NO IMAGE (SONY COLOR TV KV-21FT1E )
Dear friend,
I have the above tv and i have not eny image in the screen.
Its making search for a long time but nohing.
I have not eny service diagram.
  • 10,594 Answers
You can download service manual for your TV from HERE, its free and download all 4 parts of file.
Good luck.
Posted on Dec 06, 2008
I have a sony KV-27FS13 TV and about 1 week ago it started making a clicking sound (when the picture color changes) and swirching back and forth between a color and a black and white picture. Everythi
Visit the site named 'Electro-help' for more details. Check this link and select the site named above. View it in 'Flip card' option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. It will make search easy. Some times, the ads attached with each posts, both at the right and bottom, might help you to find the availability of spare parts. There are more than 775 posts to different brand TVs now.
Sep 17, 2012 | Sony KV-27FS13 27" TV
Sony trinitron wega kv-36fs200 36' tv is missing green color
sounds like a major fault with the line output transformer/power board. if no green on screen, tube is on it's last legs. Advise to scrap, not to repair, cost in excess of £200
Oct 23, 2009 | Televison & Video
SONY KV-32TW67 FAINT GREEN AND RED LINES ACROSS WHOLE SCREEN
friend maybe your LCD was broken or loose. try to pull gently if it return to normal image.
Jun 30, 2009 | Sony KV-32TW67 TV
Sony Tv
you should take it to a TV repair place, they charge $50 to look it over.
Dec 17, 2007 | Sony KV-35S40 TV
Sony tv kv-32fv300
you probably aren't checking this posting out anymore, but maybe someone else will see this and it can help them.
i was having the same problem, did a search and found this solution. worked like a charm!! go here:
http://www.floggingenglish.com/2008/07/22/diy-tv-repair-fixing-screen-flicker-on-a-sony-hd-wega/
Nov 24, 2007 | Sony FD Trinitron WEGA KV-32FV300 32" TV
Picture and sound problem at 21" sony waga color tv
This is due to problem in deflection area and power supply section malfunction. Make one general service by technical person immediately to avoid major transformer failure problem. Since this is initial stage, the cost of repair is probably less.
Aug 28, 2007 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Vertical fold over
if the set has a previous vertical line problem and a white horizental line only comes in the cross of the screen and you turned the tv on for a time while the problem is solved that mean you have make a burnt line to the screen , but if you are the tv owner and nothing of that happens so you have a problem in faulty dried capaciter in the vertical live part search for 33uf 160 v or 22u 160 v and alter regards please don't forget to rate thx
May 01, 2007 | Sony KV-32S45 32" TV
Screen went dark
Sounds like the screen control which is usually mounted in your high voltage transformer (Flyback) has opened up. Stargazer
Jan 10, 2007 | Sony KV-27S20 27" TV
Fushia Pink color on screen
It depends how many times the LED blinks. Tell me how many and I can read the description on the manual.
Jan 06, 2007 | Sony FD Trinitron WEGA KV-30HS420 30" TV
Cant locate or adjust the the TV color
All the controls should be accesed thru the on screen menu,your remote should have a menu or display button and if you press it on the screen of the tv you should see a list of different options ,I am not familiar with the kind of menu that your set has but I know the color adjustment should be in the same screen that allows you to change the brightness,shapness,tint,color and contrast,the more you use the menu and become familiar with it the easiest it will be to use.Let us know if you need more information.
Nov 06, 2006 | Sony KV-32S26 32" TV
Televison & Video Logo
145 people viewed this question
Top Televison & Video Experts
