Question about Audiovox Car Docking Station for DT85 Portable DVD Player DS85 Car Video Player
It does not load disc
Everything seems to work but it does not allow loading any disc, the door is closed
0 characters
1 Points
Avic Z3 open monitor will not close
have you check if there was any stuck parts on the unit... or a mis aligned mechanical contacts..?
Jun 18, 2008 | Pioneer AVIC-Z2 Car DVD Player
My alpine iva-d300r will not even load any disc i
sounds like it.. try to find the small reset button usually on the face of the radio or sometimes behind the detatchable face. you can only push it with a pen this will reset the system and may reset the cd mechanism
Feb 05, 2010 | Alpine IVA-D300 Car DVD Player
I load disc, it spins but no pic/sound
you better take it to someone professional in the domain as your portable dvd player seem to have problem with its laser
Oct 04, 2009 | Car Video Players
DVD player will not play disc.
If you are loading a store bought DVD and that it what it say's. The transport needs to be replaced. roughly 150-200. If you are loading "burned" DVD's the format may be wrong and the unit cannot read it. Best suggestion I can give you is to first buy a "Laser Lens Cleaner" on that uses fluid. Any electronics store sells them for 15-20. Run it thru the unit a couple of times then try a clean, store bought DVD. If it plays, problem solved. With your DVD's, if you have any liquid car polish like mother's or meguiars, put a couple drops on the disc and spread around with your finger, let it set a couple then buff off with a microfiber towel. This works wonders for old scratched cd's and dvd's and helps protect new ones from getting scratched. As for the Lens cleaner, run it thru every product you have that uses discs 3 or 4 times a year, it's the best preventative maintance and only maintanance you can do on a CD player DVD or PC. Hope this helps
Jun 24, 2009 | Delphi 10.2" FLIP DOWN MNTR/DVD...
Put in disc also same same
Google manual and model number to download a manual.
It sounds like the DVD player itself is not working, maybe you can see if the laser unit moves if you hold down the "closed/open" switch, DO NOT LOOK directly into the laser, it will damage your eyes, tilt the unit so you look in from "the side".
If it does not move try to touch the slider to see if it just needs a little help, remember it is fragile, it is positioned and moved by small plastic finns (do not know if it is the right word).
May 02, 2009 | Dual XDVD270 Car DVD Player
Jensen VM9312 not loading DVD.
If it reaeds the cleaner... then try another disc. 20-30 seconds is a long time to looad a disc...
If the new disc does not work either , I would suggest resting the deck .
If reseting does not help , it is still under warrantee. so have it serviced.
Dec 11, 2008 | Jensen VM9020TS Car DVD Player
Jensen 9410 will not load or eject
i had my jensen three weeks everything was okay until all of sudden the unit wounld not load or eject CD's or DVD's
Mar 20, 2008 | Jensen VM9410 Car DVD Player
Won't play disc, reads no disc
Hi, well I see this type of thing in my Lab alla time unfortunately it sounds if ya DVD has gone faulty... an all too common occurrence these days.. the Laer seem to be very "Frail" You could try a cleaning Disk, but they seldom work.. but sometimes? all ya can do is replace it with another good DVD.. OR if thats not possible use any AV input and connect a remote DVD player that way.. a bit of a hassle, but it's a work around anyway.
Aug 04, 2007 | Sony MV-900SDS Car DVD Player
It's a problem that a lot of people that have this unit is having, the solution is repair center and not to purchase this unit anymore it problem that Jensen audiovox need to use better parts
May 05, 2007 | Jensen VM9411 Car Video Player
Car Video Players Logo
14 people viewed this question
Top Audiovox Car Video Players Experts
Michael Thomas
Michael Thomas
Jaime Hernandez
Are you an Audiovox Car Video Player Expert? Answer questions, earn points and help others
