Question about Kyocera Yashica T4 35mm Point and Shoot Camera
Yashica Digital Camera EZf 1230 Cannot power up
I charged the battery until it's fully charged, but the camera still can not starting up , what is the problem ? please advice, Thankyou, Louis
  • ms_william20 Apr 14, 2009
2 Suggested Answers
rehmanhazeen
SOURCE: Hi, My Yashica EZ 5011 camera will not turn on.
i need a yashica's webcam softwares so plzz say me where is ??
Posted on Dec 29, 2012
Yashica com
Depending of what you use, always be sure all batteries are the same, charged and suited for your camera. Most of the time even new Ni-CD rechargeable batteries won't work, because the voltage is to low, according to NiMH or alkaline batteries.
Always charge NiMH batteries before using them for the first time, or if they have not been used for a long period. 3 months is a very long period.
Always charge sets of batteries (2 or 4) together.
Do not use alkaline batteries unless it is absolutely necessary. In some cases, alkaline batteries may have a shorter service life than NiMH. Alkaline battery performance is limited, especially at low temperatures. The use of NiMH batteries is recommended.
Never use manganese (Zinc-Carbon) batteries in your camera.
Jan 03, 2014 | Cameras
How to use Yashica EZF8035 Digital Camera as a webcam....?
Dear Sir
As we go the quick view, and after seeing like 8 to ten pictures, the camera switch offs, orther times It works properly,we can take pictures, but the to view pictures it is not possible, could you heip me, camera model no EZF 8035 YASHICA make
Apr 27, 2012 | Cameras
My nikon s4100 coolpix does not turn on
Hello Ice,
Please check the battery of the Nikon Coolpix 4100 Digital Camera. Please check the battery is fully charged or may be its damaged if its swollen. Also check the contact points of battery and camera and clean it. Insert the battery and charge it fully. When the battery gets charged fully then press the power button 4 to 5 times to start it. If the battery is damaged then replace the battery with new battery.
Jul 04, 2011 | Nikon Coolpix 4100 Digital Camera
My camera dosen't turn on
If your camera won't turn on, first of all try to charge your batteries until it's fully charged. If this doesn't solve your problems, check if your battery pack is busted by using your power supply to turn your camera on. If using a power supply solves your problem then consider replacing the battery of your digital camera.
Dec 25, 2010 | Vivitar V7028 Digital Camera
I need user manual of yashica ezf 827 digi cam.
There is a one page discription not a manual for Yashica ezf 827. But it is useful at least.
http://www.4shared.com/document/neiolNuU/yashika.html
Jun 16, 2010 | Cameras
My battery is fully charged but when i turn the camera on it shuts right back off
SOunds like your battery is bad. try discharing it :
  1. Place the battery in your camera until it itself turns off. In this situation, the battery is fully discharged.
  2. Take out your battery and slide it into your battery charger.
  3. Connect your charger with power to fully charge the battery. It is normal for a new battery that battery indicator shows 100% capacity in 10 to 15 minutes. Please keep charging until there is no time left for charging.
  4. Fully charged and fully discharged or "cycled" as much as five times to condition them into performing at full capacity.
Try it and see if it works? If the batteries are not rechargeable then the problem is in the cameras power supply and you need to take it in or replace it.
Jun 13, 2010 | Sanyo VPC-T1060 Digital Camera
My lightly used nikon coolpix s570 has developed a power issue. Meaning that with a fully charged battery, the camera won't turn on. sometimes removing and reinserting the battery will get it to turn on....
If you have a second battery, fully charge it and try it. If you do not have a second battery, it make either be a defective battery or a battery that is not properly charging. Try powering on the camera until you get it powered up, either by reinserting the battery or turning it one. Then purposely use the flash and focus until you totally exhaust the battery. Then charge it for the recommended time. Try the battery in the camera once more. Also look into the battery compartment and make sure there is no corrosion. After these actions, the only other thing I could suggest is trying a new battery or sending it in for repair. Usually it is the battery though.
Mar 22, 2010 | Nikon COOLPIX S570 Digital Camera
New BN-V428U battery
BATTERY TIPS
Now a days in LITHIUM BATTERIES are used no memory effect
always charge battery for 16 hours when first use new
never keep ur battery fully discharged for long time when u store ur camera always keep it half charged or fully charged when storing for longer period
it is good to fully discharge once in a month but dont make it ur habit
pls rate me FIXYA for help
Apr 13, 2009 | JVC GR-D50 Mini DV Digital Camcorder
FUJI F20 Won't Power Up - Good and Charged Battery
Fuji FinePitteryx refuses to power up,even after new lith. batteries were installed
Mar 04, 2008 | Fuji FinePix F20 Digital Camera
Canon PowerShot S45 Digital Camera
Maybe this fuse is blown:
http://www.hit-karlsruhe.de/aol2mime/images/S45_S50_PowerFuse.jpg
Short it or replace it.
See also http://www.hit-karlsruhe.de/aol2mime/canon_powershot.htm
eNDi
Oct 17, 2007 | Canon PowerShot S45 Digital Camera
Kyocera Yashica T4 35mm Point and Shoot Camera Logo
211 people viewed this question
Top Kyocera Cameras Experts
Iqbal Husain
Iqbal Husain
Are you a Kyocera Camera Expert? Answer questions, earn points and help others
