Question about Lands Phones
My phones are flashing searching all the time
I have a twin handset dect 122 and have experienced the same problem.having already unplugged the mains transformer and re-connected to no avail i decided to remove the rechargable batteries and re-insert and hey presto! both phones are now working,for how long i dont know but could it really be that simple?we will see.good luck,waza.
Posted on Jan 03, 2009
Managed to sort the problem out by leaving disconnected for a while and resetting.
Posted on Dec 07, 2008
Blackberry won't turn on
there is any Red Light blinking at your phone ?
if yes,you have to Flash/Upgrade Firmware your blackberry.
and How to Upgrade frimware Blackberry,you can see and Searching at YOUTUBE or you can Found in :
http://www.gsm-forum.eu/furious-gold-tutorials/1851-how-flash-blackberry-phone.html
or in :
http://srimeenakshimobiles.com/forums/blackberry/11578-blackberry-guide-how-unlock-flash-8xxx-9xxx.html
and for the Firmware you can search and Download in http://www.zylone81.indonesianforum.net/forum/
or you can search at Google.
Jan 08, 2012 | RIM BlackBerry? Curve 8330 Cellular Phone
My em228 flashes blue red why?
It is NOT the battery. When you turned the bluetooth on, only hold the power button until the blue light flashes about 3 times. If blue tooth is enabled on your phone, this should allow the bluetooth to connect without having to search for any devices, that is, if you already have it in your settings.
The red and blue alternating lights are to setup the bluetooth and allow it to connect to your phone, THE FIRST TIME. Once the device is listed in the bluetooth settings on the phone, you can just connect, instead of searching for the device every time you need to turn it on.
Only hold the button until the bluetooth flashes BLUE, about 3 flashes........see if this works better for you.....
Another frustration, (sometimes) depends on what brand of phone you have. I know my EM227 connects differently between my DG Razr and my Samsung Eternity.
Let me know if this helps, and if not, let me know what phone you have, and I will tell you for sure, exactly how to turn on and connect, with no problems.
Good luck~~!
mstipps@yahoo.com
Nov 18, 2010 | Emerson EM227 Bluetooth Headset
My att digital keeps flashing "CL" what does it mean and how do I stop it?
Problem Why is CL ( or C ) flashing in the base message window?
Solution(s) This indicates that you need to set the time and day on your answering system. During initial setup and any time there is a loss of power to the base, you will see this flashing indicator. Consult your User's Manual for instructions on setting the day and time. Manuals for most models can found on this site. Go to our MANUALS section, then search for your particular model.
http://telephones.att.com/telephones_ui/support/dsp_faq_gen.cfm?faqid=233669
Dec 01, 2009 | Uniden Cordless phone EXS9950
When my Nokia N70's camera is opened it is showing unexpected err
While this can be a hardware issue with the phone, it is probably just a firmware issue. You can do a full flash of the firmware and the issue should be resolved. I would start by going to Nokia support and try to upgrade the firmware software there. If not, search google for the JAF, but this is a hardware device and may cost you, also search google for nokia flash software to try to flash using your computer. If doing a full flash of the firmware does not work, it is probably an IC chip issue and would require it to be fixed on a hardware level.
Oct 24, 2009 | Nokia N70 Cellular Phone
I have a Ge 25942EE4-C phone and the Cl is flashing I have looked the phone over for a button to set this can you please assist me?
We had this same problem and seeing that the Manual is incorrect, I searched GE website manuals to find a different one that at least looked like the right model and found out how to clear the CL message code. This is just a time/day setting and it is to be done by the handset, not the base unit, With the handset, press the flash key, then press #8. You should now see the time flashing in the display. Adjust the time then press the pound key. Now the day is flashing in the display. adjust the day with the up arrow, then press the pound key to finish. Your base unit will announce the time and day is set and the CL is gone.... good luck
Dec 29, 2008 | GE 25942GE2 Cordless Phone System
Reformat
you need to have a usb supported cable for your phone.
To connect phone in flashing mode, and perform tasks like flashing the main firmware, FS or to upload files to FS you must have USB Flash drivers installed on your computer.
With out installing USB Flash drivers, you can’t use XS++ or SeTool 2 lite or JDFlasher.
In good old days we used to use SEUS to do this automatically for us, but now SEUS updates phone to CID53 which is not desirable, so hence we install USB Flash Drivers manually. Here is the tutorial ! Please read the tutorial completely and also check out the video attached !
Installing Drivers (for Windows XP)
Download the necessary drivers.
Then unpack the downloaded archive to a directory, your choice. (Use WinRAR to extract from archive)
1. Switch OFF your phone !
2. Remove the battery !
3. Reinsert your battery !
4. Don’t start your phone !
5. HOLDING ‘C’ on your phone, connect your phone to USB Cable !
6. Don’t Leave C through out driver installation.
You get a notification in System Tray ! Saying SEMC USB Flash Device
A new window should appear “Found new hardware wizard”
It asks permissions for to search for drivers for the device. Select “No, not this time” and click next.
Then select the option INSTALL FROM A SPECIFIED LOCATION(ADVANCED) and click next
Then choose “Search for the best drivers in these locations”, and check the “Include this location in this search”, now browse for the downloaded drivers.
Click next, Wait for some time, drivers get installed.
Now…….
Open the directory, where you unpacked the archive, In the directory, you will find a ggsemc.inf file. Click on it with the right mouse button, and then click ‘Install‘.
Sep 15, 2008 | Sony Ericsson K610i Cellular Phone
Flash timing setting for polycom sound station
You need to update the flash timing on your Soundstation to match what is on your PBX.
Check out http://knowledgebase.polycom.com/kb/search.do?cmd=displayKC&docType=kc&externalId=10964&sliceId=SAL_PUBLIC_1_2&dialogID=2075496&stateId=0%200%202071605 and http://knowledgebase.polycom.com/kb/search.do?cmd=displayKC&docType=kc&externalId=11208&sliceId=SAL_PUBLIC_1_2&dialogID=2075496&stateId=0%200%202071605
Jun 06, 2008 | Polycom SoundStation Premier EX Audio...
Km1 screen blank
You need flashing your phone. Power off your phone. Press * and # at the same time and power on your phone while pressing those keys. It supposed to show your phone information. If it shows, notice the phone software version. Search on google and download that version flash file. For flashing you need RSD Lite or Flash&Backup software. Search on google also for these. Additionally, an USB cable is needed to flash the phone.
May 19, 2008 | Motorola Mobility RAZR V3c Cellular Phone
Flashing Display on Samsung i500
I have had the same problem... twice.  First time I held down some keys just trying desperately to get it to come back to life.  Well I hit the right combination for a hard reset.  So I lost all my data.
Second time I took my phone into the Sprint Store across from Sprint HQ in KC.  The only thing they knew to do was a hard reset. I'm suspicious since I was having trouble removing my battery the second time, that my battery's position may have caused some type of short.  Still searching. KC Ron
Jan 20, 2008 | Samsung SPH-i500 Handheld
Handset flashes "searching" and has stopped working
Did you already try cleaning the connections on the phone and the base with alcohol on a Q-tip? Make sure the connections on the phone are touching the base propely.
Jul 19, 2007 | Siemens Gigaset 4210 Cordless Phone
Lands Phones Logo
270 people viewed this question
Top Lands Phones Experts
Are you a Lands Phone Expert? Answer questions, earn points and help others
