We have a hp officejet d155xi & our color ink & black & while cartridges do not last long. It was suggest to me that the print heads may be on their way out and it may fix the problem. Is this probable & how much would it cost?
    Problem Solver:
  • 34 Answers
You may try and change the setting in the printer and fax option in the control panel.
change printing preferences to Fast Draft this will help you to save ink catridges.
please do let us know about how you find the solution and do rate it.
Posted on Dec 06, 2008
Why is my hp officejet 6110 printing everything green
You didn't use the HP printer cartridges? I know they are expensive. but the quality is worth it . I trust not a cheaper ink in a quality printer. You may need to check this HP url
Printer Prints Blank Page or Does Not Print Black or Color Ink for the HP...
When you get to Solution four: Use an automated tool to clean the printhead a helpful tip is to repeat the printhead cleaning up to 4 times .
Jan 17, 2015 | HP OfficeJet 6110 All-In-One InkJet...
HP All-In-One 4500 prints YELLOW when Black is SELECTED Could this be a PRINT HEAD PROBLEM?
The inkjet printers print colors as they combine the major 4 colors contained in the cartridges CMYK (or said in words cyan, magenta, yellow and black) in some proportion.
If you print black the printer gets ink from the black cartridge only. If the black cartridge is empty some devices start to print black as a combination of the colors in the color cartridge - for example gets some of the cyan, gets some of the magenta, gets some of the yellow.
In your case maybe some of the other colors are empty too (or the nozzles are clogged) and the printer cannot prepare the correct mixture of colors to start printing black.
I suggest you to change both black and color cartridges.
Hope this helps.
Sep 12, 2011 | HP Officejet Pro L7580 All-In-One InkJet...
Hp officejet j4580 flashing "incompatible
hello
you must purchase original ink cartridges -- not all compatible cartridges are built the same..
i would suggest buying authentica , from HP dealer or reseller
go to www.compluscominc.com, they will help you for sure and let you kno what to buy and how much
CC653AN icon_x.gif Contact Reseller
HP 901 Black Officejet Ink Cartridge - Prints approximately 200 pages (North America)
RoHS: Modified
CC654AN icon_x.gif Contact Reseller
HP 901XL Black Officejet Ink Cartridge - Prints approximately 700 pages (North America)
RoHS: Modified
CC656-30001 icon_x.gif Contact Reseller
HP 901 Tri-Color Officejet Ink Cartridge - Prints approximately 360 pages
RoHS: Modified
please send me 4 thumbs up
Aug 12, 2011 | Office Equipment & Supplies
Can I print black and white without having color cartridges?
You need to have color cartridges installed for your printer to function. You can however print black and white with empty color cartridges. If you do this you may damage the print head and not be able to print in color again. If you can live without color printing I recommend a monochrome laser printer. It will never print color, costs 1/2 as much to print with, won't dry out, and the cartridges last way longer than ink cartridges.
Sep 28, 2010 | HP Officejet 6500 Wireless All-in-One...
HP Officejet Pro L7650 Print head problem
The reason why the printer refuses to print if you get low on one or more colors is that the system runs off negative pressure through the ink lines to the print head. If you were able to continue printing with an empty cartridge you could get air in the respective ink line, disrupt the negative pressure, make it so that that color will no longer print, and require you to get the printer serviced to fix the problem. I own a Cartridge World ink refilling store and I feel this is a good machine (compared to some of the others out there). The only down side with this type of machine is the print heads expiring or getting clogged as you are experiencing. The reason the black is clogged and not the other colors is that the black ink is pigment based and the colors are dye based. The pigment based inks do tend to clog print heads over time. You can try to rehydrate the print head with warm distilled water. if you can't get it working to your satisfaction you can buy a new black/yellow print head for $72. With this type of printer you should print at least one black and white and one color document per week to keep the print heads fresh. If they sit too long without ink flowing through them then they can get clogged and print poorly. I hope this helps belay some of the resentment you hold towards your printer.
Nov 22, 2009 | HP Officejet Pro L7680 All-In-One Printer
Prints only from color cartridges, black ink not working
The problem is in the print head.It's clogged or damaged.You need to replace it.It's part number is C9381A - HP #88 Printhead - Black and Yellow
Nov 01, 2009 | HP Officejet Pro K5400 All-In-One InkJet...
The black ink print is very very faint
Indicates that the printer is using only color ink to create a black color. Check printer settings to see if you can set it to use only black cartridge. Also try printing with only the black cartridge inside if the printer permits, this way you can be sure if the black print head is faulty.
Jul 28, 2009 | HP Officejet Pro L7580 All-In-One InkJet...
HP J4500 color cartridge error
Take the cartridge out and clean the contacts off with something (ie: pencil eraser, your thumb...) That worked for me! I couldn't find a solution anywhere even after chatting with online tech support from HP. Quick and painless! I hope this helps...
May 31, 2009 | HP OfficeJet J4580 All-In-One Laser...
Won't color print
If this is a heavy use machine, then it probably needs to be completely disassembled and cleaned from the inside out. A good cleaning cures most of what ails and inkjet printer.
Inkworks
Feb 18, 2008 | HP OfficeJet 7410 All-In-One InkJet...
Computers & Internet Logo
51 people viewed this question
David Payne
David Payne
