Question about Canon CLC 1140 Copier
I nedded sst v.1.4
For updateing lang
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 89 Answers
If you're authorized by Canon ring them up and they'll help you get it.
Posted on Jul 25, 2009
00602-003 error
Your hard disk needs to be replaced!! E602-003 is a bad sector read on the hdd, if you restart the machine it may work for a while but it WILL come back.
You need canon part number WM2-5230-000 (not sure how you would get it) it needs to be installed in the back of the machine at the top of the main body after the back cover has been removed.. Once this is done you dilemma begins, Canon uses a program called "service support tool (SST)" which is only a canon issued program, this program is the tool used to update all the software and firmware in iR devices. This can only be connected to a 2200 machine via usb to centronics cable with a "nethawk driver" driving the cable. Then SST need to have the firmware for the 2200 series registered (it does not come together) within SST, then connect cable and turn the machine on at the switch on the right hand side WHILE holding keys 2 & 8 together, this will give you a black screen which only shows "DOWNLOAD MODE" in the lower part of the screen. Then the machine is ready to accept the data. SST is extremely touchy, so if anything is not right you will get a lovely pink screen in SST saying an error code. To correctly set up the hard drive you must first format the HDD from within SST, then install the BOOT and SYSTEM versions (boot must be "N" at the end of it's version eg. 37.44N to be a printer or a stand alone copier will have a "C" at the end. You must pick the right one or you will not be able to print (if it has a PCL kit installed in the machine).
After all Boot, system, language, fax versions are installed restart the machine, wait for a couple of minutes intil all that data is written to the HDD and it will pup up ready to go.
Apr 22, 2014 | Canon iR5000-6000-L1 PS Ver 1.0
I have a mazda cx7 2007. I dont think i am timing it correctly. can anyone give me some advice?
Oh no,
Are you replacing VVT and chain? You need 2 special tools for this.. 1 to hold the camshaft where the slot is for the high pressure fuel pump, and another beside the crank damper on the rear of the motor, there is a small 10mm bolt that you remove and install a "holder" of sorts that holds the crank at TDC.
If you fail to do both of these steps before removing the chain you run the risk of throwing the timing out. Part numbers are as follows for the SST's.
Camshaft: (picture 1) SST 303-1061 (49 UN30 310610)
Crankshaft: (picture 2) SST 303-507
Jul 23, 2013 | Cars & Trucks
We ned a copy of the HP Laser Jet MANUAL for M1522nf. SOMEONE ERASE THE SETTINGS. Help.
All the info you need can be found here:
http://h20000.www2.hp.com/bizsupport/TechSupport/Home.jsp?lang=en&cc=us&prodTypeId=18972&prodSeriesId=3442750&lang=en&cc=us
Thanks
Moza805
Sep 01, 2011 | HP LaserJet M1522n MultiFunction Printer
Won't print;
The problem means that your hard disk needs to be replaced. E602-003 is a bad sector read on the hdd, if you restart the machine it may work for a while but it WILL come back.
You need canon part number WM2-5230-000 (not sure how you would get it) it needs to be installed in the back of the machine at the top of the main body after the back cover has been removed. Canon uses a program called "service support tool (SST)" which is only a canon issued program, this program is the tool used to update all the software and firmware in iR devices. This can only be connected to a 2200 machine via usb to centronics cable with a "nethawk driver" driving the cable. Then SST need to have the firmware for the 2200 series registered (it does not come together) within SST, then connect cable and turn the machine on at the switch on the right hand side WHILE holding keys 2 & 8 together, this will give you a black screen which only shows "DOWNLOAD MODE" in the lower part of the screen. Then the machine is ready to accept the data. SST is extremely touchy, so if anything is not right you will get a lovely pink screen in SST saying an error code. To correctly set up the hard drive you must first format the hdd from within SST, then install the BOOT and SYSTEM versions (boot must be "N" at the end of it's version eg. 37.44N to be a printer or a stand alone copier will have a "C" at the end. You must pick the right one or you will not be able to print (if it has a PCL kit installed in the machine).
Thank you !!
After all Boot, system, language, fax versions are installed restart the machine, wait for a couple of minutes intil all that data is written to the hdd and it will pup up ready to go.
Hope this helps.....
May 21, 2010 | Canon imageRUNNER 2800 Black and White...
Canon ir3300 error602-003
how to install data in the hardisk of ir 3300 machine. plz say me the full process what is sst and everything
Dec 09, 2009 | Canon Office Equipment & Supplies
Canone ir2016 SST HELP
send your mail to el.zoubir@gmail.com
i have all sst verson
i need firmware for cano IR 2016J
Nov 04, 2009 | Canon Office Equipment & Supplies
I nedd sst for canon IR8500
i can get you the newest ver. of the SST but i need your email and you have to rate first
Mar 15, 2009 | Office Equipment & Supplies
Update
reduce the number of processes u run... make ur startup lighter...
Feb 01, 2008 | Computers & Internet
Canon CLC 1140 Copier Logo
100 people viewed this question
old marine
old marine
Corne Viljoen
