Question about AOC LM-727 17" LCD Monitor
Monitor Settings Adjust Itself
I've been using my monitor for quite sometime now, but lately, all the monitor settings start to go wild on the first 30 minutes after it's turned ON. the jog autatically selects any settings available on the screen, then later it increase/decrease, then selects another adjustment and increase/decrease value. i could not controll it. sometimes it just turn off by itself. any ideas?
  • jgkiran Aug 03, 2008
    monitor settings appear automatically...
  • Jonathan Estrada Dec 08, 2013
    and somehow you might think a ghost is pushing some buttons :) this is an OSD controller IC issue. typical AOC problem. your chip needs to be replaced but its way more practical to buy a new one.
    Scholar:
  • 78 Answers
Try connecting some other monitor to the system, if u do not face the issue, then issue is with the monitor, some hardware fault.
Posted on Apr 22, 2010
I cannot get the monitor to turn off, using the power button. I have to unplug the monitor to turn it off. ever heard of this problem before?
sometimes your settings through your computer can control this, look at your monitor settings and adjust your time needed for the computer to tell your monitor to shut off.
Apr 10, 2017 | Power Computers & Internet
Tip
How to adjust or change a monitor's refresh rate.
If you've ever used a CRT monitor, you know that fine-tuning your refresh rate is essential. The refresh rate of a display is measured in Hertz (abbreviated Hz) and specifies the number of times per second that a display is illuminated.<br /> <br /> Setting the refresh rate to 60 Hz - a common default value - tells the monitor to redraw itself 60 times per second. For most people, that setting on a CRT monitor is too slow, resulting in an annoying flicker that can cause headaches, eyestrain, and fatigue. Bumping the refresh rate to a higher number can reduce that flicker, as long as the monitor itself can handle the faster rate.<br /> <br /> If you're using an LCD monitor then a safe refresh rate lies in the 60Hz-75Hz range. A greater refresh rate when it comes to LCD's means greater performance.<br /><br /> <b><u>How to adjust the refresh rate</u></b><br /> Firstly you will need to right click on your desktop background and select <b>Properties</b>.<br /> <img src="slasher_x_72.JPG" /> <br /> This will display the <b>Display Properties</b> window as show below.<br /> <img src="slasher_x_73.jpg" /> <br /> You will need to click the <b>Settings</b> tab.<br /> <img src="slasher_x_74.JPG" /> <br /> Once in the <b>Settings</b> tab you will need to click on the <b>Advanced</b> button.<br /> <img src="slasher_x_75.JPG" /> <br /> Then click on the <b>Monitor</b> tab.<br /> <img src="slasher_x_76.JPG" /> <br /> Here you can change the screen's refresh rate. Make sure the box next to <b>Hide modes that this monitor cannot display</b> is ticked. After you have selected the refresh rate you wish click <b>OK</b>. It would be a very good idea if you have the user's manual for the monitor handy just so that you can see what the manufacturer suggests the refresh rate should be set to.
on May 31, 2011 | Computers & Internet
My computer turns on and all I get on the monitor
Can you use the monitor controls to adjust the Input selection, color settings and display settings. You may have the wrong input selected. Another possibility is the resolution output from your PC will not work on your monitor so it shuts down to protect itself from overdriving signals.
Oct 10, 2014 | Computers & Internet
Horizontal lines have started appearing, running all he way across the monitor screen....several close together abour 3 inches from the top, and one, sometimes two, about an inch from the bottom... I have...
what you are seeing ithe horizonal sync lines, have you tried to adjust the settings on this monitor, I would try turning down the brightness, and the contrast. There should be a menu button on the monitor to adjust it.
Nov 18, 2010 | Soyo DYLM2286 Monitor
The right hand 1/3 of the screen is blank. Cannot get anything to display
sounds like you have to set the monitor resolution using your computer. right click desktop... graphics options. or Properties. look for Resolution slider. Move it around. press apply. see what happens. if it now fits but is fuzzy. change the refresh rate eg. 60 Hz or 75 Hz. On the monitor itself there is typically a button that allows you to move the image to fit the screen, quite often these settings are inadvertently played with by children ect. look for buttons/ menu's on your monitor itself. play with the settings .
Aug 24, 2010 | E-Machines eMachines Monitor E15T4
Monitor fs740 contrast is 0%, can't adjust it.
in your monitor settings you should have a default settings selection button you can Select and it will or should set your monitor to default . If it doesn't work , you have a problem with the monitor itself .
May 12, 2010 | Compaq FS7600 17" Flat Glass Monitor
My onscreen image is a bit taller than it is wide. A square shape would be taller. Can I get an update for my xp computer of a video card driver?. My Gateway fx530b was purchased Aug. 2007.
The problem is probably a setting with the Monitor itself. You can adjust the horizonal and vertical settings on the monitor itself. Sometimes it is accessed by a menu button on the monitor or by a knob.
Look around on the monitor and see if you can adjust it there!
Nov 22, 2008 | Gateway Computers & Internet
Monitor gives recomended settings then puts itself in sleep mode.I cant even get the computer to go into safe mode.
Your computer is in hibernate mode.
Start up your computer and do this
Start >> Control Panel >> Power Options
Select the tab "Hiberbate" >> Uncheck hibernate mode
Also you can adjust there your power setting and monitor settings
Nov 05, 2008 | HP Computers & Internet
Portrait display
Hi...there!
Sure you can... just go to your toolbars bottom R/H side and look for a Graphic Card settings for example ( Nvidia or ATI settings) Then right click and look for a rotation settings from there just followed the settings... To adjust the display, open your on screen display on your LCD monitor and look for Auto Adjust by using (- +) buttons... Have a nice day!
Oct 07, 2008 | Samsung SyncMaster 204B 20.1" LCD Monitor
AOC LM-727 17" LCD Monitor Logo
152 people viewed this question
Top AOC Computers & Internet Experts
Raj Patel
Mohammed Ebrahim M
Mohammed Ebrahim M
Are you an AOC Computer and Internet Expert? Answer questions, earn points and help others
