Question about Dryers
No heat and filter care light constantly lit - Dryers
  • 334 Answers
Have you cleaned the filter and the filter compartment?
Try that, then unflug it for about 10 min, then plug it up and try it again.
This will reset some units with an auto reset high temp limit switch.
What happens when a filter gets dirty/clogged is that not enough air is blowing accross the heating device. This lets it get to hot and it will shut off for safety to prevent fires.
If everything is clean and after pluging it back up it still gives you that code you may have a bad sensor.
Posted on Dec 06, 2008
Hoover tumble dryer vhv 380 filter care light constantly on even thou there all spotless .....please help
Please vacuum the lint filter housing and check the outside vent on your house for any lint build-up.
Oct 16, 2015 | Hoover Dryers
After I start my car and disengage the handbrake, the handbrake light is dimly lit (should be off). At the same time, my headlights, windshield wipers, rear wipers and window heating, and heating vents...
what you described is symptoms of a bad ignition switch, when you are moving the key around to find a good spot it is internally moving the contacts until they catch a good spot, this happens when they get worn.
Sep 29, 2012 | 1997 Volkswagen Golf
Will not power up has constant on off flicker , when I turn it on the green light clicks off and turns red and the cycle repeats. I have checked the fuses and also resolderd the power board. is there any...
Hi Eric,
First of all, thank you for contacting Fixya.com regarding on your TV problem.
I've suspected a convergence chips failure not the power supply board issue in this kind of symptoms. To confirm it, locate the convergence board inside the set, it has a Sanyo convergence chip STK392-110 that are mounted on the large heat sink. This board has a LED (light emitting diode) that will light up once the board gone to malfunction. Turn on the unit and then check if the LED will lit after the shuts down. If yes, then I would advice you to replaced both convergence Chips and check the resistance of the resistors in line with the +25V and -20V supply of the chips.
Let me know if the LED at the convergence board does not lit to continue our diagnosis... Check also the LED at the power supply board and on the deflection board(this is where the flyback transformer is located)
Have a nice day!
Goodluck and take care!
Kind Regards,
Jdvillanueva
Dec 03, 2011 | Pioneer PRO-99 TV
Reliance 606 natural gas water heater - model #640YORT - water does not stay hot. pilot has to be clicked to heat and then u can use hot water til tank empty and it will not continue to heat water.
If I understand correctly, the pilot light is not staying lit.
You light the pilot and water in the tank reaches temperature.
Once hot water is gone, then pilot light has to be lit again.
Gas pressure is good, and gas is flowing.
Thermostat is working at high end because it cuts off heating.
Vent is working because tank heats up.
Air intake is working.
Gas control thermostat might not be reading low temperature. Replace gas control valve.
Pilot tube might be dirty. Clean burner parts and combustion chamber, and air intake, and vent.
Backdraft might be blowing out pilot. Check for constant updraft by running water heater 5 minutes, and then light match under vent hood and see if smoke goes up.
Very hot air can put out pilot, especially when water heater located in attic. Add ventilation.
Improper vent might have water dripping back down into combustion chamber and putting out pilot light and rusting out the parts. Inspect for rusted parts and water.
http://waterheatertimer.org/How-to-install-gas-water-heater.html#troubleshoot
http://waterheatertimer.org/pdf/Pilot-light-will-not-stay-lit.pdf
Aug 09, 2011 | Reliance Natural Gas Water Heater Control
I live in a rented home and my heat is not coming up through the registers, could the filters be clogged, we know nothing about heat pumps. Should we check the filter first, before calling our landlord in...
If it is forced air heat then you should change the filters. Also check to make sure the heater is kicking on. The main heat trunk line should feel warm right by the heater.
Jan 22, 2010 | Ruud UBHC Air Conditioner
Whirlpool Dishwasher ADP 4601 , Light flashing constantly.
There is a switch attached to the door latch that may need to be replaced. (the switch is inside the door).
Feb 08, 2009 | Kitchen and Much More Dishwashers
Red led light on constantly
electronic circuit needs replacement
Feb 01, 2009 | PUR (FM-9500) Air Purifier
Hi,ive got the abs,traction control and handbrake light lit on my dash.the lights are on constant.can you help.
Hi, the lights get lit when the brake fluid level in the reservoir falls too low or the fluid level signal is broken due to dirt in the connector. You could remove and install the sensor electric connector, located above the reservoir, and carefully knock the reservoir to release the possibly stuck level sensor.
Nov 05, 2008 | 1999 BMW 323 Series
Dryers Logo
302 people viewed this question
Top Dryers Experts
