Question about ASUS P5L-MX Motherboard
USB does not at booting time on bios
Dear Sir,
Can you solv the problem about BIOS, when i chosse the way of booting from bois setting , on bois board i dont found usb/zip for booting
system : Toshiba Pro 4300 series
Pentium - III
  • 73 Answers
Hi buudy first of all
1 just check whether the usb setting shows in ur bios enable it if it shows disable
2 start the pc go to device manager in my computer enable the usb device
3 to check whether it is enable plug any usb devices (keyboard , mouse etc ) if key,mouse starts than it is okayyyyyyy
Posted on Dec 06, 2008
How do I get into a BIOS that does not boot.
you mite cold boot, when the system turned off and nothing is running wait about 10 seconds, than push F10 when you are booting up.
if you want a copy of the bois manual for your motherboard than type the following information
the board############### bios manual
the code error do this 0271 [check the date & time in bois]
/error 0176 [ there isnt one in my tech book]
Mar 31, 2015 | IBM Computers & Internet
How to install bios
the bios is already on the board,
when you are booting the computer you have to push down on the F10, if that doesnt work than try F1 and thanF2, every time you try to enter the motherboard bios you have to start from a cold boot.
website for motherboard bios configuration and settings is at
if you want a copy of the bios setup and configurations and everything explained in detail go to your browser and type the following information.
Jun 25, 2014 | MSI MS-6758-040 Motherboard
Dell dimension 3000 keyboard freezes up on bios options
I would try this, unplug the computer from the wall, reopen the case and you should see a small "watch" battery on the motherboard. This allows the computer to save the bois when there is no power. Pull the battery out, now before doing anything else; hold the power button in on the front of the computer for about 30 seconds. Let the computer set for a couple of hours (the bois at this point should be cleared, by I have seen were you have to leave the computer sit, so I added this). Put the battery back in the computer, turn it on and try to get into your bois setting. It accually should come up with an error to enter the bois because the date and time are way wrong.
Hope this works for you
Jun 27, 2012 | Dell Computers & Internet
USB mouse block the POST
Sounds like it is trying to treat the mouse as a boot device. Check the bois under boot devices and try to disable booting from USB. If this works, and you need to boot from a USB device at times, go back into the bios and re-enable boot from USB. Then change your boot order.
Hope this helps
Jan 13, 2012 | Foxconn K8M890M2MA-RS2H Motherboard
Sir i am getting problem in booting from usb dvd ram because my installed combo drive is not working ,so how can i boot from usb dvd ram and laptop cmp is "amilo pro fujtshi siemens"
When turning on your computer, there should be a screen display either in your brand logo that promts to press a key to enter setup,bios etc. or boot priority. If it takes you into the BOIS menu, go to the boot tab, and change your boot priority to usb as first boot priority. Save and exit, you should be good to go. Should boot from the usb dvd.
Jan 31, 2011 | Computers & Internet
I can't format...
go to bios settings , when you started appear the setup options , chosse that option and go to peripherals and you can chosse the boot sequence, save and exit
Aug 01, 2010 | Compaq Armada M700 Notebook
Ver, very SLOW when booting up! Sometimes the
BIOS System defaults are best used for installing a new operating system or performing diagnostics. Bootchecks and memory checks due to settings on antivirus/antispyware programs are notorious for causing slow boots. In most cases these scans are unnecessary. Saying that, it is also possible you have acquired a trojan. Run a full system scan and if you have a clean machine, disabling the bootchecks and memory checks will speed up your booting. If after doing this your boots are still slow, tweak your BIOS as follows per Intel:
  • Set the hard drive as the first boot device in the boot order in the BIOS setup (Boot > Boot Device Priority menu).
  • Enable Intel® Rapid BIOS boot in the BIOS setup (Boot menu).
  • Disable Hard Disk Pre-Delay in the BIOS Setup (Advanced > Drive Configuration menu).
  • Disable system functions and features if you do not need them. Examples include:
    • Legacy USB - this must be enabled if you use a USB keyboard or USB mouse outside the Windows* environment (Advanced > USB Configuration).
    • Unused I/O ports, such as serial, parallel and IEEE-1394 ports (Advanced > Peripheral Configuration menu).
    • Event logging (Advanced > Event Log Configuration menu).
    I hope you find this solves your problem. All the best! Greg
Nov 10, 2009 | Intel D845GVSR Motherboard
P4p800se bois update
go to to update your BIOS.
Feb 23, 2008 | Intel Motherboard
Bios problem for A7V400-MX
Make sure that the battery contacts are good. If they are then you then are experiencing a faulty BIOS chip. try reflashing the BIOS. If this doesnt work, replace the board.
Jan 25, 2008 | ASUS A7V400-MX Motherboard
ASUS P5L-MX Motherboard Logo
235 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
