Question about Sony KP-53S65 53" Rear Projection Television
Poor color issues.
My KP-53s65 is having color issues. In the movie setting on the menu, the picture looks pretty good, but there is a noticable red tint to the screen. I've tried reseting to factory settings and cleaning the lenses and mirror, but there is still a redness to the picture. Also, in standard and sports mode the picture has a distinct whitish-blue tint to it. Again, adujusting color, hue, or brightness has no effect. Do I just need to replace one or more of the projector tubes or is there a simple, nobrainer solution to my problem. The tv is about ten years old, if that makes any difference.
  • edenflow Oct 17, 2008
    my 53" sony projection tv is about 10 yrs. old and has the same problem: the whole screen has bluish/white tint to it and has the standby light blinking. tried to unplug the unit for a while , plug it in and tried to reset thru convergence but no matter what i do to it would not converge. same is true when i use the remote comtrol to do the above.as well, menu won't show up on screen, either manually from the tv console or the remote.any advice would be greatly appreciated. thank you
    bottledfrom yvr
    Sniper:
  • 80 Answers
If the set is 10 years old, one or more of the CRT's (picture tubes) may need to be rebalanced in a process called white balancing. If the tubes are in good shape this can be accomplished with great ease. A good tech will then reset the focus and screen adjustments to obtain an optimal picture. I personally own a 16 year old Sony KP61 series big screen and it looks great with the original tubes, hope yours goes just as long. Joe Weibel Custom Electronics (customelectronics.org)
Posted on Feb 14, 2007
    Scholar:
  • 168 Answers
Try adjusting the convergence. good luck and happy valentine!
Sony kp53s65
A rather older set:
picture blinks may be screen controls now set too low
picture dark same or lens need cleaning
color off either adjustments or a Convergence issue
Mar 16, 2012 | Sony KP-53S65 53" Rear Projection...
Sony rear video projector.KP-53S65. Turned on the TV today and has a double image and the colors are off. No previous malfunction. Any suggestions?
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projeciton sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you are handy and can follow directions. You can get complete repair kits from TvRepairKits.com or click here. They have put together DIY repair kits that include the OEM parts and step by step photo instructions for each repair. If you are not handy or can't follow directions we would suggest a shop.
Jul 03, 2010 | Sony KP-53S65 53" Rear Projection...
I am having issues with my Sony KP-53s65 53in TV... You see double people and words. The color is off and the focus setting does not correct this issue. The RED and BLUE cross bars are lined up with the...
you need to get into the service menu on the tv and adjust some values you can find these values online but i would highly recomend that you get a service centre to look in to this ,
i've done mine my self but if you hit the wrong valuye you could mess the whole tv up there are about three pages full.
hope this helps
Jul 05, 2009 | Sony KP-53S65 53" Rear Projection...
53" sony projection -picture washed out w/ green horizontal lines
It sounds like your Green CRT ( picture tube ) is shorted. That's the one in the middle. Sony had issues with there tubes in those years. Sorry for the bad news. Even if you could locate the tube, it will be a matter of time before the Red or Blue does the same.
May 03, 2009 | Sony KP-53S65 53" Rear Projection...
KP-53S65 Blue Ghosting
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer2_bing.gif Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.png http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Aug 11, 2008 | Sony KP-53S65 53" Rear Projection...
Double vision
Convergence ICs are bad it causes the red and/or blue to jump out of alignment making it look 3D. You have to convergence ICs located on a large aluminum heat sink with an STK number stamped on them. You can purchase new ones for about 10.00 each. they have to be soldered in. If you can solder you should easily be able to repair this yourself. Let me know if you need anything further.
Jan 24, 2008 | Sony KP-53S65 53" Rear Projection...
Cant fix my sony KP-53S65
If the TV will not turn on and the red light blinks on the front of the set, it means that the microprocessor has detected a problem in the set and shut the set down. It then blinks the red light a certain number of times, and the number of blinks is the code for why the set has shut off. How many times does the red light blink before repeating?
Aug 07, 2007 | Sony KP-53S65 53" Rear Projection...
Strips of color coming up from bottom of tv
youll need to replace the stk ics inside the tv. they are easilly found by looking for two larg heat sinks. im pretty sure sony runs stk392-510. you will have to look at the ics to verify.
Apr 16, 2007 | Sony KP-53S75 53" Rear Projection...
KP-53s65 multipule problems, hoping for single solution?
sounds like 2 different problems here. first problem sounds tuner related. second sounds convergence related. third issue (cost effective to repair ?) at this point i would replace the set. i hope this helps
Mar 12, 2007 | Sony KP-53S65 53" Rear Projection...
Sony KP 53S65 53" rear projection TV contrast issue
While the root of the problem is likely the picture tubes aging, I'm sure it would benefit from a cleaning and adjusting. After the dust is cleaned from the lenses, the screen controls could likely be lowered to get the blacks you desire. An experienced tech would be able to do this for you.
Jan 03, 2007 | Sony KP-53S65 53" Rear Projection...
Sony KP-53S65 53" Rear Projection Television Logo
154 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
