Question about Leviton (102-5G108-RW5)
How to wired an alarm to a leviton 47603 - Leviton (102-5G108-RW5)
  • 2,460 Answers
You don't. http://www.4.midlightelectric.com/acatalog/Leviton104563.html
Traditionally alarm connections go on an RJ-31x in FRONT of the panel.
http://www.systemswebstore.com/faqfiles/alarm_system_phone_connection.htm
(thanks to whoever lent me these web sites. It's not an endorsement)
Carl
Posted on Dec 06, 2008
How to wire a leviton 5634 for agarbage disposal
If you are replacing an existing switch, either replace one wire at a time, or write down the wire colors from the old switch.
or look here: http://www.leviton.com/OA_HTML/LevitonSearchResults.jsp?kw=5634+wiring+diagram&tbon=D
May 16, 2014 | Leviton R03-5634-A Two Single-pole...
Can I use the leviton 15A-125V adapter to a 220V wall socket?
Not an adapter. You need a voltage converter to convert 220Vac to 120VAc.
Jan 23, 2013 | Leviton Electrical Supplies
How to reset Leviton 6212H
1) Copy following link to identify Leviton 6200 series 12 hour countdown timer and download manual:
http://waterheatertimer.org/Countdown-timer-horsepower-ratings.html#6230
2) I think you have timer wired wrong:
Copy following link and read ez steps how to wire single-pole timer:
http://waterheatertimer.org/How-to-wire-timers.html
3) Add comment and describe what type switch you are replacing.
Dec 18, 2012 | Leviton Decora Timer - 6212H-W - Alabaster
What model Leviton GFCL should I use? My wire is a 600 volt 12/2 with ground. Said wire feeds other GFCL outlets.
Any off-the-shelf GFCI sold today with work on 12-2 wire:
By code, 12-2 wire should be connected to 20 amp circuit breaker, but typically most switches and outlets wired to that circuit are rated 15 amp. Amp rating is printed on electrical devices.
Leviton 15 amp 7599-W:
http://www.amazon.com/Leviton-7599-W-Receptacle-Feed-Through-SmartlockPro/dp/B000VYO9MU/ref=pd_cp_hi_3
Leviton 20 amp 7899-W
http://www.amazon.com/Leviton-7899-W-SmartlockPro-Indicator-Wallplate/dp/B000N663PM/ref=pd_cp_hi_0
Wiring:
http://waterheatertimer.org/How-to-wire-GFCI.html
Jun 17, 2011 | Leviton R01-7299-0NI Switch And GFCI...
Need instructions to set my timer. Where can I find these?
You posted under Leviton 6124
If this is not your timer, add a comment.
Also see Leviton timers at:
http://waterheatertimer.org/Leviton-timers.html
Leviton 6124 manual
http://waterheatertimer.org/images/6124-manual.pdf
Wiring for 6124 timer:
Add a comment if you need help wiring this timer
Nov 30, 2010 | Leviton 24-Hour LCD Programmable Timer,...
I replaced my old 3way toggle switches with the LEviton 5613 3way lighted rocker switches. Wired exactly the way the older toggle switches were wired. Switches work fine just like the older ones but one...
http://www.leviton.com/OA_HTML/ibeCCtpItmDspRte.jsp?item=4044§ion=10103&minisite=10025
The Leviton page for Leviton 5613 does not have a troubleshoot.
Manual shows simple wiring diagram.
3-way switches will not operate lights if switches are wired incorrectly.
Check your ground wire is connected.
Leviton 5613 series is illuminated.
Check that both switches have 5613 number.
Swap switches and see if problem is inside switch.
Nov 13, 2010 | Leviton 5613-2WSP Grounded Switch
I am trying to replace a two wire light switch(both white) with a leviton photoelectric 3 wire motion activated light control(red, black and green). I am trying to determine which wire goes to which?
one of the white wires has power on it constantly....that wire connects to the black wire of the leviton.......the other white wire which has no power to it is going to whatever needs power so that wire connects to the red wire of the leviton....the green wire connects to the metal box where your mounting the leviton.
Feb 08, 2010 | Leviton Decora Light Dimmer Switch
A client of mine has a Leviton 4 port Internet gateway. It's serving up DHCP to four connected computers. It's uplink is connected to a wireless Linksys router, which is, in turn, connected to a cable...
If you don't have physical access to the equipment, the shortest and easiest way to configure your leviton gateway would be to connect the linksys router to one of the numbered ports rather than the WAN/uplink port. That would bypass the DHCP server of leviton, however, you will have to do away with one of the PCs connected to leviton.
Please contact me for further clarification, if needed.
regards
Sandeep
Nov 25, 2009 | Leviton 10/100 Base-T Internet Gateway...
I have a black and white wire to hook to. leviton has black, blue and white. green also but thats a ground. what do i do with the blue wire? this is a single switch to a gfci then to outside lighting....
The blue wire is the switched hot wire coming from the leviton.
So:
black hot/source to black leviton -- blue leviton to black for light fixture or black "line" on GFI -- all whites connected together.
Charlie
P.S. If the GFI is only powering a light fixture, it is not needed.
Sep 23, 2009 | Leviton 6124H-A 6124H-A Decora LCD Timer...
Leviton (102-5G108-RW5) Logo
76 people viewed this question
Top Leviton Computers & Internet Experts
ashburton
Michael Galve
Michael Galve
Are you a Leviton Computer and Internet Expert? Answer questions, earn points and help others
