Question about Ricoh Aficio 1515MF All-In-One Laser Printer
LAN PRINTING NOT WORKET ON RICOH 1600LE
I INSTALL RICOH 1600LE PRINTER ON XP PROFESSIONAL AND IT'S WORKING FINE ON IT WHEN I SHARE IT AND GIVE PRINTING FROM OTHER PC THEN PRINT NOT COME OUT AND AFTER GIVEING PRINTING FROM LAN LOCAL PRINTING ALSO STOPPED. NOW I MUST CANCLE PRINT JOB AND STOP AND RESTART SPOOLER SERVICE AND THEN PRINT. I INSTALL IT ON OTHER MACHINE ALSO BUT GET SAME PROBLEM AND ALSO DOWNLOAD NEW DRIVER FROM COMPANY WEBSITE BUT PROBLEM NOT SOLVED PLEASE HELP ME. THANKS IN ADVANCED
  • 1 more comment
  • heriya Mar 24, 2009
    MS-Excel pages not print the printer how can print?
  • banga1970 Mar 28, 2009
    "LAN PRINTING NOT WORKET ON RICOH 1600LE"
  • hardik1020 May 05, 2009
    Ricoh Aficio mp1600le Printer install and printer sploor service stop
    Problem Solver:
  • 13 Answers
Use an updated driver version for this machine on ricoh-support.com, another solution is using pcl5 driver as this one does spooling at computer and not machine...
Posted on Mar 09, 2009
How do i download Aficio MP 1600le driver
Hello there.
BEFORE you start, you must find out the Windows operating system you are running on your PC. To do this, go to 'Control Panel' then 'System'. The system page will tell you what version of windows you have. Make a note of the version !!!!
The drivers for your Aficio machine are available to download from this page http://support.ricoh.com/bb/html/dr_ut_e/rcn/model/mp16/mp16en.htm
You just click on the Windows system that you are using, and you will then be able to download the drivers for the 1600le. You will probably need ALL the four different printer drivers.
To install the drivers, you will need to run each downloaded file and store the files extracted driver files in a NEW folder.
You then go to control panel - system - device manager - right click on your printer and update the drivers.
It is complicated but as with all computer items, it makes sense when you do it.
All you are doing is telling your specific PC, HOW to 'drive' the printer. Just like if you got in to a new Truck, you would want to have the driving instructions.
Good Luck
Sep 11, 2014 | Ricoh Office Equipment & Supplies
Ricoh Aficio SP C430DN - Print Data Error
Its you, change drivers, postscript on the printer? PCL 5C is what your are using?
Mar 31, 2014 | Ricoh Office Equipment & Supplies
Error while sending message to sc print a
Try installing the printer with a USB cable first (disconnect the LAN CABLE FIRST) and do a normal installation. Check all functions of the printer and then do a LAN printer install by going to "install or add a new printer on the control panel and then follow the instructions for adding the printer via LAN or wireless if it does support that function. I think you did the initial install backwards (LAN first instead of USB) and when you think you're done, update any software that might be available from the manufacturers site, THE ACTUAL MANUFACTURER not any other site that offers the update!) Like CNET OR FIXYA OR WHATEVER) GO DIRECTLY TO THE SITE, e.g., Canon, Epson, ETC..)
Nov 18, 2013 | Office Equipment & Supplies
I am not able to install scanner driver of ricoh 1600le, tell me how to install it
scanner driver can only be installed if you have the network option fitted in the printer. the scanner doesnot work through usb.
Nov 30, 2010 | Ricoh Aficio MP 1600L Black and White...
Ricoh Aficio MP1600 Le
Is your Windows 7 a 32 or 64 bit? Which driver are you downloading? Recommend PCL5c...
Feb 10, 2010 | Ricoh Aficio 1515MF All-In-One Laser...
Hp Vista Laptop won't communicate with XP desktop when trying Prt
u have share your printer and add your printer in laptop u have to connect both pc in lan (local area connection ) or u can use the cross cable of lan when both pc connected then u have share your printer in xp then u have to add the printer in your vista laptop by using printer add visrd there is option on it u have to select the network printer & add it in to vista then u can print it
or
there is onther way u can install your printer in a laptop u need ur printer vista download
Jan 17, 2009 | Office Equipment & Supplies
I need ricoh aficio mp 1600le driver, how do i get into.
Here is the driver page:
http://www.ricoh.com.sg/downloads/drivers1.aspx?path=http://support.ricoh.com/bb/html/dr_ut_e/ra/model/mp16/mp16en.htm
copy and paste the link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Nov 11, 2008 | Ricoh Aficio 1515MF All-In-One Laser...
Ricoh 1018d not print with lan conection
Hi Usama,
I had the same proplem as you when i installed pcl6 driver on my ricoh 1085
I solved but by uninstalling pcl6 driver and installing pcl5e
for your 1018d try this driver for windows XP D O W N L O A D H E R E
BTW.
about using 1085 as a scanner ,
I don't know what is "scanner interface drive board" ?
more help please.
Oct 23, 2008 | Ricoh Aficio 1085 Laser Printer
Sharing srp350 network printer on win98 to winxp
You are correct with the conflict, although, it's a difference in drivers, i think what has happened is when you share a printer with xp, it installs the driver from the pc with the driver and printer attached, and as it is attached to a win98 pc, the full functions are probably unavailable,unlike an xp local driver.
Mar 06, 2007 | Samsung SRP 350 Thermal Printer
Ricoh Aficio 1515MF All-In-One Laser Printer Logo
245 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
