Question about Canon imageRunner C3100N Copier
Irc 3100 e070-001
Hi i git this prolem when i clean the itb theni i change the whole assy. from working one but the error still there i clear the error and the dc but there still the error.please help me.
  • 76 Answers
Try to check the grounding plate did not come in contact with the shaft of the ITB
drive roller in the ITB unit, causing a poor ground (1 case). This grounding plate is used to establish a ground for
the ITB tension roller to the ITB drive roller.
E070-0003 can be displayed when the time that passes between the first detection of the ITB home position (HP)
and the next HP detection is shorter than a specific period of time.
Field Remedy
Follow the steps below:
1. Make sure that the inner surface of the ITB has stains or scratches on it.
2. Make sure that the ITB-HP sensor (PS19) operates normally.
3. Make sure that the grounding plate properly comes in contact with the shaft of the ITB drive roller.
Posted on Dec 08, 2008
Canon irc4580i print dark problem
In the process used printer, will be inevitable printed page by your printer have the bad quality prints. For example: Toner specks, Light image, Vertical line, Dropouts, background, Toner smear, Vertical black line and band, Vertical white line, Background scatter, Black pages, Loose toner, Horizontal stripes, Ghost, Uneven Density, poor fusing ...
The common print quality problem Canon IRC-4580 printer
Currently, The Canon IRC-4580 is the laser printer have high speed, easy to use, friendly for user and printing clear text.
However, we can not avoid the damage of some components of the printer when used.
In this article, I will introduce some basic errors with printing quality problems of Canon IRC-4580 printer and "How to fix it".
After viewed artical, you know:
- How to fix (repair/solve) Vertical line (black or white) in Canon IRC-4580 printer
- How to fix (repair/solve) Poor fusing (loose toner) in Canon IRC-4580 printer
- How to fix (repair/solve) Uneven Density in Canon IRC-4580 printer
- How to fix (repair/solve) Light image in Canon IRC-4580 printer
- How to fix (repair/solve) Ghost in Canon IRC-4580 printer
1. Fix print quality problem "Vertical line" for Canon IRC-4580 printer How to fix print quality problem Vertical line
This plobrem "Vertical line" is usally error of Canon IRC-4580 printer. For this "Vertical line" error, technicians divided into two smaller error are: Vertical black line and band and Vertical white line.
Description:
- Vertical line and band: On the printed image appear some straight thin black vertical.
- Vertical white line: On the printed image appear some white vertical voids.
Error location:
- Surface of the charge roller
- OPC drum
- Cleaning blade
- LSU unit
- Developing roller
Cause of error "Vertical line" on the printed page:
- May be surface of charge roller scratched or dirty by toner powder.
- May be have some grooves on the OPC drum.
- May be cleaning blade is damaged.
- May be LSU window or LSU lense has dirty.
- May be surface of developing roller has scratched.
How to fix(repair) "Vertical black Line and Band" for {{SPkey1}} machine:
- Replace the charge roller of toner cartridge.
- Replace the OCP drum.
- Replace the cleaning blade
If printed page are not improved
- Clean the LSU unit by soft cotton cloth and try to print. If Vertical line is not clear on the printed page you should replace LSU unit.
- Replace new axis developer and try to print
2. Solve print quality problem "Poor fusing (loose toner)" for Canon IRC-4580 printer. How to fix print quality problem loose toner
Description loose toner: Toner is not properly fixed on paper, use to hand rubbing lightly on the printed image toner powder may be stick in hand
Error location: toner cartridge or fuser unit
Cause of error "Dark Image or black" on the printed page:
When toner cartridge is empty. You toner refilled by toner powder ware not compatible. This is makes toner cartridge components demaged and temperature of fuser unit is not enough melt to toner powder
How to fix(repair)"Poor fusing (loose toner)" on the printed page for Canon IRC-4580 printer:
With this error, you should replace toner cartridge or fuser unit to fix it.
3. How to fix print quality problem "Uneven Density" for Canon IRC-4580 printe How to fix print quality problem Uneven Density
Description: The printed page has one half light and one half clear.
Error location: Toner cartridge, transfer roller, springs, doctor blade
Cause of error "Uneven Density":
- The pressure force on the left and right springs of the transfer roller is not even.
- May be toner low also causes this error
- Doctor blade has bent
How to repair error "Uneven Density" on the printed page for Canon IRC-4580 printer:
- Replace springs and transfer roller.
- Toner refill toner cartridge Canon IRC-4580 and reset toner cartridge chip (replace new chip) or replace new genuine toner cartridge.
- Replace doctor blade.
4. How to solve print quality problem "Light image" for Canon IRC-4580 printer How to fix print quality problem light image
Description: The printed image is all light and no Ghost.
Error location: Toner cartridge, Developer, HVPS board
Cause of error "Light image" on the printed page
- Enabled toner save.
- Toner cartridge is low
- OPC drum may be faulty by strong light intensity
- Temperature in room is below than 10*C
- Bad contact caused by the toner dirty between the high voltage terminal in the HVPS and the one in the set
- Abnormalities output from the HVPS
How to fix(repair) error "Light image" on the printed page for Canon IRC-4580 printer:
- Disable toner save by change in printer driver.
- Replace the OPC drum.
- Replace developer.
- After printer is power on, wait 30 minutes then start printing
- Clean up the contact between the high voltage terminal in the HVPS and the one in the se- Replace the new HVPS if the problems are not solved by 4 away above.
5. How to fix print quality problem "Ghost" for Canon IRC-4580 printer How to fix print quality problem Ghost
Description: Ghost occurs intervals of the OPC drum or transfer roller.
- OPC drum has fauty.
- The life of the transfer roller has been expired
- The high voltage terminal is contaminated by toner powder or
- Replace OPC drum
- Replace transfer roller
- If performed 2 away and the error does not clear, you should replace ganuine toner cartridge .
- Replacce HVPS board.
Oct 29, 2016 | Canon Office Equipment & Supplies
How can i resolve Erreur E000020-0125 pour photocopieur canon IRC 4580i
SALT sensor(replace it or clean window),replace the drum unit,clean or replace ITB unit.Concerning the first two digits of detail code:01-Y,02-M,03-C and 04 Bk.So in your case the problem is in yellow unit...
Sep 26, 2014 | Canon Office Equipment & Supplies
E000012-0001
Thread irc 3220 error e000012 0001
Your ITB unit (Intermediate Transfer Belt) may need changed. Try removing it first and rotating by hand.
If it sticks, you are probably looking at a new unit.
The link above is for the iRC3220 but Canon codes are generally all the same.
You may find there's a tear in the belt and this is why it is not working properly.
Mar 28, 2014 | Canon iRC3100 Printer
Canon irc 3080i error code e000020-0023
NITIAL FAULT IS ERROR CODE DUE TO WORN BLACK DRUM GIVING PATCHY IMAGE, ON FITTING A NEW DRUM IT CREATES ANOTHER ERROR CODE ABOVE E020, ON RE-FITTING OLD ONE ERROR DISAPPEARS. PATCH CREATED ON ITB IS UNDERTONED DUE TO LESS INTENSITY LASER BEAM PASSING THRO, THE RESIDUE ON THE GLASS, HENCE E020-0023.
THE CLEANING TOOL ON THE DOOR IS INADEQUATE TO CLEAN THIS RESIDUE. PULL OUT PROCESS UNIT TO MAX. LIMIT. PRISE UP THE DUST SHUTTER, THEN CLEAN WITH DAMP WIPE AND DRY IT. REPEAT IF NECESSARY OR TAKE LASER UNIT OUT
Mar 28, 2012 | Office Equipment & Supplies
Canon 3170u error E000070-0002 how to fix this problem
E070 ITB HP detection error
0001 HP of the ITB fails to be detected even
after the specific period of time.
Abnormality of the HP sensor,
Deviation of the belt from its position to
either edge, or soiling of the seal
Clean the HP detection seal, Clean/Replace the HP
sensor
0002 The next HP fails to be detected within
the specific period of time after the HP
of the ITB is detected.
Clean the ITB back side and the drive roller
BE CAREFULL TO REACH THE WHOLE ITB UNIT YOU NEED TO REMOVE FIXING UNIT TOP COVERS IN PAPER DELIVERY SECTION, IT NOT WOULD BE BAD TO REMOVE RIGHT DOORS OF COPY MACHINE, REMOVE ITB CLEANING BLADE UNIT,...
Jan 10, 2010 | Canon ImageRunner C-3170U Copier
Canon IRC 3200. Displacement in Sub Scanning Direction
You can try running a gradation. (Add Funct-Adj Cln-Gradation-full) Unfortunatly your ITB is most likely streched out. This is most common cause. Replace ITB and run gradation
Nov 28, 2009 | Canon Office Equipment & Supplies
My irC-3200 cannon just show me this error E012 number on the display screen so i want to know what this code mean??Please help me
E012-0001 Error code At about 37 sec. after the power is turned ON, due to a drum ITB motor failure
Symptom About 37 sec. after the power is turned ON, E012-0001 is displayed due to a drum ITB motor failure. Cause Rotational failure of drum ITB motor Items to Check 1) In service mode level 1 COPIER > FUNCTION > PART-CHK > MTR, enter 1 and press the OK key.
2) In service mode level 1 COPIER > FUNCTION > PART-CHK > MTR-ON, press the OK key to check whether the motor is working normally.
3) Check whether 24V is supplied to J93 on the ITB drum motor. If yes, the ITB motor likely faulty.
4) If 24V is not supplied to the ITB drum motor, check whether 24V is output from fuse PCB J70-3 to the ITB drum motor.
Also, check whether 24V is output from the fuse PCB J71-1 to the microswitch PCB and also whether 24V is supplied to the fuse PCB J71-2 from the microswitch PCB.
5) If there is no problem between the fuse PCB J71-1, -2 and the microswitch PCB, the fuse PCB is likely faulty.
If 24V is output from the fuse PCB J71-1 to the microswitch PCB and not supplied to the fuse PCB J71-2, check the microswitch PCB. Field Remedy Replace the drum ITB motor.
FH6-1971 DC Brushless Motor
Sep 01, 2009 | Canon Office Equipment & Supplies
I have 3 color copy machines irc3200n,clc 2620 all the machines
the cause of the problem is ,the transfer belt is not rotating properly ITB rollers must cleaned throroughly (cleaned by isopropyl alcohol) to prevent slippage of transfer belt that causes mis alignment /misregistration of color,but copying BW is ok,In other words ITB unit needs servicing ,Run also gradation adjust QUICK and FULL adjust (for IRC 3200)
Aug 04, 2009 | Canon Office Equipment & Supplies
Error code E000070-0003
checkpoints...
1)check for itb assembly grounding
2) white patch inside itb
3) secondary transfer roller rotation
4) variastor at registration assembly
Apr 02, 2009 | Canon iRC3100 Printer
Canon ImageRunner 3200
there are several steps before reaching the laser i-- clear dc con then take machine off remove plug from outlet then power up machine 2--clean the itb assembly thoroughly 3---change the transfer belt 4 --- change the itb assy. if nothing works then we will go to the laser
Jan 06, 2009 | Canon imageRUNNER C3200 Copier
Canon imageRunner C3100N Copier Logo
330 people viewed this question
old marine
old marine
