Question about Kenmore 35912 / 35913 Progressive Upright Vacuum
Hi, I was using, and it stopped suddenly. what does it mean? Burnt out?
  • 281 Answers
No not really if something is keeping the brush rolle from turning then the motor guard will keep it fron running .check if the brush roller can be turned by hand and freely if its real hard to turn then the roller bearings are bad or there are carpet strands tide up around the ends of the roller keeping it from turning correctly.feel free to call me if you need help.i don't charge i just like helping people and saving them money in these rough times.314-628-9153
Posted on Apr 23, 2009
My Riccar vacuum was working but then just stopped and won't turn on. I changed the bag even. What's up?
Hi Patty.
Could be:
Power cord. Check esp. strain-relief where cord enters housing.
On/off power switch. Needs strip down & continuity check.
Motor burnt out. Smell if burnt. Strip search.
Carbon brushes inside motor worn. Dismantle & check / renew.
Does this help?
Regards, Clive.
Nov 05, 2017 | Riccar Vacuums
My dyson dc28 brush stopped turning after a pop and smoked. Smelled like burnt plastic. The attachment hose still has suction and is working fine. What happened?
Hiya.
When an object gets under the machine it can
cause the brushbar to suddenly jam. The belt between the motir
and the brushbar however is forced to keep turning
causing the rubber belt to burn an then break.
Jun 01, 2014 | Dyson DC28 Animal Bagless Upright Vacuum
After a few minutes, vaccum emits a burnt rubber smell. Checked the V-belt and it seems fine.
It might seem fine but the burnt rubber smell means that the belt is slipping. This causes friction between the belt and the motor spindle causing the spindle to get extremely hot which melts the inner surface of the drive belt.
Take the belt off and examine the inner side that loops over the brushbar and the motor spindle. You will find that there are sections where the belt has partially melted - they are usually smoother than the rest of the belt.
Belts don't need to break before they need replacing. They just need to lose some tension. This is what seems to have happened in your case and you should replace your belt.
Regards,
BElectric
Dec 17, 2010 | Vacuums
Wet vac motor making noise and smells like burning
Hi I would suggest that the burning smell and the noise will mean that the motor is burnt out. You can get them pretty cheaply from the internet and they are quite easy to fit.
Mar 04, 2010 | Henry Numatic "" Canister Vacuum
While vacuuming with my hoover mach 5 it all the sudden shut down
Hi, If it is warm to the touch, and it just shut down all of a sudden, I would say that the motor has an internal over load switch that is normally closed, and opened to stop from burning this vac out. It is a built-in safety. I would look at the roller for anything that may have hung up, but steady use for an hour just over heated the motor. Let it cool way down. Try and start it. Also, check the plug to see if you may have lost power there also. Let me know please so I can be of any help you may need.
Sincerely,
Shastalaker7
Nov 08, 2009 | Vacuums
I have an Electolux Oxygen canister vacuum and the power head suddenly stopped working. It is only a few months old. Any suggestions.
1. You have to verify if it's simply the belt that has broken and the spinning brush isn't spinning because of it. Place your ear next to the top of the power head to listen for the power head motor. If electricity is getting to the head you'll hear the motor and know to inspect the belt.
2. If the motor doesn't run, look at the electrical pin connectioins in the pipe from the hose to the head. Are they burnt? If yes a new wand is needed. Also check the electrical connections in the hose handle and make sure they are not burnt.
Let me know if this helps
Oct 09, 2009 | Electrolux Oxygen Z5540 Pet Lover Vacuum
Beater bar stopped working
hi welcome to fixya you need to replace belt if belt is ok than you burnt out the motor please check belt first as it is cheaper thank you for useing fixya please rate
Mar 02, 2009 | Kenmore 23313 Whispertone Bagged Canister...
Vacuum motor shaft too hot
Check the brush roll ends, will they turn easily or is one frozen. If so, you need to replace the brush roll. If the motor turns on, it and the belt are trying to turn the brush roll and can't. Also check the ends where the brush roll sits in and make sure it hasn't overheated and melted., If it did you will have to replave the base.
Mar 11, 2008 | Dirt Devil Featherlight Bagless Upright...
Kenmore 35912 / 35913 Progressive Upright Vacuum Logo
200 people viewed this question
Top Kenmore Vacuums Experts
Chris Nomland
Chris Nomland
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
