Question about Logitech Webcam
Logitech cannot access our webcam.
Sometimes when I skype my friends cannot see my picture.
    Genius:
  • 1,061 Answers
Use the skype set-up for your webcam and mic.RICHARDM69
Posted on Dec 10, 2008
When i go on skype the picture of me is fuzzy flickering snowy but my skye friend is clear
Open skype go to tools options scroll to audio settings or video settings you can see the webcam there you can even take a snapsot also make sure your settings are correct for a video call
hope this helps
Jan 25, 2011 | Logitech Webcam
Webcam connection with skype
Hi have anice day.
It is your camera's CMOS sensor malfunction. Unplug uninstall-install and if no result its better to replace it.
good luck!
Feb 22, 2008 | Logitech Quickcam Chat Webcam
Pictures appear to be overmagnified and unclear ? pixel problem
CONFIGURE TO SKYPE
Connect webcam
Its good practice to disconnect and re-connect the webcam before you start ( reboot the webcam software) - if you have been using it elsewhere the SKYPE software may have difficulty in locating it, even if you exited the previous program correctly.
The reason being, the webcam software can remain hooked-up to a program and needs to be rebooted.
Mine, I just unplug it from the USB and plug it back in to reboot the software.
If yours is integral with the computer you will have to re-start the computer, use a keyboard shortcut or disable / enable the webcam from the Device Manager.
Start Skype.
On the 'Tools' menu, click 'Options'.
In the navigation pane of the Skype 'Options' window, click 'Audio Settings'
Run down the list setting defaults
Select the webcam as the default microphone.
Make a free test call
Click 'Save'
In the navigation pane of the Skype Options window, click Video Settings.
This will launch the webcam
Adjust quality of picture in 'Settings'
Check the correct webcam is shown as default
Click Save
Test your webcam by making a Skype test call.
For more information about how to configure Skype Messenger, please visit the following Skype Web site:
http://support.skype.com (http://support.skype.com)
Apr 15, 2010 | Logitech Webcam
I am not a computer person.I was wondering if logitech webcam C250h will work with skype?
Yes, I have a Logitech WEBcam (not the same model) and I use Skype.
After you installed Skype then :-
To test if the Logitech QuickCam is functioning, check the USB cable; make sure it is connected properly. Then click on Start - All Program - Logitech - Logitech QuickCam and see if you can get the camera to capture your image/video.
If this works then the fault is with the Skype configuration. Sometimes the WEBcam settings drop off and the WEBcam need to be selected again. Open Skype - Tools - Options - Video Settings and select the Logitech QuickCam
Also check the Audio Settings for the Microphone THEN click on Save.
Avoid connecting the WEBcam to an USB hub.
Mar 09, 2010 | Logitech Webcam
When using the ultravision with skyp it sometimes tells me: you have a problem with your mic. After that it shuts down the call. what is the problem?
Check your Audio settings
Typical audio set up
Laptop/mic x webcam/mic x Vista x Yahoo Messenger
If you have an earlier OS, you may have to access your hardware from the Control Panel.
TEST SPEAKERS
Right click on speaker icon in System Tray
Select "Playback Devices"
The speaker icon ( checked as working) and volume level graph should be visible
Right click on the volume graph and click "Test"
Left hand speakers followed by right hand should be heard
SET DEFAULT & TEST MIC
Click "Recording" tab.
To set required (webcam) mic as default - click on mic font to highlight and click "Properties"
In lower dropbox display "Use this device enable" click OK
Click "Levels" tab and ramp up sliders ( adjust to suit later)
Return to "Recording". Test mic by speaking and make sure volume graph displays
Restart computer
CONFIGURE TO SKYPE
Start Skype.
Run down the list setting your defaults
Select your webcam as the default microphone.
Click 'Save'
This will launch your webcam
Click Save
Still no Luck ?
Visit the logitech website and click on your webcam to check out the support and known issues for your model
http://www.logitech.com/index.cfm/405/&cl=us,en?prodcrid=405
Your cam might have Rightsound which needs to be configured
Jan 19, 2010 | Logitech Quickcam Ultra Vision Webcam
Some of my friends are on webcams driven by logitech and some on skype - can my logitech driven webcam access the skype friends?
Yes - no problem - you will have to download Skype - whenever you want to use a webcam in a new program you have to configure the webcam software to the chat program software
Test your webcam here to make sure it broadcasts ok - Hit 'Allow' in the top window and check your cam in the left hand panel.
http://www.testmycam.com/
working OK ?
CONFIGURE TO SKYPE
Connect webcam
Its good practice to disconnect and re-connect your webcam before you start (To reboot the webcam software) - if you have been using it elsewhere the MSN software may have difficulty in locating it, even if you exited the previous program correctly.
Start Skype.
Click 'Save'
Click Save
Dec 27, 2009 | Logitech Webcam
My friend can't see me but she can hear me. I can see and hear he
If you have a conflict with your printer - disable the printer during cam sessions
make sure your cam is configured to Skype
  1. Start Skype.
  2. On the Tools menu, click Options.
  3. In the navigation pane of the Skype Options window, click Audio Settings.
  4. Select your Logitech device as the default microphone. For example, select Logitech e3500
  5. In the navigation pane of the Skype Options window, click Video Settings.
  6. Select your Logitech device as the default Webcam. For example, select Logitech e3500
  7. Click Save.
  8. Test logitech by making a Skype test call.
Aug 24, 2009 | Logitech QuickCam Pro 5000 Webcam
Logitech webcam image dark
Normal 0 See section A. Skype in the info below to setup the Audio & Video.
Also send this to your family and friends so they have their computer setup properly.
Web Camera’s have to be setup on the program they are to be used with. Just installing the camera on your computer does not set it up to broadcast on messengers or Skype.
Each program has Options that have to be setup in order for the Audio and Video to function properly.
A. Skype Setup:
After downloading and installing Skype (http://www.skype.com/intl/en-gb/download/skype/windows/beta/downloading/) set it up as follows:
  1. Go to Tools, then Options, and click on Audio Settings and set the Microphone and Speakers to the computer Audio Card.
  2. Then click on the Video Settings.
  3. The camera if Installed Properly will come up and show a video picture.
  4. Then, on the bottom of the page click on Save.
The camera and audio should function properly. Your friends and Family will now be able to see and her to you.
B. Yahoo Setup:
After downloading and installing Yahoo Messenger (http://www.soft32.com/download_30.html ) set it up as follows:
  1. Go to Messenger at the top left and click on it.
  2. Next go down to Preferences and click on it.
  3. Next Calling and Devices on the right and set the Microphone and Speakers to the computer Audio Card.
  4. Next go to the Test Audio section and (in blue writing) click on “Open the call setup assistant” and follow the instructions on the left window.
Hope this helps. Bud
Jun 15, 2009 | Logitech Webcam
My picture turns to "Green Screen" while video calling on Skype..
sometimes i get similar effects when i use skype or MSN my view goes yellow i think it is due to the age of the model of the webcam, so i recommend getting a better one. If the problem persists then maybe the graphics arent that good with the webcam or the software is dodgy. hope i helped!
Apr 30, 2009 | Logitech Webcam
Logitech Webcam Logo
67 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
