Question about Video Game Consoles & Games
Cant connect hdmi to playstation3 - Video Game Consoles & Games
  • 470 Answers
The 3-Port HDMI System Selector is by all conventional standards a standalone HDMI system selector. It is independently powered, it comes with its own remote, and use with a PS3 is technically optional. Obviously, however, the 3-Port HDMI System Selector was aesthetically designed for the PS3, and it features some nice benefits for PS3 users. For starters, the 3-Port HDMI System Selector doubles as a cooling system with its two built-in cooling fans. Additionally, the system selector also integrates with the PS3 and the included remote can be used for controlling DVD and Blu-Ray playback.
or you can watch it on the video how to connect it
www.youtube.com/watch?v=v_6NiUIanyg
regards JAN_yuanjia rate it pls
Posted on Dec 08, 2008
Playstation3 has sound but no video
Okay, do you have it through a HDMI or AV cable?
Whoever used it before you have the settings on either HDMI or AV, which means if you are using the other one, the video will not come up
Its a bit hard to explain but you should hook up both HDMI and AV and find out which one it is coming through, then change the setting to whichever one you want
Feb 28, 2013 | Sony PlayStation Video Game Consoles &...
I hooked my PS3 to my HDMI cable to get a better visual screen display for my HD movies and games, but display screen went blank and I cant get the commands menu screen, how can I get the menu commands...
You must reset your PS3 in order to accept the new TV configuration.
  • If the video output settings on the PLAYSTATION3 do not match those of the cable or TV in use, there may be no picture. If the screen goes blank, turn off the system.
  • Then, with only the PLAYSTATION3 and the TV connected, touch the system's power button for more than 5 seconds to turn the system back on. The video output settings will automatically be reset to the standard resolution.
  • Hope this helps please remember to rate my response, thanks!
    OpenSource13
    Jun 16, 2012 | Video Game Consoles & Games
    I get no signal from my playstation3 to my tv. the ps3 terns on but i cant see anything on my tv
    This could be a hard one to set right here's a few things you could try. 1 hold the power button on the ps3 in till it beeps should be around 5 seconds. 2 if using a hdmi try using the av cable instead ( make sure to remove the hdmi frm the ps3) if these don't wrk leave me a comment and I'll try my best to help you some more!
    Apr 06, 2010 | Sony Playstation 3 (PS3) Console
    Can't get Playstation3 sound through the STR-DG800 using HMDI.
    Do you have your ps3 connected to the TV with HDMI and then audo cables from the TV to the receiver? If so, you need to make sure you change the audio settings on your TV to surround sound.
    May 12, 2009 | Sony STR-DG800 Receiver
    Hdmi cable is connected but no picture
    sounds like the hdmi connection on the main board may be bad. try to use 2nd hdmi input if your tv has 2 hdmi inputs. trying using a a/v plug or rgb connection as well and see if you get a picture without the using the hdmi cord. finally, call tech support for you tv manufacturer and describe your problem and your troubleshooting and see if the issue is known and or covered by warranty. the service call is usually free. hope this helps
    Apr 09, 2009 | LG 42LG70 42 in. LCD HDTV
    Cant get 42''lcd telly to let me play ps3 threw hdmi cable
    You will most likely have to contact your LG dealer to fix this. The problem is due to the HDMI input not recognising the playstation, the cure for this is a software upgrade for External Device IDentification (EDID), which can only be done by a service centre.
    Mar 29, 2009 | LG 42LC2D 42 in. LCD HDTV
    Im tryn
    looking at the rear of the set it is on the left side. it si marked mono-link. remember this is only a 1080i set.
    Dec 31, 2008 | Mitsubishi WD-62825 62" Rear Projection...
    Using a Compaq WF1907 monitor with a Playstation3
    No. HDMI transfers picture and sound, but DVI does not. You need a audio line as well.
    Oct 25, 2008 | HP Compaq WF1907 Monitor
    Video Game Consoles & Games Logo
    211 people viewed this question
    Top Video Game Consoles & Games Experts
    James Wishart
    Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
