Question about Mitsubishi WS-65869 65" Rear Projection Television
WS-65869 turns off after 3-4 secs.
When I turn on the set I hear a relay click on and the green light on the front panel light up after 3 - 4 secs the relay drops out and the tv shuts down. When the problem 1st occured the tv was on and it went solid blue then it turned off. The relay that clicks in/out is near a 5 pin IC STR-G6623. I read in another post this IC is a regulator of some sort, where can I get ahold of a schematic for this tv?
  • 3 more comments
  • Bill Schatz Dec 13, 2008
    Extra info: I was able to download schematics, and I found fuses F9A02 & F9A05 (+24V & -24V) were blown. I tried replacing the fuses and the TV stayed on longer, but the fuses blew again and the TV shut off.
    I made an error in my extra info post it should have read fuse F9A04 for the +24 volt.
    As to the solution provided, in the service manual there is an 11 pin IC listed as the HV regulator, and there is a large FET/Transistor which were you suggesting I replace?
    The TV shuts off in less than 10 seconds, and if I replace the +24V & -24V fuses the TV stays on until the fuses blow.
    I agree with the dufficultly of fixing problems long distance. I have a DVM & a scope and a soldering iron. The Main fuse is good and so are all the stand-by voltages and fuses (6V, 12V). On the switched side the 17 volt Audio fuse is good, & the 110 volt fuse is good as well.
    Sorry I'm new to how this works. I have downloaded both the schematics & service manual for this TV. I do appreiciate your suggestions and I'll see if I can find a bad cap somewhere in the 24 volt circuit.
  • 365 Answers
There may be some damaged IC and try to replace it.thank you
Posted on Dec 13, 2008
  • JITHIN ANTONY Dec 13, 2008
    the manual can be here manualsonline.com
  • 4,472 Answers
Https://www.manualsparadise.com/ShowProductsForModel.do?model=M68648953
you can purchase the service manual for a small fee at this website. Definitely a smart investment.
I believe this a bad capacitor in the power supply, and yes it could still turn on and the fuses would get tripped just like this. Start there. Should not be more then 300$ for a professional. If you need any further assistance please let me know. Also please take a moment to accept and rate my solution accordingly.
Thank you,
Lee
  • Lee A.
    Lee A. Dec 13, 2008
    Though if you have a transistor/diode checker I would check the horizontal transistor and then if that is bad and you hear a clicking at all it may also be your flyback transformer/horizontal transformer. You may need to change them both as one takes out the other. Please take a moment to accept and rate my solution accordingly.
    Thank you,
    Lee
  • 734 Answers
Based on your description, the most likely diagnosis is a failure of the power supply stage although please understand that TVs are quite complex and diagnosing one without being in the same room is not easy.
This area of the TV comprises some fuses, a bridge rectifier (4 diodes) a couple of capacitors, fusible resistors and a regulator. All are prone to failure.
That stuff can be checked quite easily if you have a multimeter and a soldering iron. Is this something you think you are capable or willing to do?
The first thing to check would be the main fuse.
If you don't feel comfortable doing this, the repair cost will likely be between $200 and $400.
  • futureloginn
    futureloginn Dec 13, 2008
    ok,
    change HV regulator fixs your problem.
    Thanks
  • futureloginn
    cost will likely $300
    Thanks
  • 116 Answers
One of the control boards has shorted, you can try to disconnect the boards one by one till its stays on, that will tell you what board is failing, also look for any charded marks, if you have a meter you can start loking for shorts, doubt it is the power supply if it came on with the fuses replaced,
  • 2 more comments
  • Justin Washburn Dec 13, 2008
    i would start with the bards near the picture tubes, as these are high voltage circuits, using the schematics follow the trail and see what uses the 24v, its the best starting point.
    if the hv regulator fried it would have visible signs of damage, check it for open/ short .
    same goes for the transistor, if you get a dead short then youll knwo which to replace.
    look for swollen caps, tranistors will need to be tested for continuity, can you post the schematics for me?
    Genius:
  • 1,847 Answers
Check your sleep mode settings on it, it may have defaulted to 1 min, so it cuts off when it cuts on
    Genius:
  • 1,199 Answers
This sounds like the flyback regulater on the main board is burnt out! (the part is around 70.00 go to www.sears.com and have make and model readt they should be able to get you the part and the scematicThis should fix ya! thanks for useing us!
Mitsubishi 65" WS-65869 Blinking Green Light 3-2 pattern,
two ideas:
Make sure you tested the pico fuses inside the unit with the caps==two or three of them.
Also from front of set behind speaker grill unplug both plugs that go up to front keyboard--set will still work with remote===if set functions now then the reset micro switch is bad/damaged.
Mar 12, 2012 | Mitsubishi WS-65869 65" Rear Projection...
Mitsubishi Medallion does this
hi there,
Check for bad solder on convergence module. May have bad stk's. Do not neglect looking for bad solder on dsignal and defl boards. Mitsubishi is very prone to bad solder.
`jack
May 26, 2008 | Mitsubishi WS-55411 55" Rear Projection...
Blinking green light on my mitsubishi tv....model ws-65869
Replace the Capacitors on the DM board. You can get the WS55859 DM repair kit which covers your model from www.tvrepairworld.com which has the caps and the CD with repair instructions
Jul 14, 2010 | Mitsubishi WS-65869 65" Rear Projection...
Mitsubishi WS-65869
This set will require that the power supply voltage problem be fixed...accordianman
Jan 20, 2008 | Mitsubishi WS-65869 65" Rear Projection...
Mitsubishi ws 65869 green led turns on for 2 sec then turns off
Your problem is not shown on schematic, C9A60 (470 pf @ 1000 v) capacitor and check and see if F9A04 & 05 are open. If so then its off to a whole different area. Do you have an email to send Sch.?
Jan 15, 2008 | Mitsubishi WS-65869 65" Rear Projection...
Blinking green light stays on and TV won't turn on.
Check for open pico fuse in power supply caused by bad convergence I.C.Get pro help-you have a good set to save.Remember--practice visual acuity technique!And,above all else,do no harm!!
Aug 26, 2007 | Mitsubishi WS-65869 65" Rear Projection...
Mitssuisbihi ws 65869
This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the device and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source) 1. SHUTDOWN AT POWER WITH SELF DIAGNOSIS ERROR 2 2. CHECK FOR LEAKY C9A60 470 PF 1000 V PART # 154P400030, PARALLEL TO D9A57 ON THE POWER PCB. 2. SHUTDOWN AT POWER WITH SELF DIAGNOSIS ERROR 2 2. CHECK FOR OPEN FUSES F9A04 AND F9A05 ON THE +24 AND -24 VOLT LINES. IF THE FUSES ARE OPEN THE CONVERGENCE OUTPUT CIRCUIT WOULD BE SUSPECT.
Aug 25, 2007 | Mitsubishi WS-65869 65" Rear Projection...
Mitsubishi WS-65869 65 in. Power Light
They are little green soldered in fuses located on the center board (the one with the STK's on it) toward the rear of the set near the large transformer.
Aug 24, 2007 | Mitsubishi WS-65869 65" Rear Projection...
Open Questions:
See all Mitsubishi WS-65869 65" Rear Projection Television Questions
Mitsubishi WS-65869 65" Rear Projection Television Logo
20 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
