Question about Hoover Washing Machines
The machine keeps spinning even when its loading water before wash.
  • Hoover Master
  • 3,463 Answers
Could be a problem with the control unit ,or possibly a fault on your motor, the tacho magnet could be loose or broken on the end of the motor shaft, this regulates the speed of the motor, so you need to check that first.
Hope this helps.
Please leave feedback.
Thanks
Posted on Dec 06, 2008
Haier HLP21E Top Load washer keeps beeping & blinking after water intake. It will rinse out the water when 'rinse' pressed. However it does not 'spin' but instead all three orange lights start blinking &...
No spin with alarm means the unit is out of balance.
The troubleshooting manual reads:
"The safety switch acts. The
spinning cannot work (The
WASH, RINSE and SPIN
indicator flash and alarm goes
off every 10 seconds). If
trouble cannot be solved after
alarming, it will alarm again
every few minutes."
To solve this the load must be balanced:
Make sure to level the machine on a solid floor. Also you may have to redistribute the clothing in the tub for even weight distribution.
Sep 28, 2013 | Haier HLP21E Top Load Washer
I have LG fyzzy logic 6.5 kg WFS65AO1DCT and it keeps loading and draining water even when in spin
see this causes and fix it. God bless you
This happens on new installations usually. The drain hose must be higher than the highest fill height of the washer. If the drain hose is to low it will create a siphon effect and drain the machine. Next is the drain hose is to tight in the standpipe. The standpipe is your homes plumbing. If the drain hose does not have an air gap aroung it, it can cause a siphon effect and start draining your machine as it fills. If none of these are the problem and your drain pump is running at the same time it is filling you will need to replace the control. For top load machines follow this video and for front load machines follow the tutorial.
Sep 30, 2012 | Washing Machines
All the water does not spin out of the clothes & at times it doesn't even seem like it is spinning
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Jun 07, 2011 | Whirlpool LSR6334LQ Top Load Washer
My washer will not empty all of the water out on the spin cycle, it does not matter which wash cycle I have put it on. I have even tried the Drain and Spin cycle. I have even taken all of the clothes out...
heatman101
Apr 15, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Not spending water out good water keep running while the washer is going not spending cloth dry..
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
If you are having problems with your front load washing machine then checkout this tip...
heatman101
Mar 06, 2011 | Kenmore 22422 Top Load Washer
Water drain open even washing mode and during spin water not drain
heatman101
Aug 29, 2010 | LG Washing Machines
2 problems 1st is the washer continues to fill with water when i put in a new load second is it wont spin
If the water keeps filling without cutting off, you either have a faulty inlet solenoide or your pressure hose and or pressure switch needs checking.
To isolate the acutal problem, start the machine on a new cycle. Change the water level to minimum or low before you start. Let the machine fill up. Keep checking the water intake as it fill up. Once the water level goes over the half way mark in your tank, if the machine starts its wash action then your pressure hose and switch are o.k. as they have signalled to the timer that the water level selected, has been reached.
However if the machine keeps filling up even though the wash action has started, then you have a faulty inlet solenoide/valve. Turn off water at the tap and get the valve replaced.
Ash
Oct 26, 2009 | General Electric WCSR2090G Top Load Washer
Washing Machines Logo
42 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
