Solution #1
posted on Aug 08, 2005
Riddle - usenet poster
Rank:
Apprentice
Rating: 0%, 0 votes
Rating: 0%, 0 votes
The best way to avoid red-eye is to have the flash as far away from the lens as possible. If you can mount an external flash onto the flash bracket, use that instead of a built-in or pop-up flash. Similarly, you can use bounce mode to make the light fall on the subject at a different angle/direction from the lens.
If you can get away with raising the ISO, widening the aperture, and/or lowering the shutter speed so you can do without a flash, you can avoid red-eye altogether.
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on Nov 28, 2007
Putting scotch magi/matte finish tape over the flash can help. Also, you might (be very geeky) andrig a little reflector to make it bounce off of the ceiling. Both of these diminish the flash but the first is worth a try.
Solution #3
posted on Apr 09, 2007
I have also found that a single layer from a tissue over the flash will give a much softer lighting affect. I had to make personal ID passes for my employees and found that this little trick made for a much more natural photo.
Suggest a new solution for this problem
Post a New problem for Nikon N80 35mm SLR Camera
Email this problem
Email this problem
This Problem Also Relates To:
Canon EOS Elan 7 35mm SLR Camera
Canon EOS Elan 7e with 28-80 lens 35mm Film Camera
Canon EOS Elan 7ne 35mm SLR Camera
Canon EOS Rebel G-II 35mm SLR Camera
Canon Speedlite 430EX - 35mm Rangefinder Camera
Canon Sure Shot 105 Zoom 35mm Point and Shoot Camera
Canon Sure Shot 115u II Date 35mm Film Camera
Can you Help with these Film Cameras problems?
The AF-Assist Illuminator
The AF-Assist Illiminator on my... Answer This...
Double Exposure The Easy...
I can set my camera on multiple... Answer This...
Repair Service
Find Film Camera Repairman Near You:
