Question about Toshiba PA1381U-1ETC Consumer Headphones
We want to install win Xp in Toshiba Satallite A205-S5825
When we booting my laptop from winxp bootable CD we gating Errore
Setup Did not finde any hard disk drives installed in your computer
Pl Help me outfrom this problems
    Problem Solver:
  • 17 Answers
Depending on the model of your Toshiba, it may have an unsupported hard disk controller which requires that you load a disk driver from a floppy disk by pressing F6 when prompted during the boot of an XP installation CD. If so, you will need to download the apropriate driver and put it on floppy diskette, Of course a floppy drive will also have to be available during the boot. (enable USB legacy support in BIOS if you use a USB floppy drive)
Alternatively, check your BIOS settings to see if the disk controller can be set to operate in ATA mode rather than AHCI mode. ATA mode should work with the XP cd-rom.
Posted on Mar 26, 2009
How to get another product key for toshiba satellite A205-S5825?
there should be a product code on the bottom of your laptop, maybe its behind the battery on a green and blue xp sticker
Mar 23, 2013 | Toshiba Satellite A205-S5825 PC Notebook
I have a toshiba satellite a205-4707 when i got it it would freeze at startup i had a ancient copy of xp pro sp1 i could only install with power cord unplugged.even after install if i plugged in power cord...
http://www.4shared.com/file/oE15gXll/killdisk_and_boot-cd-iso.html
get this from my shared drive(read instructions in there)
and wipe your disk clean (Warning...this process will make you lose all data on disk so be careful, if posible backup all critical data that you need)
once done install WinXP SP3(get a Windows XP cd from a friend or download a pirated copy from net) look for "WinXP SP3 piratebay" in google
when installing WinXP make more than 2 partitions (C, D, E)
Install WinXP in C
once done, let Windows boot and show Desktop
install WinVista or Win7 in D
use E for saving your critical data
Nov 29, 2010 | Toshiba Satellite A205-S4617 Notebook
Sir i have try to install win xp in my aspire 5740 acer laptop , in which window7 is previously installed. I want to install winxp in it just give me the steps how i can do that.
1. You should have a winXP bootable installation CD
2. You should enable boot from CD setting in BIOS
3. put your XP cd in to the cd reader
4. Startup the computer
5. Follow the instructions
Format the partitions or
completely drop and recreate partitions then formt
See this video: http://www.ehow.com/video_4992223_install-windows-xp-computer.html
See this page:
http://www.5starsupport.com/tutorial/xpinstall.htm
Aug 20, 2010 | Computers & Internet
Touch pad not working
just restart machine in bios setup ckeck that touch pad option is set to enable. and also check some of the laptop has one switch on keypad or on the top of touchpad for on/off utility is set to on
Dec 27, 2009 | Toshiba Satellite A205-S5823 Notebook
Toshiba satellite A205-S5804 VIsta to XP
I had the same problem to make dual boot on a vista loaded laptop with XP. I use nlight to splitstream the RAD and it was successfull.
  • Try this link, there is a very nice article regarding this problem with pictures.
  • You can also try bootdisk to make a bootable CD then start with this CD and try to run your setup. Click here for bootdisk
Please post your feedback.
Thanks
Iqbal
Jun 01, 2008 | Toshiba Satellite A205-S4617 Notebook
Installation
insert xp bootable cd
hit delete or F2 to enter setup while starting computer
select boot priority or first boot device as "cd rom"
exit saving changes.
boot only 1 time from cd and then follow the installation wizard steps.
Nov 16, 2007 | Computers & Internet
Downgrading from vista to xp sp2
I know this problem, The HDD is a SATA disk, win XP setup cannot identify a SATA controller on it's own you need to load the driver (from a disk) so you may need to download it first. I think this is the correct link http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=ob-51521-1&lc=en&cc=us&dlc=en&product=3369431&os=228&lang=en extract the files and burn to a CD or Floppy then run win XP setup by booting from CD you should see in the begining of win XP setup from CD it prompt you to press (I think) F2 to add RAID or SCSI Controllers, (this prompt is at the bottom of the screen) Then follow the propmts to load from the disk you made earlier. you should be able to select the controller from a list. (short list) you should then be able to continue and hopefully Win XP setup should now be able to see your HDD and give you choices about which partition (as per normal) you want to remove all partitions before installing winXP (you can then make whatever partitions you wish) Hope this helps
Aug 06, 2007 | Compaq Presario 1200XL104 Notebook
Toshiba PA1381U-1ETC Consumer Headphones Logo
492 people viewed this question
Top Toshiba Audio Players & Recorders Experts
James DuPont Jr
James DuPont Jr
 Grubhead
Grubhead
Are you a Toshiba Audio Player and Recorder Expert? Answer questions, earn points and help others
