Question about Sony PlayStation 2 (PS2) Console
Progressive scan on ps2 doesnt work
I bought component cables for the ps2 and wired it up to my lcd monitor (an lg with 1080i max resolution and component and hdmi imputs) ,changed the settings in the ps2 menu to y/pb/pr and everything worked until i tryed to turn on progressive scan in the god of war II menu...then,the screen went black and it wont turn it on.What do i do?
Gkhdthkdtyicdghmdtyidghmdty
Posted on Dec 06, 2008
Tip
What is 1080i and 1080p what cable and HDMI version do I need
So you've got your new Flat Panel Plasma TV and Blu Ray DVD player what cable should you use, am I really 1080p HD Ready ?
So here it is in laymans terms
HDMI
stands for High-Definition Multimedia Interface. It's a digital interface to get the best, uncompressed digital picture possible.There are currently five versions that are setup as improvement on the last since its introduction in 2003
The first high defintion TV's were classed as HD Ready only the resolutions were set at 1280x720= 921,600 just under a MegaPixel per frame and were called 720p and are capable of viewing only 1080i signals with the correct cable the latest version is called HD Ready 1080p the HDMI standard for this is HDMI 1.3 which means that unless you have a TV that is rated for HDMI 1.3 your 1080p Blu Ray player wont work in full 1080p there will be no picture and the players HDMI output will have to be reduced to 1080i this can be done in the Blu Ray Players settings so you can still watch the video on your older HD Ready television
1080i vs 1080p - Basically both formats have the same number of Pixels 1920 across the top and 1080 across the side this gives a total number of pixels (1920x1080=2,073,600) aka 2 MegaPixels per frame assuming that the aspect ratio is 16:9 this is the same as a basic digital camera or phone jpeg.
You might also see written like this 1080p24 means that it originated from a progressive scanned 24 frames source and has become an established production standard Cimena and for your Blu Ray player will also have this setting if you require it.
When Compared to standard DVD with and aspect ratio of 4:3 which has 720x576=414,720 this is an increase of 500% in the resolution alone over the now humbled DVD Video format with interlaced video
The difference between the two is that one is interlaced (like normal DVD-Video) and the other is progressive OR non-interlaced scan which means that 1080p requires way more transfer speed than that of the 1080i format.
So the main disadvantage of progressive scan is that it requires higher bandwidth than interlaced video that has the same frame size and vertical refresh rate this is why DVD-Videos incorporate the interaced video due to the lack of a digital inteface like HDMI 1.3 rated cable is required to transfer this higher speed of transmission in contrast the 1080i signal requires a much slower speed and HDMI 1.2 rated cable might work.
As far as interconnects go you can still connect your full 1080p Blu Ray Player to your 1080i Plasma TV using the three cable interconnect that comes with the players but for the best possible connection you need to use a HDMI cable with gold plated connecitons. Prices range from £15 right upto £60 and beyond if you go with Monster Cables however the £15 version if it says rated for Blu Ray it will work just fine so save yourself £40.
HD Ready
HDMI 1.0 - combines a digital video signal (standard or HD) with a two-channel audio signal over a single cable used with the HD Ready
HDMI 1.1 - This version adds the ability to transfer not only video and two-channel audio over a single cable, but also added the ability to transfer Dolby Digital, DTS, and DVD-Audio surround signals, as well up to 7.1 channels of PCM audio.
HDMI 1.2 - This version adds the ability to transfer Super Audio CD signals in digital form from a player to a receiver most Home Theatre Systems require at least this type of cable for full capabilty however you can use a v1.3a cable works just as well
HD Ready 1080p
HDMI 1.3 and HDMI 1.3a These versions include improvements in both audio and video capability. With the advent of Blu-ray Disc it adds the ability to transfer the digital bitstreams for the new high resolution audio formats in addition to the standard 24-bit color depth we are used to, HDMI 1.3a has the ability to transfer color depths up to 48-bits, and can accommodate resolutions much higher than the 1080p resolution standard that is in use today on all TVs that are HD Ready 1080p
HDMI 1.4 and HDMI 1.4a HDMI version 1.4 adds practical enhancements for HDMI connectivity. If home theater components, such as HDTVs, Blu-ray Disc players, and Home Theater Receiver, the next step in HDMI of the future is covered by the v1.4a cables wrt to speed.
on Apr 15, 2010 | LG 47 in. Flat-Panel LCD HDTV
I have a 22" Westinghouse
Change the settings on your HDMI output to 720 progressive for resolution. The tv likely cannot handle the 1080 resolution, or the tv can only use interlaced (1080i or 720i) format.
Aug 21, 2011 | Westinghouse 22" Widescreen LCD Flat Panel...
Is this TV digital
This is not a digital TV. This TV has only an NTSC (analog) tuner. A converter will be needed to tune digital broadcast TV stations, your CATV or satellite company supplies a converter to allow this set to display programs.
The display is limited to "480P" resolution, called "Enhanced Definition", which is a step up from the traditional NTSC standard of "480i" resolution or "Standard Definition". ("P is "progressive scan" and "i" is "interlaced scan"). Progressive scan provides a better picture quality when compared to interlaced scan images. High Definition or "HD" is a signal that contains data that allows display of images with 720P, 1080i and 1080P resolutions (the larger numbers indicate more information, or higher picture quality). Your TV will receive all signals, SD, ED and HD, but will down convert to ED. Signals can be brought into the set via 2 composite-video connections, 1 each component- and S-video, an RF antenna/cable-box/VCR input, and a 15-pin D-Sub analog RGB input. More info can be found here.
I hope this helps and good luck! Please rate my reply. Thank you.
Jun 01, 2011 | Philips 15PF7835 15 in. LCD Television
How do I go from 480p to 1080dpi on my 65inch HDTV
If you're using an HDMI cable your display will automatically adjust the settings based upon the video source. Make sure that your source is capable of outputting 1080p. If it's an HD Cable Box or DVR, the maximum resolution it can display is 1080i. If you have one of these HD boxes, set it to only display 1080i as there will be a delay every time you change channels from a channel that is not naturally at 1080i.
If your source is a standard DVD player, it can only display images in 480i (or 480p if it is Progressive Scan) and therefore your TV will display the picture in 480 resolution. If your source is an upconverting DVD player it will display up to 1080p however, Keep in mind that DVD's are in 480 resolution and that regardless of upconversion (or upscaling, though improved, the picture will not be in HD.
The only way to achieve a true 1080p (not dpi... that's dots per inch... that's a printer term. The "p" is for Progressive Scan as opposed to an "i" for Interlaced) is from a 1080p source, i.e., a Blu-Ray disc player playing a Blu-Ray Disc with the use of an HDMI cable. Component Cables can achieve 720p/1080i only with your TV as it does not support 1080p over component cables.
As an aside, there are some media players that support 1080p output and some DirecTV Boxes and DVR's d oas well for 1080p Pay Per View movies.
Nov 23, 2010 | Mitsubishi WD-65733 65" HDTV
NO HIGH DEFINITION
  • HDTV capable: Yes (up to EDTV, 480p)
  • Jul 10, 2008 | Akai PT5492S 54" Rear Projection...
    Only get 480p
    Hi.
    Your friend is wrong you will get same resolution of 1080i whether you use component or Hdmi.
    But you will need a high def input to tv in order to get this resolution EG high def cable box or satellite.
    http://dysonmanuals.llc.nu/
    Mar 24, 2008 | Sony KLV-S32A10 32 in. HD-Ready LCD...
    Setting ***.
    You will have to change the dvd player resolution to 1080i (or change resolution for each individual disc), because:
    a) there is no way to change the resolution manually on this television
    b) this TV maxes at 1080i, hence negating most of the utility of using an hdmi cable (Of course, hdmi cables are much easier to hook up, less messy than component cables; so all is not lost)
    Mar 19, 2008 | Philips 32PFL7332D 32 in. LCD HDTV
    Screen flicker when watching 1080i
    Component video has a max resolution of 720p. in order to use 1080i or p you have to use hdmi or dvi connections. That is why you get the flicker.
    Dec 08, 2007 | Onkyo TX-SR304 Receiver
    No picture using component on Toshiba 32HL66
    It may be a synch issue. Make sure your component input is set for the proper type of output. Your XBOX 360 is likely set to 1080i, but your DVD and PS2 are only 480i (or maybe 480p for the DVD if progressive scan). Sometimes component inputs are 'self adjusting' to the signal, but others require manual setting.
    May 30, 2007 | Toshiba 32HL95 32 in. LCD TV/HD Combo
    Sony PlayStation 2 (PS2) Console Logo
    108 people viewed this question
    Top Sony Video Game Consoles & Games Experts
    Zhenya Ogorodnikov
    shaun taylor
    marley mcelhinney
    Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
