Home | RCA | F31317 31" TV | RCA F31317 lost blue in ...
RCA F31317 31" TV
Problem for RCA F31317 31" TV
RCA F31317 lost blue in picture.
By inspfp on Feb 14, 2007
RCA mod# F31317 (svc# F31317-YX53), Chassis# CTC203CA6
This is another try for any other possible checks or solutions. One prior submitted solution to check several resistors on the CRT board failed to find any problem. I am still open for any suggestions. Is it just a boat anchor or a repairable unit (within reasonable costs)? Does anyone have a schematic?
Unit is approx 6 years old (per prod. date). Lost blue in picture. Picture has a sepia-like appearance. Reds are still good and green is there also. No noises occurred and there was no indication of a failure prior to the loss of blue in picture. Found service mode label inside case. Checked the blue control parameters. No adjustment can be made to the blue switches that have any effect on picture color quality. The red and green can be adjusted. The first 3 parameters are codes and each one shows code 24. I cannot find any info to define these codes. Checked the circuit board attached to the rear of the tube for cracked solder joints. No cracks visible but I touched a solder iron to each to attempt a possible fix to no effect. Checked all plug-in connections for tightness and cleanliness, NPF. I have not removed the main board to check for solder joint integrity. There are no visible damages or failures on the main board.
Same Problem
May 17, 2009
-   I have a 36" Toshiba Tube TV that is about 9 years old now. Here is what seems to be the trouble. First the TV had a terrible blue tint for about two days and then fine blue lines in the picture. Now the blue has gone away completely and I have the choice of a picture that is too Red or Too green. No idea what to do. Don't really think it's worth repairing even though the picture is still sharp and clear. -   stvn_selva
Best Solution
posted on Feb 14, 2007
Helpful)
nfandres
Rank: Guru
Rating: 87%, 261 votes
this symptom is characterised by the loss of one or two primary colours. this symptom can be classified into three cases: 1) loss of red colour, 2) loss of colour blue,3) loss of green color. this symptom may be caused by a trouble in the colour demodulator, in the color amplifier or in the colour subtraction amplifier circuit. in your case loss of blue colour. this is a very complicated problem that you need some special test equipment like oscilloscope and color pattern generator in order to trace the signal. tune the receiver to a color broadcast station(a colour bar generator can be used to transmit a colour signal to the set). check the Z-axis demodulator, z-axis amplifier and the B-Y output circuit for the chroma signal. observe the signal process with an oscilloscope. if the color signal is not present use a VOM to locate the defective component in any of the above circuits. check the transistors and the resistors in the collector circuit. good luck!
Was this helpful?
Yes
No
Popular Solutions for RCA F31317 31" TV
Questions and Unsolved Problems for RCA F31317 31" TV
Do you recommend RCA F31317 31" TV?
Answer
Answer
My RCA Model F31317 has intermittent picture display. The sound works but the picture will cut out... (More)
Answer
my sat went out and during the reset process I lost picture. just snowy static screen. still plays... (More)
Answer
my tv will not recinize when a cable box is hooked up to it. it keeps asking for a G-link for the... (More)
Answer
picture on my rca f31317 seems darker than normal, have adjusted to the brightest setting. any... (More)
Answer
changes channel down on it own nonstop
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For RCA F31317 31" TV:
Top Standard Television Experts
Rank: Guru Guru
Solutions: 689
Experience: 30 Years of professional repair and design.
Ask Me
Find more Standard Television Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
