. Sea Breeze
Mar 13, 2011 | Dometic Refrigerators
Fridge wont get cold with gas
This is worth a try. Disconect the gas and power make sure the pilot light is out. Turn the fidge unside down overnight then unright again. Try it on gas agian. This worth a couple of goes before giving up.
Aug 30, 2009 | Thetford Norcold N323 1.7-cu ft 3-way...
Is it possible to put a 3 seater bench in second row
Yes...you can. I did this in my 05 Grand Caravan. We found ours at a local junk yard. It cost us 200 and even matched pretty well with the current benches. Just call around to your area junk/salvage people.
Mar 29, 2009 | 2005 Dodge Caravan
Bought a chescold finch 3 way fridge but no instructions - help
The max/min gas flame is for adjustment of temperature when using the fridge on gas. The next one with 0 to 7 is possibly the electrical thermostat. I am not familiar with this exact model. One of the dials will be able to be pressed in. The idea is to press and hold this button in for about a count of five, then push the lighter strike. You will hear a click noise which is when a spark is delivered to the burner area. Some fridges have a small window or guage which shows if the flame has lit. You may have to look down the chimney. You keep holding the press button down after having depressed the lighter strike button for about five seconds. This allows gas to flow to the burner while the thermocouple heats up. Once the thermocouple (which is a small copper probe sticking almost into the flame) heats up, it will keep the gas valve open and if you then release the button, the flame will continue burning. The idea is that if the flame were to blow out, the thermocouple would cool and in turn act as a safety by shutting off the gas supply. Hope this is enough info.
Mar 05, 2009 | Engel Freezer 22 Qt. Fridge/Freezer
Our caravan fridge electrolux rm4206 gets cold on both gas and 240v mains but does not seem cold enough ie freezer compartment is not quite frozen and fridge compartment is not cold enough. Any...
remove the fridge from caravan, now turn upside down and leave for as long as possible. what this does is get rid of any air locks in the gas. once left for a month or too turn back and leave for a day to setal and refit to caravan.this should solve your problem, it has been tried and tested on our caravan and worked. (This will not work on a domestic house fridge because they work on a different system)
Aug 27, 2008 | Electrolux Refrigerators
Refrigerators Logo
1,784 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
