Question about HP Computers & Internet
My paper is not going through the feeding tray
  • Vikas Garg May 11, 2010
    please give out the details of your printer so that the problem could be dealt
  • 23 Answers
Make sure there is no objects in the way, Also be sure to use a regular size sheet of paper.
Posted on Dec 06, 2008
Paper going in crooked
Adjust the side guides in the paper tray up against the paper snugly. If it still feeds crokked try feeding paper through the hand feed tray.
Dec 27, 2012 | Office Equipment & Supplies
My office has the bizhub c360, and when I put paper into the bypass tray, it prints from the main tray instead of the bypass tray. The settings on the printer are for bypass tray, the settings for my...
Hi the machine could be defaulted to print from the main trays if you have the same type paper being fed from the manual feed same size paper then it will automatically take it from the default trays
IF you take the paper out of the trays and put it only in the manual feed will it print and take it from the manual feed also you have to tell the machine when you use the manual feed what size and type of paper is in the manual feed once you tell it what paper and type of paper like card stock you then need to make sure when you go to print that it is set on your computer with manual feed and type of paper must match what is set on machine
Mar 09, 2011 | Konica Minolta Bizhub 222 Black and White...
My HP printer is not feeding paper.
Here is the solution for your problem just go through the steps given below and you can fix it yourself.
1. Check to make sure your printer has paper in its paper tray. If your printer has paper, check to make sure that the tray is not overloaded. If you suspect your paper tray is overloaded, remove some paper from the tray and attempt to print again.
2. Use the same type of paper when stocking the tray with paper; do not mix different types of paper into a single stack. Mixing different brands and weights of paper in a single stack makes your printer more prone to paper feed problems. If you find that one particular type of paper causes consistent feed problems, switching to a different type or weight of paper may solve the problem.
3. Check to make sure the paper in the tray is whole. Torn and creased paper will cause problems with the printer.
4. Open your printer's rear access cover and inspect the paper feed rollers. Dusty or dirty rollers cannot grip the paper; clean them with a soft, damp cloth and water.
5. Count your printer's rollers. HP printers have six paper feed rollers; if your printer is missing rollers the paper will not feed correctly. Contact HP to replace the rollers and repair your printer.
Thanks.
Oct 06, 2010 | Computers & Internet
We have an IR3320N that will only feed from the bypass tray - anyone run into that symptom? It was feeding from the feed trays this am.
What happens when you try to feed from one of the trays? With paper in the trays look at the display, does it show that the correct paper is loaded in the tray? Get a flash light and pull the trays out and look back into the machine and see if any paper is jammed up in the back. Also make sure all the guides are up to the paper in the trays and give it a go.
May 15, 2010 | Office Equipment & Supplies
My Pc745 has stopped pulling paper from the tray without crunching it up
try to run paper from the side bypass tray. if still no go, you may have something blocking the paper from feeding. if it feed from the side bypass but not the cassette, paper feed tire may not be feeding paper or the out of paper sensor maybe keeping paper from reaching paper feed tire
Apr 11, 2010 | Canon Office Equipment & Supplies
Paper is in the feed tray, but it continues to say NO Paper??? Brother MFC-8460N any suggestions?
Could be a tab or spring broken off of the feed tray, dirty feed roller can cause that error when paper doesn't feed. Paper guide too tight so that paper can't lift to the feed roller also a possibility. Sensor above paper stack out of position.. many possibilities.
Nov 06, 2009 | Brother MFC-8460N All-In-One Printer
Mp780 - Paper attempts to feed and fails Message: Load paper
Your paper feed source is wrong .Go to the printers control panel and change the feed source.
If all you do is 8.5X11 you can go into the maintenance tab and choose it to automatically change paper trays by selectin auto continuous feed.Make sure paper is in both trays of the same type and size.You will hear the printer try and grab the paper three times then it will automatically switch to the next tray.
Jun 10, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Canon 710i
Can you look into the paper tray and actually see if the feed rolls are turning? You may have either a bad paper feed clutch, or the solonoid that releases the feed rollers is bad.
Also the paper tray should move up and down when the paper feeds to move the paper against the rollers. Up to feed down to eliminate paper drag. One of those fingers that raise the tray may be binding against the bottom of the tray not allowing proper movement.
If you can get a flash light and observe what is going on. Then let me know.
Mar 21, 2008 | Canon FAX-L1000 Plain Paper Laser
Print job will not print from the manually feed tray unless I select the Go button for it to process
Table 3-7. Paper Handling Menu
Item Values Explanation
ENVELOPE FEEDER
SIZE=COM10
For supported paper sizes
see page 1-12.
This item appears only when the
optional envelope feeder is installed.
Set the value to correspond with the
envelope size currently loaded in the
envelope feeder.
ENVELOPE FEEDER
TYPE=PLAIN
For supported paper types
see page 1-12.
envelope type currently loaded in the
envelope feeder.
TRAY 1 MODE=
FIRST
FIRST
CASSETTE
Determine how the printer will use
Tray 1.
FIRST: If paper is loaded in Tray 1,
the printer will pull paper from that
tray first.
CASSETTE: A paper size must be
assigned to Tray 1 using the
TRAY 1 SIZE option (the next item
in this menu when TRAY 1
MODE=CASSETTE). This allows Tray 1
to be used as a reserved tray.
TRAY 1 SIZE=
LETTER
see page 1-12.
This item appears only when TRAY 1
MODE= CASSETTE. Set the value to
correspond with the paper size
currently
Mar 12, 2008 | HP LaserJet 4350 Printer
Can't print onto thick card
Have you tried specifying the paper type and weight INSTEAD of the tray. Set the tray properties first, then print. If you leave it on auto tray it will use the tray that matches your paper type and weight.
Jan 09, 2007 | Konica Minolta bizhub C351 All-In-One...
Computers & Internet Logo
47 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
