Question about GE Profile JTP18 Electric Single Oven
My oven, electric, overshoots the set temp then fades down
It then fades down to 20 or more degrees before heating up and never reaches set temp again?!!! It's about 4 years old and useda few times a week for a household of 2.
  • GE Master
  • 3,463 Answers
Probably faulty oven thermostat.
Posted on Dec 06, 2008
My oven gets warm but will not reach set temperature. Is this the element
Hello Peter;
My name is Peter. I am a retired field service appliance technician.
I recently repaired a oven that would be off as much as 200 degrees. The normal operation of your oven is to rise 20-40 degrees above set temperature and shut down until it drops 20-40 degrees below set temperature, turns back on and repeats the cycle again.
Generally, there are only three components that control your oven temperature:
1.) The Heating Element - If you are getting heat your heating element may be good. To be on the safe side inspect the two connections on the back wall to ensure they are not corroded.
2.) The Thermocouple - There are several different thermocouples depending on your model and if your have gas or electric. These are easily replaced.
3.) Oven Control - Here again there are several different controls, both mechanical or digital.
I just purchased a oven thermocouple and a reconditioned digital control over the internet for under $75.00.
IF YOU HAVE A DITIGAL CONTROL - GROUND YOURSELF BY TOUCHING BARE METAL. STATIC ELECTRICITY WILL KNOCK OUT A BOARD.
So, go into the following website put in your model number and select parts. Several diagrams with part numbers will appear. Your model number is on a metal plate on the face of your oven after you open the door.
Fine your thermocouple and oven control. Copy these part numbers and search the internet for best price.
First, replace the thermocouple. If this solves your problem then return the control for credit if not install the oven control. The highest probably is you have a bad thermocouple
Water Filters Lawn Garden Appliance Parts
May 07, 2015 | Ovens
GE free-standing electric range Pre-heat oven temp is about 50 degrees less than what is set (i.e. set digital display to 400 and over only reaches about 350). Is there an adjustment that can be made to...
We have a new GE Range and the signal beeps at about 100 degrees below the temp which we have set . The dealer replaced the sensor and the control circuit, but there was no change.
A service tech from GE came to our house and explained that the new ovens have a bottom heating element which is covered and therefore heats the lower part of the oven more slowly; but the exposed upper element heats more rapidly and the sensor is located near the upper element. We were advised to wait for about 15-20 minutes after the beep before placing the food in the oven. Judging from the number of comments found online, this seems to be a feature of newer ranges.
SnapDoc
Nov 08, 2010 | GE JKS05 Electric Single Oven
Ovens wont heat to temp
The reason to this problem can be due to the faulty
thermostat.
Sep 02, 2009 | Lincoln Conveyor Oven - 1133-000-A
Kitchenaid oven KEBC107KSS03 won't heat after cleaning cycle.
I have a kitchenaid oven # KEBC107KSS03. When I set the temp to 400 the buzzer goes off saying the temp has reached the desired temp, the temp is only 250 and will take another 20-30min to reach 400.
thanks for your reply
Aug 25, 2009 | KitchenAid KEBC107 Electric Single Oven
Incorrect temperature
under the oven knob is the screw that adjusts the temp. remove the knob and with a small blade screwdriver adjust the temp according to your wife's oven thermometer CW+hotter CCW=cooler
then on the back of the knob is a screw to adjust the position of the knob with respect to the marker
Apr 20, 2009 | Viking 30" Professional Select Built-in...
Temp indicator chimes although temp is really 100 degrees low.
Yes you do need a new thermostat, just make sure that the sensor is not obstructed by anything. first.
Plz rate my solution
Thanks.
Dec 18, 2008 | Jenn-Air WW30430P Stainless Steel Electric...
NEFF Oven Model B1430NOGB/02 Oven Temp not heating above @50 degrees
probably the element. to save wasting money, check continuity with a multimeter
Jun 25, 2008 | GE Profile JT912 Electric Single Oven
Kenmore electric oven
Sears Kenmore Electric Wall OVen, Mod.#9114012192 purchased in 1993. Set oven for 425 degrees, reaches set temperature, stays on about 10 minutes and temp. display goes out and oven starts cooling down. Will not stay on desired temp.to cook. Can you tell me what my problem is? Thanks. Doug.
Dec 02, 2007 | Ovens
GE Profile JTP18 Electric Single Oven Logo
114 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
