I have just purchased a dlink dir 635 router and am trying to set it up on my Bigpond cable broadband internet. previously I had only a Motorola SBG900 gateway between cable and pc. I now have the new router between this gateway and pc. I have "successfully configured router" but it then doesn't connect to internet. The internet works fine if I take the router out. Any help would be appreciated. regards, Frustrated.
    Novelist:
  • 171 Answers
The motorola sbg900 is acting as a router itself. I'm assuming this is what you've got? http://promo.bigpond.com/homenetwork/html_new.php
So first, go into your d-link router settings and make sure the THIRD number in the IP address is the same as your modem's ip address. This third number is the "subnet", and it must be teh same for both router and modem.
e.g. if your motorola users ip 192.168.2.1, make sure your d-link is set to 192.168.2.2. Make sure the fourth number is different, but the 1st 2nd and 3rd numbers are the same.
You can figure out what your motorola's ip is by connecting it to your computer, make sure your interent is working, and then run "ipconfig" from a command prompt window. Look for the "Default Gateway" IP. That's your motorola's ip address.
Once the IP addresses match, go into your router's settings and disable the "DHCP server".
Next, plug a network cable to go from one of the LAN ports on your motorola to one of the LAN ports on your d-link. Note that it is LAN port to LAN port. The "internet/wan" port on the d-link is never used for anything.
At this point your d-link will be operating like a "Switch", it knows it is just an extension of your existing network and it won't collide and cause you problems like it was before.
Posted on Dec 06, 2008
I Need Installer For My D-Link DIR-600 Wireless Router
There are ways to configure router:
1. Is by using Installer using a CD came with it or
2. Access routers Graphical User Interface (GUI) through Internet browser. Just type in on the address bar the IP address of your router. For dlink it has a default IP of 192.168.1.0.
Note:
Before accessing router configuration make sure that the yellow cord (ethernet cable) is connected directly from the router to your computer.
Sep 14, 2013 | D-Link Dlink Dir-600 Wireless Router...
How can i change the password of my D-link DIR-635 router
To change any settings on the router, you will need to access the router set up.
Do you have any computer connected to the router with the cable?
If not then you will need connect the computer to the router.
open the setup page and change the settings.
Click Here for step by step instruction
Dec 05, 2009 | D-Link / RangeBooster N 650 / DIR-635 /...
Hi i have dir-365
Try resetting the router . Press the reset button for 10 seconds and after 10 seconds unplug the power cable but continue pressing the reset button for another 30 seconds after 30 seconds plug in back the power cable and continue pressing the reset button for 10 seconds and release it after 10 seconds.
try to open an Internet browser and type in 192.168.0.1 on the address bar. It should give you the DLink page. Once you have that configure your connection.
Jan 11, 2009 | D-Link / RangeBooster N 650 / DIR-635 /...
VPN problem with Dlink DIR-300
Update your firmware to the latest. I had the same issue and the issue is gone after the upgrade.
Dec 31, 2008 | D-Link / RangeBooster N 650 / DIR-635 /...
Dlink dir 300 internet problem
First you have to make sure that you connected it correctly. the cable coming out of the modem should be connected to the single port (Internet port) at the right when facing the back of the router.
All computers that are wired through it should be able to access the internet. if one of your computers cannot access the internet you may want to check the IP address that you are getting. (go to a command prompt and type ipconfig).
If you are connecting a wireless computer check the wireless security setting which you can find at the configuration (setup) page of the router. to access the configuration page check the owner's manual.
Oct 08, 2008 | D-Link / RangeBooster N 650 / DIR-635 /...
D Link DIR 635 router conection internet
Normally, all ruters are hubs as well. if you want to connect it as a hub only; try connecting only the ports minus the WAN port that goes to the DSL modem. In this case the router will behave just like a hub.
Nov 11, 2007 | D-Link / RangeBooster N 650 / DIR-635 /...
DIR-635 can't access the internet
I think you have wrong configuration of your router.
1. Some xDSL Internet Service Providers may assign a Fixed IP Address for your Broadband router. If you have been provided with this information, choose this option and enter the assigned IP Address, Subnet Mask, Gateway IP Address and DNS IP Address for your Broadband router.
2. If you connect to the Internet using an xDSL Modem and your ISP has provided you with a Password and a Service Name, then your ISP uses PPPoE to establish a connection. You must choose this option and enter the required information.
Nov 04, 2007 | Computers & Internet
Hi, I am assuming that you can connect to your router's web based interface (192.168.0.1). On a PC LAN wired to the router, open a browser; Type "192.168.0.1"; Log-in username/admin and password/(blank); Go to Tools > Misc and the option to select the WAN speed (bottom); Lock the speed down on the WAN port of your router to 10Mbps (Some versions do not have this feature). Hope this works for you. If not pls post back with your modem brand/model. You may also want to log the IP settings (IP Add, Subnet Mask, Default Gateway, DNS Servers) of the PC that is directly connected to the modem when you can access the Internet when not using the router. Good luck and kind regards.
Oct 02, 2007 | D-Link / RangeBooster N 650 / DIR-635 /...
Computers & Internet Logo
David Payne
David Payne
