Question about Mitsubishi VS-60703 60" Rear Projection Television
No main picture
Sound is good, PIP picture is good and when doing menu items the whole screen is readable. All other times the screen has a bluish tinge.
    President:
  • 1,284 Answers
Sounds like the PIP board is or has failed.
Posted on Feb 14, 2007
How do i fix my screen
Sounds like you might have it on picture in picture mode! Look on the remote for a pip button and press it (might have to do it a few times)
Oct 13, 2014 | Samsung PN51E450 51-inch Plasma TV
Turn on pip wiithout remote
If your TV has a Menu button on its front panel, enter its Menu widow, surf through, come to wards picture control window, and make PIP function OFF. If it has no such button, you must have its remote control to turn it OFF.
Jun 07, 2012 | Televison & Video
My Mitsubishi VS 50703 is fed from a DVR into input Ant A. I get sound, but no picture, until I press the 'menu' button on the TV remote; then the picture appears in the PIP window for a few...
Try resoldering the vertica IC. Very common problem. When vertical drops out the CRTs go into blanking ( shutdown no picture) but the menu and on screen displays will still work. Resoldering the IC will usually solve the issue.
Jul 15, 2011 | Mitsubishi VS-50703 50" Rear Projection...
Black square on screen that covers half the picture appeared on my 42" sharp aquos tv.
sounds like you might have PIP turned one (picture in picture) .. if there is no input hooked up for the PIP . you will just get a black screen ... you should be able to move that PIP around and change its size .. indeed turn it off .. look for a menu item called PIP .. select PIP off ..
Nov 06, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Mitsubishi cs-26ex1
This sound like the standard Mitshubisi PIP board problem. There are two ways to adress this one is to repair the board, this involves replacing surface mounted capacitor and is about %80.00 sucsessful. The other is to simply bypass this board. this option is the way to go, it involves installing two capacitor on the main board and fixes the main pix but kills the Picture in Picture (PIP) I will send off both these repairs to your E-mail
Feb 13, 2008 | Proton MM2701VT 27" TV
Pip position
Hi there
The PIP ( picture in picture ) is only to determine where the Menu block itself will show on your screen.
Try the Vertical and Horisontal shift in the Menu Options.
Oct 23, 2007 | BenQ PB6100 Multimedia Projector
No pic or sound
The TV is in some kind of protection mode, the blinking LED show you an error code.
Try pressing 062596 and then press menu button (do these in quick motion, don't let them to time out while keying)...see what happens
I also heard that this problem appeared with some people because the of the burnt fuse in the TV. To fix that it has to be taken to the tech shop. mecry.gif
And yes I also heard about this issue many times, seems like this TV set is very popular with this kind of problem.
Oct 22, 2007 | Philips Magnavox 42MF521D/37 Television
No pic/sound on main screen
I will recommend replacement of the main tuner
Dec 10, 2006 | Toshiba CN35F95 35" TV
Main screen color seems overmodulating. PIP subfeed color fine. White like under black light.
rule number one about all vs chassis with vertical can pip boards take them out and throw them away i could fix one but you couldnt beleive me and it wouldnt be worth your while do a search on your modle number until you come up with instructions on how to add two caps to the pip board connector to bypass it until you do this you are wasting your time Mitsubishi ... we're still building Zeros
Dec 08, 2006 | Mitsubishi VS-50705 50" Rear Projection...
Blue screen and sound but no picture, except in PIP mode
The lighting possibly damage the tuner of the set,for now you can swap the pip with the main picture and change the channels with the vcr,you need the assitance of a service to diagnose how much damage is there but.Let us know what you find or if you nned more information.
Oct 06, 2006 | Mitsubishi VS-45603 45" Rear Projection...
Televison & Video Logo
69 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
