Video Game Consoles & Games Logo
Posted on Dec 06, 2008
Restore codes to nintendo ds
We accidentally deleted the default code list while ACTION REPLAY DS was in the machine. WE have supporting disc which we believes would work but the nintendo ds, when connected to our computer, leads windows to display a window saying the driver can't be found. Do we have to visit a website to get the driver? If so, which website please.
Anonymous
Level 1:
  • Contributor 3 Answers
  • Posted on Dec 09, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
1160
Points
You can ask to good engineer
3helpful
Action replay doesn't let me add codes in custom code list!!!!!
Your Action Replay DS hardware may require resetting if you are experiencing any of the following problems:
* Code Manager PC software is reporting that Action Replay DS does not contain enough free space when it actually contains no codes.
* Code Manager PC software is reporting the console`s battery is low when it’s actually fully charged.
* Multicolored bars are shown on the screen after you confirm the entry of a game ID when trying to manually enter codes.
* You can use the Code Manager PC software without any problems until the Action Replay DS is connected via USB set to the update mode on the console, at which point Windows shows a run time error.
If you are experiencing any of these problems, please follow the steps below to reset the Action Replay DS hardware. Please beware that resetting the Action Replay DS hardware will not restore a default codelist, and any codes which are stored on the Action Replay DS will be erased.
1. With your console powered off insert the Action Replay DS
2. Hold down buttons A+B
3. Turn your console on
4. With A+B still held down, as soon as you see the Action Replay DS license screen press and hold down buttons START+SELECT so that you now have 4 buttons held down
5. Hold all 4 buttons down for around 10 seconds until the Action Replay DS loads to it`s home screen
6. If Action Replay DS doesn’t hold on the license screen for around 10 seconds when you do this, you may need to turn off and try again
9helpful
I wiped all my games! HELP ME!!!!!!!!!!!!!!
i had the same prob
* Multicoloured bars are shown on the screen after you confirm the entry of a game ID when trying to manually enter codes. * You can use the Code Manager PC software without any problems until the Action Replay DS is connected via USB set to the update mode on the console, at which point Windows shows a run time error.
from codejunkies
1helpful
My ds wont accept the ards. My other ards wont put any new games in the bottom screen it goes blue and red?My computer (windows vista)doesnt accept my ards
Your Action Replay DS hardware may require resetting if you are experiencing any of the following problems: * Code Manager PC software is reporting that Action Replay DS does not contain enough free space when it actually contains no codes. * Code Manager PC software is reporting the console`s battery is low when it?s actually fully charged. * Multicoloured bars are shown on the screen after you confirm the entry of a game ID when trying to manually enter codes. * You can use the Code Manager PC software without any problems until the Action Replay DS is connected via USB set to the update mode on the console, at which point Windows shows a run time error. If you are experiencing any of these problems, please follow the steps below to reset the Action Replay DS hardware. Please beware that resetting the Action Replay DS hardware will not restore a default codelist, and any codes which are stored on the Action Replay DS will be erased. With your console powered off insert the Action Replay DS Hold down buttons A+B Turn your console on With A+B still held down, as soon as you see the Action Replay DS license screen press and hold down buttons START+SELECT so that you now have 4 buttons held down Hold all 4 buttons down for around 10 seconds until the Action Replay DS loads to it`s home screen If Action Replay DS doesn?t hold on the license screen for around 10 seconds when you do this, you may need to turn off and try again whats an ard? from code junkies
Action Replay deleted all of the cheats for Nintendo DS
you can reconnect your ds+AR and you can put the codes back on there by clicking and draging one of codes list from codejunkies.com if you have your Action Replay Code Manager installed, which should come on a disc you bought with your AR
2helpful
2answers
Action Replay DS has deleted avery single cheat code it came with
source codejunkies
Cant update action replay ds version 1.60
your codes got corrupted you have to delete all of the codes even if it says there is no codes on it then you can update it
5helpful
2answers
My Ds Action Replay Went BLANK!
i have had a similar prob it wiped all the games andm then i could not put more on because it went multi coloured when i tried so i hap to reset the entire thing to do so(source codejunkies):
copyed from code junkies
5helpful
2answers
I want cheats for Ridge racers5
I'm not sure if you're asking for cheat codes for use with Ridge Racer DS for the Nintendo DS, or Ridge Racer V for the Playstation 2 - Unfortunately, neither game has actual cheats built into them. You can, however, use a hex editor tool (also referred to as a Trainer, Gameshark, or Action Replay), which would allow you to cheat.
Intec Action Replay for the Nintendo DS: http://us.codejunkies.com/Products/NDS-Action-Replay---USA__EF000142.aspx
Action Replay codes for Ridge Racer DS for the Nintendo DS: http://us.codejunkies.com/search/codes/Ridge-Racer-DS_Nintendo-DS_17825879-17___.aspx
Intec Action Replay for the Playstation 2: http://us.codejunkies.com/Products/PS2-Action-Replay-MAX---USA__EF000306.aspx
Action Replay codes for Ridge Racer V for the Playstation 2: http://us.codejunkies.com/search/codes/Ridge-Racer-V_PlayStation2_1048770-1___.aspx
2helpful
2answers
Erased Action Replay
Well, you're going to have to install the AR Code Manager on your PC. When you do that, insert your AR cartridge into your DS and plug it in via the USB cable on the PC. After that it should attempt to load your current code list. If nothing pops up hit the "Quick Update" button at the top, it should delete your current game codelist and download the new codelist from one of the sites listed.
Top Video Game Consoles & Games Experts
MegaByteMe
MegaByteMe
Aron
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
