Question about fedora Linux Operating System
Pc linux OS reboot loop - fedora Linux Operating System
  • Brian Perry
    Brian Perry May 11, 2010
    How is it looping during the boot?
  • sir scott
    sir scott May 11, 2010
    are you booting from the LiveCD ? or is your PCLinux installed onto the HDD ?
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 80 Answers
It might be cause by The MBR was messed up by a bad grub install. You can try to fix the grub.
If you want to try reinstalling grub, boot from the live CD, log in as root, open a Konsole window, and at the prompt, ([root@localhost ~]#) type;
[root@localhost ~]# grub <Enter>
GNU GRUB version 0.97 (640K lower / 3072K upper memory) <-- This is the output from grub after <Enter>
[ Minimal BASH-like line editing is supported. For the first word, TAB
lists possible command completions. Anywhere else TAB lists the possible
completions of a device/filename. ]
grub> <-- The grub prompt.
From the grub prompt type;
grub> find /boot/grub/stage2 <Enter>
(hd0,0)
(hd0,4)
(hd0,5)
(hd0,9)
(hd0,11) <-- You'll only have one, use it
(hd1,0)
(hd1,2)
(hd1,4)
grub> root (hd0,5) <Enter> <-- Use what showed up above for yours
Filesystem type is ext2fs, partition type 0x83 <-- Grub reports both ext2 and ext3 as ext2. Don't worry about it.
grub> setup (hd0) <Enter> <-- That is a zero (hd0), not a letter
Checking if "/boot/grub/stage1" exists... yes
Checking if "/boot/grub/stage2" exists... yes
Checking if "/boot/grub/e2fs_stage1_5" exists... yes
Running "embed /boot/grub/e2fs_stage1_5 (hd0)"... 15 sectors are embedded.
succeeded
Running "install /boot/grub/stage1 (hd0) (hd0)1+15 p (hd0,5)/boot/grub/stage2 /boot/grub/menu.lst"... succeeded
Done.
grub> quit <Enter>
Your done; grub is reinstalled
P.S.: If this information was helpful, please rate this solution.
Posted on Mar 12, 2009
Tip
Linux System not Booting: A Troubleshooting Session
<span>In a recent days in our lab I've got a with Linux file system. <span> </span>Our lab used Redhat Linux 5.3 Enterprise version. Redhat Linux is an Unix based Operating System and It based on Ext3 file system</span><br /> <span></span> <br /> <span><span>Problem of Linux:<span> The systen cannot access internet. It shows the license expiry error notification. Some</span></span><span>time it doesn't detect the hard drive. Some time the pc can detect hard drive but the Linux started with some errors of file system. Finally the file system of the OS getting crashed and can't boot. At GRUB loading stage it become restarted.</span></span><br /> <span><span></span></span> <br /> <span><span><span>Solution or Troubleshooting: </span><span>If I replace the hard drive cable It detect well and start OS also. Then the pc can detect hard drive but the Linux started with some errors of file system. Then I discovered that there is a problem with OS.<span> </span>Though formatting can solve the problem but that needs a backup of important data. This is time consuming and risky. So I thought to repair the file system</span>.</span></span><br /> <span><span><span></span></span></span> <br /> <span><span><span>At first I'm trying to login in single user mode and repair the file system. I have tried to login by pressing "s" beside kernel at startup in single user mode. But the system doesn't boot. Then I'm trying to repair the OS by RedHat Linux CD. I <span> </span>Insert the CD and select rescue mode by pressing "F5" key. Then I got the single user mode. After that I check all file system sequentially. </span></span></span><span><span><span>/etc /passwd, /etc/shadow, /etc/securetty, /etc/pam.d/login. Those file was wrong. I updated those file by correcting. Then I update the auth config file. After that I boot the system again. But now also it don't get start. Then I rescue the grub by grub-rescue and also update the kernel. After the total process I'm tried again to login from single user mode in root and It get logged. After that I reboot the system and tried to login. Finally it logged in successfully and run properly.<img src="alokerdas.jpg" /></span></span></span>
on Jan 15, 2011 | Computers & Internet
My computer keeps rebooting
Does it Boot or is it stuck in a boot loop cycle? Have you done ANY hardware or software, new OS?, updates/upgrades lately? Memory? Put in a new CMOS battery. Try reseating Memory Mods. Are the Fans, heatsink, vents clean? Open the BIOS setup, check Clock, set if necessary, Disable Auto Reboot. Remove ALL Media DVD,CD,USB devices, Printer cable, ect., Will it boot to Safe Mode? Take a look : http://searchenterprisedesktop.techtarget.com/Steps-for-solving-the-reboot-loop-problem May be a bad HDD? Remove and test, replace if necessary.
Feb 15, 2013 | HP Pavilion Elite M9060N PC Desktop
How to reboot my Asus Eee PC series Operating system: Linux (Ubuntu) Any ideas on how to fix it
What exactly do you mean by reboot?
If you mean by restarting OS In ubuntu, you can do it by clicking the power option found in TOP right corner right beside time.
Hope this helps.
Mar 14, 2011 | ASUS Eee PC 900 PC Notebook
Need a boot disc for my 2005 desktop I wiped the hard drive with SecurErase, when I tried to reboot only COMPAC comes up on the screen.
If you have wiped the HDD then it no longer has an OS installed and you would need to purchase one if you wanted to use Windows (whatever flavour).
You can however use a Linux system which is free. There are several different versions of Linux but I recommend you try this one
Dec 25, 2010 | HP Compaq Presario SR2150NX PC Desktop
I want to reboot my asus eee pc 900 and i dont have the disc. i was wondering if i could download the reboot somewhere and use a usb to reboot it.
Yes you can - I a m not sure where you can get the original OS for that model, however installing an OS on that model using a bootable USB is possible. Use this link to find instructions on how to for Windows OS's -
http://www.serbanghita.com/install-windows-xp-on-asus-eeepc.html
If I am not mistaken, the original OS on the Asus is a Linux OS which I think will require you to use a program called unetbootin to make the bootable USB. Use this link for unetbootin http://unetbootin.net/
You can also perform the same task using an external hard drive.
Hope this answers your question and helps FixYa! let me know if you have any other questions? Meanwhile, share the love and leave me some feedback!
Apr 02, 2010 | ASUS Eee PC 900 PC Notebook
Am hav 2 os 1.vista & linux .my vist get currupted so i reinstal it .now it is showing me only one os-vista. am hav linux in last 10gb. i think linux is there but not getting starting point.
Click Start
Right-mouse click My Computer
Click Properties
Click Advanced
Below 'Startup and ...' click Settings
Click 'edit'
After the lines:
[operating systems]
multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="Microsoft Windows XP"
add the line:
multi(0)disk(0)rdisk(0)partition(2)\LINUX="Not XP"
Save the changes.
Shutdown and reboot.
Oct 27, 2009 | Microsoft Windows Vista Ultimate Edition
Pc starts after multiple reboots
try replacing the power supply unit
Jan 20, 2009 | Linspire Five-0 for Linux
Pc linux OS 2007 stuck after seconds
One Idea is You might have some Ram issues If you can try and boot up again and run the MEMTEST option and see what happens
Dec 06, 2008 | fedora Linux Operating System
fedora Linux Operating System Logo
344 people viewed this question
Top fedora Computers & Internet Experts
alex metro
alex metro
none
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a fedora Computer and Internet Expert? Answer questions, earn points and help others
