Question about Kenmore 53642 / 53644 Side by Side Refrigerator
Hello I have a Kenmore side by side refrigerator and the water line will not stop running. I don't have to push anything and it just runs. I can't leave my kitchen because it will flood my kitchen floor if left unattended. We are trying to shut the water off and it still is going through the water line. Is there anywhere on the frigerator where we can shut the water off without having to throw away the frigerator.
My ice maker is not working. It gradually stoped working
Posted on Dec 10, 2008
Hissing sound from refrigerator after water filter changed (Kenmore, side b side, 4 years old)
Mabe there's some air in the line. Let the water run a bit and see if the hiss stops.
May 24, 2014 | GE (PSS26MSRSS) Side by Side Refrigerator
Cold water dispenser wont stop running
Possible air leak on water tub connection. Replace water line adapter located underneath freezer door upper hinge. Let me know if that helped.
Oct 24, 2013 | Kenmore 57029 Side by Side Refrigerator
Kenmore mn. 106.54546400 suddenly does not make ice cubes
make sure water line is turned on. make sure ice "full" lever is not pushed up. if these don't help, it may be water inlet solenoid.
May 08, 2012 | Kenmore Side by Side Refrigerator
Kenmore side by side ref model #58582891 water line leaking in bottom front of refrigerator, replaced the filter housing, stopped the leak that went into the drip pan. Water drips in front when push the...
The drain in the freezer behind back lower panel
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? The defrost water
overflows into the ref. or freezer
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Aug 11, 2011 | Kenmore 73502 / 73504 / 73509 Bottom...
Maytag side by side fridge has ice forming in bottom of freezer and leaking onto floor in front of freezer door
Hello, Thank You for using FixYa. I will be helping you today.
You have a frozen drain. You need to remove the back panel in the freezer. Do not touch anything behind the panel and don't poke anything. You need to remove as much ice from the bottom as you can. Then use boiling water to pour in the bottom section under the evaporator,I would put a towel in the unit to help catch the water. Keep adding new hot boiling water until the drain clears up and the water starts to drain. It can take a while sometimes the whole tube will freeze. You can add a duckbill to the end of the drain hose behind the unit to help stop this from happening part number
8055306 Just push it on the end of the drain line.
Thank You and please rate my answer if it was helpful..
Jun 16, 2011 | Maytag MSD2756G Side by Side Refrigerator
ICE MAKER STOP WHEN FILTER GOT CLOGED
Run the water from the frig for a while to make sure the filter has run out all the air. The filter needs to fill with water first and then fill the line to the icemaker before you will get ice.
Apr 29, 2009 | Kenmore 57029 Side by Side Refrigerator
No water
hey we got this one.the buzz is the water valve solinoid energizing when you push the paddle for chilled water,so power is passing thru switches in your refer and getting to the water valve.[good]then we need the water to do its thing,and even though you said you changed the filter[i would'nt have yet],because there was work going on for the water lines.there may have been tons of minerals broken loose.the water valve also has screens to catch minerals and stop them from entering water valve.some water valves are not cleanable.if yours not im sorry replce the valve.if it is you will see the way as you inspect..................but heres a very important matter.before you replace valve,filter or anything that has been blocked by a mineral blast,flush your lines in a bucket.other wise you just recontaimanate with whats still in the lines.i know it took a lot of words to say a little.and it didnt come out just as i was thinking it but i hope that helps.God bless ,tom
Jan 06, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore side by side with ice/water in the door
Hello Mike,
I need more information. What model # do you have. If the model # starts with 596, you most likely have a locked up compressor. Give me a little more information on what sounds you may hear or anything else you may notice about the running of the refrigeratior. Age?
May 26, 2008 | Kenmore 52632 / 52634 / 52639 Side by Side...
Kenmore Coldspot Side by Side Model 51559101
I also have the same refrigerator model 106.56566400 and periodically when the power goes off in the house the refrigerator & freezer will stop cooling. Try pushing the on/off button located inside the refrigerator to the left of the digital temperature controls. Hold the button down, this turns the unit off, then press it again to turn it back on. This basically resets the refrigerator, and most of the time works to get the refrigerator cooling again. Try this first before calling a repair man.
Nov 22, 2007 | Kenmore 52632 / 52634 / 52639 Side by Side...
Kenmore 53642 / 53644 Side by Side Refrigerator Logo
139 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
